Go Back   Honda Civic Forum > GENERAL > Honda Civic DIYs and Civic Tech Chat
Honda Civic DIYs and Civic Tech Chat Honda Civic DIYs and Civic Tech Chat - for the true gearheads! Bring your wrench, it's time for some Honda Civic DIY projects! Questions about problems with your car do NOT go here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 08-15-2009   #1 (permalink)
Running Riot
Senior Member
Running Riot's Avatar
Running Riot will become famous soon enough
Send a message via AIM to Running Riot
i searched for it no luck, valve clearance ?s
So I got a little over a grand to play with and I was either going to boost or build and I can't really build anything reliable with boost for a grand so NA is the way to go. As some of you know im using skunk2 pro 1 cams with 10.4 pistons. I want to get up to about 11.5-12.1 compression usings cp srp or je wiseco pistons and a mugen head gasket. I want to be able to adjust the timing too maybe +1 -1. My question is, is there a dimension, a measurement or some kind of guide that will tell me definitively that my valves wont smash into my pistons? the lift on the cams is pretty good, a bit higher than CTR cams and ITR cams and I'm just worried that my valves will hit the pistons at 9k rpm. (that would be no es bueno) I searched on google and all i found were domestic shit kickers and when i searched "valve clearance" here on the forums I got a bunch of BS threads and one for valves on clearance....
If someone out there is running a similar set up and wants to give me some input that would be great. Thanks guys.
__________________
B16 10.4:1 JDM Pistons ITR Manifold 70.2mm Throttle Body Skunk2 Stage 1 Pro Cams AEM FPR DC Header Magnaflow Custom 2.5" exhaust BDL Fuel Rail Nology Individually Grounded Wires Fidanza 7.5lb Flywheel Exedy Clutch Goodridge Braided Steel Clutch Line Fidanza Short Shifter Skunk2 knob JUN Chip
IM SO JDM I EVEN HAVE SARS
Running Riot is offline   Reply With Quote
Sponsored Links
Old 08-15-2009   #2 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
Re: i searched for it no luck, valve clearance ?s
usually "valve clearance" adjustments should be given to you with the cam you buy. if you are adding too many parts together, nobody can really be sure what will happen tho unless a shop builds the motor and watches it turn so they can see whats happening.
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is online now   Reply With Quote
Old 08-15-2009   #3 (permalink)
speedfoos
Boosted.......bitch.
speedfoos's Avatar
speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned
If you are in doubt if the cam you buy will cause P2V, then you need to clay the pistons. Put a thin layer of clay on top of pistons, re-assemble the motor and head, carefully turn the motor over by one crank revolution, disassemble the motor and look for marks in the clay.
__________________
Quote:
Originally Posted by LogicWavelength
This thread (T.E.A.R.S.) was inspired by speedfoos. We all know about his very public and very obscene battle against his car's engine.
There's a good chance that I'm not going to answer your PM.
The Foos' 383 Stroker (and everything else) Thread....(clickme)
T.E.A.R.S. Crew Member #2
My terbow shopping list and tips thread
www.7thgenhonda.com
speedfoos is offline   Reply With Quote
Old 08-15-2009   #4 (permalink)
gearbox
Super Moderator
hey thats a great idea
__________________
www.lubecontrol.com
Member 1025782
Old 08-16-2009   #5 (permalink)
Running Riot
Senior Member
just any kind of clay?
__________________
Old 08-17-2009   #6 (permalink)
speedfoos
speedfoos's Avatar
You just need something that will take the indentation of the valve and hold the mark until you pull the motor apart to see what's what. Regular old modeling clay will work just fine.
__________________
www.7thgenhonda.com
Old 08-18-2009   #7 (permalink)
Running Riot
Senior Member
well i got a quote from a local speed shop here, if i bring them the parts they can assemble it for me and do the machine work etc 750 for labor. Now my initial estimate of bottom end parts ran me around 800 dollars if i use new h beams with srp forged pistons. If I use the stock rods then its around 400. So that got be thinking if i should just use nippon pistons, but then i found this....
Short blocks include, bore and power hone to the next size over stock, resurfacing the deck, hot tanking the engine, ACL bearings, micro polished crankshaft, CP forged pistons, JGE 4340 H beam rods & professional assembly. $1900.00. (new oil pump extra)
i mean its like an extra 600 plus shipping but they include all the parts i was going to use anyways and they machine the crank. I mean it may be a little bit more than I need don't you think for just an ordinary daily NA weekend racer?
__________________
Tags
2000 , adjustment , adjustments , cams , civic , clearance , clearances , ctr , honda , pro , pro1 , si , skunk2 , type , valve
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Looking for a 7th gen manual for free? (UPDATED!!!)
ALL of Grey's DIY's...
DIY: Trunk Shocks
Detailed smoked out taillights DIY w/ pictures
Oil Changes
DIY: tricked out trunk
DIY: No More Trunk Rattle!
SOHC VTEC Explained
DIY: Grounding kit Install
Need help with Radio Code
Site Supporters
aluminum radiator
Honda car spoilers
