| Re: HELP ! These 11W High Power LEDs Burnt My Fuse Twice! led bulbs should not burn your relay, unless the leds suck (which is very possible since almost all those junk bulbs are made overseas). i have a LED flasher relay in mine even tho i dont have led signals YET. you can buy the one from auto stores made by tridon (same as oem brand) and its EP_34 i believe for the part number. it should say LED somewhere on the flasher. ive tried it and sure enough, the led bulb blinks at a normal speed with this flasher.
__________________
Restore Performance, Reduce Costs www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring. |
