Go Back   Honda Civic Forum > GENERAL > Honda Civic DIYs and Civic Tech Chat
Honda Civic DIYs and Civic Tech Chat Honda Civic DIYs and Civic Tech Chat - for the true gearheads! Bring your wrench, it's time for some Honda Civic DIY projects! Questions about problems with your car do NOT go here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 07-02-2009   #1 (permalink)
bachlava7
New Member
bachlava7 is an unknown quantity at this point
Fuel Pressure Gauge
So I'm going to install a fuel pressure gauge and as far as I can tell the best place is on the fuel line between the filter and the fuel rail. I think that if I could attach some special fitting at either end that would be best. So my questions are, has anyone does this and what do they recommend? My pressure sender has a male 1/8 NPT fitting. And would anyone happen to know what size my banjo bolts are on my fuel line? I have a 98DX.
-bachlava7
bachlava7 is offline   Reply With Quote
Sponsored Links
Old 07-02-2009   #2 (permalink)
Running Riot
Senior Member
Running Riot's Avatar
Running Riot will become famous soon enough
Send a message via AIM to Running Riot
Re: Fuel Pressure Gauge
Quote:
-bachlava7
if using a stock fuel rail, the top of the filter would be your best bet. If you can find an -AN fitting to go between the fuel feed line and the rail would be a good choice. I am using a BDL fuel rail that already came tapped for nitrous and fuel gauges. Mine is mounted next to the FPR
__________________
B16 10.4:1 JDM Pistons ITR Manifold 70.2mm Throttle Body Skunk2 Stage 1 Pro Cams AEM FPR DC Header Magnaflow Custom 2.5" exhaust BDL Fuel Rail Nology Individually Grounded Wires Fidanza 7.5lb Flywheel Exedy Clutch Goodridge Braided Steel Clutch Line Fidanza Short Shifter Skunk2 knob JUN Chip
IM SO JDM I EVEN HAVE SARS
Running Riot is offline   Reply With Quote
Old 07-06-2009   #3 (permalink)
bachlava7
New Member
Cool thanks. I just found an adapter that replaces one of the banjo bolts, the banjo bolt at the fuel filter. How do I go about relieving the pressure of the fuel system in order to put this on? Thanks.
Old 07-07-2009   #4 (permalink)
Running Riot
Senior Member
with the car running, remove the fuse for the fuel pump until the car dies, then remove the fuel cap, remove the hose that goes to the regulator from the fuel system and then slowly remove the bolt that goes to the fuel rail. Keep a rag and a fire extinguisher handy especially if you smoke
__________________
Tags
18 , banjo , bolt , civic , diy , filter , fitiing , fuel , gauge , honda , install , npt , pressure , rail , thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Looking for a 7th gen manual for free? (UPDATED!!!)
ALL of Grey's DIY's...
DIY: Trunk Shocks
Oil Changes
Detailed smoked out taillights DIY w/ pictures
DIY: tricked out trunk
DIY: No More Trunk Rattle!
SOHC VTEC Explained
DIY: Grounding kit Install
Ask Me About DIY Stuff V2!
Site Supporters
aluminum radiator
Honda car spoilers
