Go Back   Honda Civic Forum > GENERAL > Honda Civic DIYs and Civic Tech Chat
Honda Civic DIYs and Civic Tech Chat Honda Civic DIYs and Civic Tech Chat - for the true gearheads! Bring your wrench, it's time for some Honda Civic DIY projects! Questions about problems with your car do NOT go here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 06-29-2009   #1 (permalink)
gorylewis
New Member
gorylewis is an unknown quantity at this point
Oil Leak Help Needed
I have an 89 Honda Civic Si.
I have taken some pictures of where the oil is leaking from. Could someone please help me identify where they think the problem might be coming from. Any help would be great.
Also today I replaced the o-ring for the distributor with an oem ring from Honda.
Greg
ID:	76786   Click image for larger version
ID:	76787   Click image for larger version
gorylewis is offline   Reply With Quote
Sponsored Links
Old 06-30-2009   #2 (permalink)
Running Riot
Senior Member
Running Riot's Avatar
Running Riot will become famous soon enough
Send a message via AIM to Running Riot
Re: Oil Leak Help Needed
Looks like CV axle seals. 3 or 4 bucks from the dealer, multiply that times 100 for installation.... unless you do it yourself. Get ready for lots of fluid spillage tho... look on the bright side, at least you won't have to take out the drain plug from the gearbox for your MTF fill.
__________________
B16 10.4:1 JDM Pistons ITR Manifold 70.2mm Throttle Body Skunk2 Stage 1 Pro Cams AEM FPR DC Header Magnaflow Custom 2.5" exhaust BDL Fuel Rail Nology Individually Grounded Wires Fidanza 7.5lb Flywheel Exedy Clutch Goodridge Braided Steel Clutch Line Fidanza Short Shifter Skunk2 knob JUN Chip
IM SO JDM I EVEN HAVE SARS
Running Riot is offline   Reply With Quote
Tags
15 , 2001 , axle , civic , honda , leak , oil , pics
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Looking for a 7th gen manual for free? (UPDATED!!!)
ALL of Grey's DIY's...
DIY: Trunk Shocks
Detailed smoked out taillights DIY w/ pictures
Oil Changes
DIY: tricked out trunk
DIY: No More Trunk Rattle!
SOHC VTEC Explained
DIY: Grounding kit Install
Need help with Radio Code
Site Supporters
aluminum radiator
Honda car spoilers
