Go Back   Honda Civic Forum > GENERAL > Honda Civic DIYs and Civic Tech Chat
Honda Civic DIYs and Civic Tech Chat Honda Civic DIYs and Civic Tech Chat - for the true gearheads! Bring your wrench, it's time for some Honda Civic DIY projects! Questions about problems with your car do NOT go here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 01-11-2009   #1 (permalink)
new_2_civics
New Member
new_2_civics's Avatar
new_2_civics is an unknown quantity at this point
this is more of a dvd player problem than it is a civic problem but...
since its being installed in a 93 civic maybe you can help me! i recently bought the Pyle PLD3MU 3" In-Dash DVD Receiver w/ Monitor, you can learn about it here.
http://pyleaudio.com/itemdetail.asp?...s&model=PLD3MU
and heres a link to the online manual.
http://pyleaudio.com/manuals/PLD3MU.pdf
when i put a dvd into the dvd player it says, "warning: for your saftey dont watch while driving"... so i sent pyle audio an email asking them why it says that. and they sent me an email back saying, "This unit was not designed to be used while the car is in motion. Your parking brake must be in the engaged position in order to view the monitor. The brake wire must be hooked up to the parking brake wire or grounded in order for this function to work properly."
now my question is this, shouldnt there be a way to make the dvd player "think" my e-brake is on? i tryed hooking up a toggle switch to the brake wire on the dvd player, and it still says i cant watch dvds!!!
and im out of ideas, so if anyone can help me i'd appreciate it
-thanks in advance
new_2_civics is offline   Reply With Quote
Sponsored Links
Old 01-11-2009   #2 (permalink)
MidnightCivic
MidnightCivic's Avatar
MidnightCivic is a glorious beacon of light MidnightCivic is a glorious beacon of light MidnightCivic is a glorious beacon of light MidnightCivic is a glorious beacon of light MidnightCivic is a glorious beacon of light MidnightCivic is a glorious beacon of light
Send a message via Yahoo to MidnightCivic
Re: this is more of a dvd player problem than it is a civic problem but...
Ground the parking brake wire and your good to go..dont wire it to the parking brake..
__________________
Current Mods
• DIY BOH • Progress Rear Sway
• Yellow Fogs • Altezza Grill
• 16 red/black te37 replicas • ep3 side markers
• Hayame Cat Back • K&N fipk intake
• D2's • 04 Smoked Taillights
• Cf Hood • Neuspeed Strut Bar
• Aero Sides • Oem Rear Lip
• Type B Front Lip • D3S Retro Headlights
Future Mods
• CF Trunk
MidnightCivic is offline   Reply With Quote
Old 01-11-2009   #3 (permalink)
WannaBFast
Prowlin' with a Purpose
WannaBFast's Avatar
WannaBFast will become famous soon enough WannaBFast will become famous soon enough
Send a message via AIM to WannaBFast
wut he ^ said
__________________
01 ES2, if you dont know what that is.. SEARCH
78 X1/9, if you dont know what that is.. i dont blame you
Honda Trained Technician
Project 5lug: Coming Soon
WannaBFast is offline   Reply With Quote
Old 01-11-2009   #4 (permalink)
new_2_civics
New Member
how do i ground it tho? just hook the e-brake wire up to a piece of metal? or hook up a toggle switch with only the e-brake wire and a ground wire?
Old 01-11-2009   #5 (permalink)
lordhelmet
Platinum Member
lordhelmet's Avatar
lordhelmet should not be questioned lordhelmet should not be questioned lordhelmet should not be questioned lordhelmet should not be questioned lordhelmet should not be questioned lordhelmet should not be questioned lordhelmet should not be questioned lordhelmet should not be questioned lordhelmet should not be questioned lordhelmet should not be questioned lordhelmet should not be questioned
Send a message via AIM to lordhelmet
What was the toggle switch connected to when you first tried this?
lordhelmet is offline   Reply With Quote
Old 01-12-2009   #6 (permalink)
new_2_civics
New Member
i had it installed to the power wire from the dvd player, and grounded out to a screw in the middle console. with the e-brake wire from the dvd player hooked to the "accessory" prong on the toggle switch... even when i un hooked the power wire from the toggle switch, it would still turn the toggle switch on...
Old 01-12-2009   #7 (permalink)
WannaBFast
WannaBFast's Avatar
well take the wire going to the parking brake switch, disconnect it, and strip the end.. loosen a bolt on the parking brake lever assembly, wrap the wire around bolt, tighten up.. there grounded done
__________________
Tags
dvd , player , pld3mu , problem , pyle
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Looking for a 7th gen manual for free? (UPDATED!!!)
ALL of Grey's DIY's...
DIY: Trunk Shocks
Detailed smoked out taillights DIY w/ pictures
Oil Changes
DIY: tricked out trunk
DIY: No More Trunk Rattle!
SOHC VTEC Explained
DIY: Grounding kit Install
Need help with Radio Code
Site Supporters
aluminum radiator
Honda car spoilers
