Go Back   Honda Civic Forum > GENERAL > Honda Civic DIYs and Civic Tech Chat
Honda Civic DIYs and Civic Tech Chat Honda Civic DIYs and Civic Tech Chat - for the true gearheads! Bring your wrench, it's time for some Honda Civic DIY projects! Questions about problems with your car do NOT go here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 06-23-2009   #61 (permalink)
agentfouser
New Member
agentfouser is an unknown quantity at this point
Re: The ultimate Intake FAQ – Intake questions and answers here!!!
sorry for the noob question, but it's kind of the opposite issue from the rest of the posts here. my 95 civic came with an aftermarket air intake, but i've now discovered that it's illegal and won't pass smog here in california. so, since i don't have the money or the burning desire to invest in a new intake that will pass, i've bought a used stock intake to put in. however, i can't find any instructions on how to replace a stock air intake. it looks pretty straightforward, but if anyone has any suggestions, tips, or websites with pictures it would be much appreciated. To remove this ad, register today for free or log in if already registered!
agentfouser is offline   Reply With Quote
Sponsored Links
Old 06-23-2009   #62 (permalink)
TRIZ
Hey! Look At Me!! I'm a Supporting Member!!Administrator
TRIZ's Avatar
TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of
Send a message via AIM to TRIZ
I would just look up instructions on how to put an aftermarket intake on, and do it in reverse. Simple as that.
TRIZ is offline   Reply With Quote
Old 06-27-2009   #63 (permalink)
kailicious
New Member
kailicious is an unknown quantity at this point
another very very noob question here.
soooo sorry... im really new at this modification thingy. i dont know a thing bout it. as in nothing. the only thing i have put on is my 4-2-1 headers... anyway...
i drive a 2000 vti civic automatic. i told 2 of my friend at separate occasions that i want a cold air intake installed. i got a common response. they looked at me then laughed. i remember one of them saying that i should do it only if i would like my headlights go "blind"
whats up with that?
kailicious is offline   Reply With Quote
Old 06-27-2009   #64 (permalink)
TRIZ
TRIZ's Avatar
I dunno what your friends are thinking, they sound lame- they dont really sound like friends at all. But anyways, a lot of times ppl will pull a headlight out and route their intake through the opening to get the incoming "cold" air while driving. This is totally custom, no kits that I'm aware of come like this. Doing this would make you lose a headlight, and in turn, make your headlight go blind? Thats all I got.
Old 07-01-2009   #65 (permalink)
loki7714
New Member
loki7714 is an unknown quantity at this point
Quick question will these three parts work together?
Honda 96-00 Civic (DX/LX/CX) Weapon-R Secret Weapon Intake System
http://www.weaponspeed.com/Honda-96-...g-p-16886.html
Airaid Poweraid throttle body
http://www.autoanything.com/air-inta...0A3112523.aspx
Bbk throttle body
http://www.autoanything.com/air-inta...0A3137611.aspx
I have a 98 Honda Civic DX. Thanks!!!
loki7714 is offline   Reply With Quote
Old 07-01-2009   #66 (permalink)
TRIZ
TRIZ's Avatar
The intake and the TBS (throttle body spacer) will work together- I'm not famil enough with that throttle body to give you an answer- I've never heard of it acutally. If it bolts to the stock intake manifold then it will work with everything. You might need to find another rubber pipe connector to fit your intake to the throttle body but those are easy to find online if not locally. You might run into a snugger fitment of the intake with the TBS but it should still work. With your engine, the whole intake will move away from the throttle body by the thickness of the TBS. Get it?
Old 07-02-2009   #67 (permalink)
loki7714
New Member
I think so. Thank you very much ill look into it. But it would prob be easier to install the new throttle body and the spacer together right? And what is the difference between the slightly bigger and slightly smaller throttle body? Is there another type you'd recommend... feel free to ignore these questions i know im asking a lot.
Old 07-02-2009   #68 (permalink)
TRIZ
TRIZ's Avatar
Its all good bro.
A bigger throttle body will allow more air into your intake manifold and consequently into your motor. More air = more fuel, which equals more power. Obviously there is a max size where the benefits top out and the bigger your push the TB size beyond this point you'll start hurting your motors performance (You'd have to do some flowbench testing to find out the exact maxout point, but that really wont be an issue unless you plan on fully race prepping the ish outta your car an running slicks and all that seriousish). A smaller TB will make it harder for your engine to breath (its like you trying to breath through a straw vs a snorkel)
Easiest way to install those parts would be to put them on at the same time since you have to pull the TB to install the spacer anyways.
Old 07-19-2009   #69 (permalink)
KurtyG123
New Member
KurtyG123 is an unknown quantity at this point
Send a message via AIM to KurtyG123
good thread. sorry i didnt read it before i posted my thread about it
KurtyG123 is offline   Reply With Quote
Old 08-02-2009   #70 (permalink)
ursalog
New Member
ursalog is an unknown quantity at this point
Is getting a new intake manifold worth the cash over stock if not planning to turbo? Edelbrock Performer X Intake Manifold to be more specific, also if it is is it applicable on a 2001 hoda civic ex 2dr? i'm on procivic.com looking at it and i set up all my settings on the side its supposed to remove the parts that arenat compatible and there are two options left for me that read Universal (B16A2/A3, B18C5 Engine Swaps Only, Natural Finish) Edelbrock Performer X Intake Manifold and Universal (B18C/C1 Engine Swaps Only, Natural Finish) Edelbrock Performer X Intake Manifold, now i know my civic has a D17A2 sooo end my confusion/ignorance please
ursalog is offline   Reply With Quote
Old 08-03-2009   #71 (permalink)
TRIZ
TRIZ's Avatar
Wont work. Those are for the B series, they never released one for the D17. Really the only reason to upgrade the intake manifold is if your going to boost it and dont want to crack your mani from the increased pressure. Thats why the boost guys do it.
Now if your not going to boost it, then the only reason to swap your intake mani is for the bling factor (I think there is one on ebay thats generic as shit but looks pretty bling). OR if your going to do a full out build on the motor and want to squeeze ever last HP outta it.
Old 1 Week Ago   #72 (permalink)
succiphud
New Member
succiphud is an unknown quantity at this point
Anudder question, would anything change if i told u the car was automatic/standard? like are there differences?
Some intake manufactures will have two different models- one of auto and one for manual, the reason is because the transmission is slightly a different size, and therefore the path the pipe takes is affected. That holds true for CAI, but for short rams, I have yet to see a specivic between auto and manual. If the intake your looking at is differentiated between auto or manual, get the proper model for your transmission.
______________
Calcul taux d'interet immobilier meilleur banque | Taux d interets legal emprunt actuel | Calcul taux d'interet immobilier
succiphud is offline   Reply With Quote
Tags
30 , aem , end , faq , gas , improved , intake , milage , mock , pipe , questions , ram , removal , short , stock , trash , vtec
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Looking for a 7th gen manual for free? (UPDATED!!!)
ALL of Grey's DIY's...
DIY: Trunk Shocks
Detailed smoked out taillights DIY w/ pictures
Oil Changes
DIY: tricked out trunk
DIY: No More Trunk Rattle!
SOHC VTEC Explained
DIY: Grounding kit Install
Need help with Radio Code
Site Supporters
aluminum radiator
Honda car spoilers
