Go Back   Honda Civic Forum > GENERAL > Honda Civic DIYs and Civic Tech Chat
Reload this Page
Foos Catchcan DIY
Honda Civic DIYs and Civic Tech Chat Honda Civic DIYs and Civic Tech Chat - for the true gearheads! Bring your wrench, it's time for some Honda Civic DIY projects! Questions about problems with your car do NOT go here.
LinkBack Thread Tools
Old 08-29-2008   #1 (permalink)
speedfoos
Boosted.......bitch.
speedfoos's Avatar
speedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questioned
Foos Catchcan DIY
Yeah. Everyone is making catchcans out of PVC pipe, Monster cans and everything else lately, so I though I would jump on the band wagon. I made two of these (one for me, one for ??) because it was fun, I had the idea, and wanted to see how it turned out. I like them! On to the DIY.
Tools required
- Drill
- Step-drill bit
- 1/4" NPT tap (optional, but nice)
- JB Weld
- 14mm and 16mm sockets
- box cutter
- some way of cutting plastic, I used a die grinder
Materials and price
- one Fake SIGG Aluminum drinking bottle $5
- one 1/4" NPT Ball valve - $2
- two 1/4" 90° push fittings - $2
- two 1/4" NPT hose barb - $1
- one 1/4" NPT male-to-male adapter and nut - $1.50
- two 1/4" NPT to -6AN fittings - $6
- breather filter - $8
- 6mm OD clear tubing - $.25
Total Materials price = $25.25 - This is more expensive than you would pay in the states because I live in England (for now) and everything is stupid expensive here.
On to the DIY, this was really easy, but I like DIYs. Here's all of the parts I used, except for the tubing and the NPT nut. This is for a vented catchcan setup that does not/not plumb back into an intake source. If you want to run this as an air/liquid separator in a positive vacuum evac setup, you have to remove the breather filter and plug the hole.
The bottle
Ball valve, joiner and NPT hose barb
90° push in fittings (for the sight line)
First thing you want to do is connect the male-to-male joiner, ball valve and hose barb together. Just grab a 14mm socket or wrench and tighten them down and it will look like this.
Now grab your die grinder and cut the little ring off the bottle cap so it's flat. like so:
Attach the step drill bit to your drill and make the hole in the cap for the ball valve to connect to. Make the hole a touch on the small side because your tap will make it the right size for the ball valve.
Thread the ball valve assembly on to the cap and use the 1/4" NPT nut on the back side of the cap to secure it. If you don't have a 1/4" NPT tap, just take your time with the hole and don't make it too big. Your fitting will be stronger than plastic, so if it's too small, you can still run it down. Even if it's too big, that's OK for this step because of the nut on the other side.
Grab your drill and drill two holes in line with each other at the top and bottom of the can for the sight line. If you don't have the NPT tap, hole size is important here. You can always make the hole bigger, not smaller.
Done.
Thread the push-fittings in to the holes and cut the clear tubing to the appropriate length. Then, just push the tubing into each of the fittings like so:
Drill another hole in the top of the can for your breather filter and run your other 1/4" NPT hose barb into it.
Drill two more holes for your NPT-to-AN fittings. I put them on the side as that looked the best. Tap the holes and run the fittings in. Again, if you don't have a tap, just make the holes a little small and let the fittings tap themselves.
If you decide to run this catchcan into a pre throttle body vacuum source, I set it up so you minimize the risk of sucking the crappy liquid into the intake and you only get the gassy (combustible) vapors. I ran a 6mm ID line off the bottom fitting - to be used as the inlet of the can - so it goes to the bottom part of the can also has some steel wool in it. That line, plus the steel wool will help minimize the chance of any oily liquid getting into your intake charge. A vented can should have a pre-TB vac source otherwise the vent will allow too much air into the IM and create a vac leak. Here's the tube I was talking about.
And the finished product! The ball valve makes emptying the catchcan a lot easier, and what's even better is that you can mount this in your engine bay using a standard bicycle bottle cage! PM me if you want to buy this can pictured here for $35 shipped.
speedfoos is offline   Reply With Quote
Sponsored Links
Old 08-29-2008   #2 (permalink)
Eyger
A long winded 7th genr
Eyger should not be questionedEyger should not be questionedEyger should not be questionedEyger should not be questionedEyger should not be questionedEyger should not be questionedEyger should not be questionedEyger should not be questionedEyger should not be questionedEyger should not be questionedEyger should not be questioned
Re: Foos Catchcan DIY
Sweet. Blue should look nice in your bay.
Cool DIY.
Eyger is offline   Reply With Quote
Old 08-29-2008   #3 (permalink)
02BLKCIVIC
Official Rattlesnake Hunter
02BLKCIVIC's Avatar
well played sir.
02BLKCIVIC is offline   Reply With Quote
Old 08-29-2008   #4 (permalink)
speedfoos
speedfoos's Avatar
Thanks guys!
Old 08-29-2008   #5 (permalink)
LT2004ever
I wil fix vBPlaza today
LT2004ever's Avatar
in for pics of it installed.
nice diy clint
LT2004ever is offline   Reply With Quote
Old 08-29-2008   #6 (permalink)
2005EM2
I <3 MY EM2!
2005EM2's Avatar
2005EM2 should not be questioned2005EM2 should not be questioned2005EM2 should not be questioned2005EM2 should not be questioned2005EM2 should not be questioned2005EM2 should not be questioned2005EM2 should not be questioned2005EM2 should not be questioned2005EM2 should not be questioned2005EM2 should not be questioned2005EM2 should not be questioned
+1
Nice!
2005EM2 is offline   Reply With Quote
Old 08-30-2008   #7 (permalink)
DDragon7
Ultimate Member
DDragon7's Avatar
DDragon7 is just really niceDDragon7 is just really niceDDragon7 is just really niceDDragon7 is just really niceDDragon7 is just really nice
That's cool, but what does it do again?
DDragon7 is offline   Reply With Quote
Old 08-30-2008   #8 (permalink)
gearbox
Super Moderator
gearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant future
very nice diy, i like the valve for emptying it. it traps and condenses oil and other contaminants to keep them from going back in the engine.
gearbox is offline   Reply With Quote
Old 08-30-2008   #9 (permalink)
speedfoos
speedfoos's Avatar
Quote:
nice diy clint
Quote:
Originally Posted by 2005EM2 View Post
+1
Nice!
Thanks guys!
Quote:
Quote:
Yup!
Old 08-30-2008   #10 (permalink)
amexicancarguy
Member
amexicancarguy's Avatar
amexicancarguy is just really niceamexicancarguy is just really niceamexicancarguy is just really niceamexicancarguy is just really nice
wow nice DIY
amexicancarguy is offline   Reply With Quote
Old 08-30-2008   #11 (permalink)
FGCOUPE
Super Member
FGCOUPE's Avatar
FGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to all
definetly a nice DIY foos!
i still need to get myself one but i was thinking a little differently?
no breather filter, no valve, etc..?
instead, i was going to use a bottle like yourself, 90degree elbow, straight piece and steel scratch pads (stuffed into the bottle). Only thing different id have to do is empty this bottle once every oil change.
still....i like!
FGCOUPE is offline   Reply With Quote
Old 08-31-2008   #12 (permalink)
speedfoos
speedfoos's Avatar
The one that's going in my car doesn't have a filter because I run a closed evac setup and a filter would throw off the car's vacuum level. If you run an outlet off the catch can back to a large vac source (like the IM, turbo inlet, or your exhaust) you shouldn't run a filter. You get a better positive vacuum off the block by running a closed can.
However, if you are just running the PCV hose and breather hose off the VC into it, you should use a breather vent, otherwise you just transfer pressure through the can. Make sense?
There is steel wool stuffed in the bottom of this can, I just didn't take a pic of it. Plus the valve makes it a lot easier to drain the crap in the can. My current can just has a screw-in plug and that thing is damn messy and a pain in the ass.
Old 08-31-2008   #13 (permalink)
02fpcivic
Diamond Member
02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light
Guys just to note this, do not pressurize your catch cans/crank cases, ever. Make sure if you run a turbo, the can is either open breather style or tapped into the intake side of the turbo compressor. Any positive pressure in your crank case can ruin things like your turbo oil seals and just plain wreak havok on your whole setup. Positive crank pressure can lead to oiling problems that sometimes start out small with little to no symptoms and progressively get worse. Sometimes by the time you realize there is a problem its too late. Other times the hot side of your turbo will push oil out into the exhaust and cause plumes of grayish smoke. Crank evac is much more a critical factor than most realize.
PS, Clint that catch can is pretty damn creative, thumbs up!
02fpcivic is offline   Reply With Quote
Old 08-31-2008   #14 (permalink)
02fpcivic
Diamond Member
Oh BTW do not try to use the exhaust as a vac source for turbo cars either. We just tried this with the race car and at idle there was enough restriction to cause turbo drainage problems.
Old 08-31-2008   #15 (permalink)
speedfoos
speedfoos's Avatar
Good points Gerry, thanks for chiming in! As an FYI, most folks have seen this diagram, but if you're going to run a closed catchcan setup, I recommend this way (how mine is run). During off-boost, it pulls vac from the IM to suck the crankcase gases from the VC and crankcase. When boost kicks in, the IM line check valve closes and the evac setup goes out through the exhaust line.
That's my setup on a closed evac system with a non-filtered can.
If you were running the filtered can I made here, this is how you would run it.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Looking for a 7th gen manual for free? (UPDATED!!!)
ALL of Grey's DIY's...
DIY: Trunk Shocks
DIY: tricked out trunk
Oil Changes
DIY: No More Trunk Rattle!
SOHC VTEC Explained
Detailed smoked out taillights DIY w/ pictures
DIY: Grounding kit Install
E-Manage FAQ!!!!!!!!!
Site Supporters
aluminum radiator
Honda car spoilers
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
