Go Back   Honda Civic Forum > GENERAL > Honda Civic DIYs and Civic Tech Chat
Reload this Page
How to get axels back in?
Honda Civic DIYs and Civic Tech Chat Honda Civic DIYs and Civic Tech Chat - for the true gearheads! Bring your wrench, it's time for some Honda Civic DIY projects! Questions about problems with your car do NOT go here.
LinkBack Thread Tools
Old 08-25-2008   #16 (permalink)
Eyger
A long winded 7th genr
Eyger should not be questionedEyger should not be questionedEyger should not be questionedEyger should not be questionedEyger should not be questionedEyger should not be questionedEyger should not be questionedEyger should not be questionedEyger should not be questionedEyger should not be questionedEyger should not be questioned
Re: How to get axels back in?
Right right, what Im going to do it buy a little 5 dollar metal file and try to get it to fit, if not, then I'll just get a new axel, I don't have autozone around here, I've got Kragen, so Im hoping that they have it. If not, there's a napa here too, they might have something like that.
Eyger is offline   Reply With Quote
Old 08-25-2008   #17 (permalink)
Eyger
Quote:
Originally Posted by speedfoos View Post
Yeah man, use a file or a dremel on those splines. Shine a flashlight into the tranny case as well to see if the splines are all fubar'd on the tranny side as well.
ya, i didn't do that exactly, but I did try to use my finger and feel around inside there, it didn't feel like there was anything out of the ordinary.
I'll continue working on it after work today.
Old 08-25-2008   #18 (permalink)
khmer
New Member
khmer is an unknown quantity at this point
this happened to me also on the driver's side. I put everything back together and had it toed to axle specialist. It ended up costing me about $250 with brakes being adjusted also. I poped it in the first time, but when I adjusted it, it wouldn't go back in. I tried everything. I tried popping it neutral, 1st, reverse, rotating the passenger axle, etc. I ended up towing it. Good luck. Give a call to a mechanic and maybe they can give you some pointers over the phone.
khmer is offline   Reply With Quote
Old 08-26-2008   #19 (permalink)
Eyger
The file didn't work. so I took a dremel and just shaved it down in the grooves to make it work.
I finally figured out that the problem was that when the axles popped out the first time, the top set of teeth got torqued or whatever, so the channels didn't line up. So i just shaved down the top set of teeth to get it to fit back in.
Everything works, it's back in, thanks for the help on the axles!
Old 08-26-2008   #20 (permalink)
bomerman19
Senior Member
bomerman19 is a name known to allbomerman19 is a name known to allbomerman19 is a name known to allbomerman19 is a name known to allbomerman19 is a name known to allbomerman19 is a name known to allbomerman19 is a name known to all
sweet!
bomerman19 is offline   Reply With Quote
Old 08-26-2008   #21 (permalink)
greeen01civic4d
balls in ur mouth
greeen01civic4d's Avatar
good deal man, now go get urself a spare axle when u get the cash, cuz it will most likely go bad
greeen01civic4d is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Looking for a 7th gen manual for free? (UPDATED!!!)
ALL of Grey's DIY's...
DIY: Trunk Shocks
DIY: tricked out trunk
Oil Changes
DIY: No More Trunk Rattle!
SOHC VTEC Explained
Detailed smoked out taillights DIY w/ pictures
DIY: Grounding kit Install
E-Manage FAQ!!!!!!!!!
Site Supporters
aluminum radiator
Honda car spoilers
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
