Go Back   Honda Civic Forum > GENERAL > Honda Civic DIYs and Civic Tech Chat
Honda Civic DIYs and Civic Tech Chat Honda Civic DIYs and Civic Tech Chat - for the true gearheads! Bring your wrench, it's time for some Honda Civic DIY projects! Questions about problems with your car do NOT go here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 07-20-2004   #136 (permalink)
loki
Senior Member
loki's Avatar
loki is an unknown quantity at this point
Quote:
Originally Posted by Krepoort
Here's where you tap the RED wire from the new gauges to the existing wires. Notice the RED/BLACK wire on BLUE thing.
And this is where I grounded my gauges (the BLACK wire). The little orangish thing is a wire tap that you can buy it from any auto/hardware store.
HTH
i didn't see a red/black wire from the bule connector so i wired it with the red one. i'll try to look for it later but i have to take my car to work now. on, and is it ok that i grounded the black wire to one the the screws? also, how do i know if i messed up my needles? thanks a lot.
loki is offline   Reply With Quote
Sponsored Links
Old 07-20-2004   #137 (permalink)
zen_master
Ultimate Member
zen_master's Avatar
Send a message via AIM to zen_master Send a message via MSN to zen_master
where are the pics???????????
__________________
2003 Civic EX Sedan
zen_master is offline   Reply With Quote
Old 07-20-2004   #138 (permalink)
Krepoort
Krepoort's Avatar
Krepoort is an unknown quantity at this point
Send a message via AIM to Krepoort
Quote:
It shouldnt be hard to find the red/black wire. The red/black lets you turn on the gauges with the parking lights but the red wire (if I remember right) requires you to turn on the headlights before the gauges come on.
Its ok to ground the black wire to the screw as long as there is bare metal.
You can tell if your needles are messed if they just dont work.
__________________
Member's Ride My Pics
>>Selling OEM Sedan Tail Lights! PM me for details!<<
Krepoort is offline   Reply With Quote
Old 07-21-2004   #139 (permalink)
loki
Senior Member
loki's Avatar
got it to work. i just didn't see the red/black wire. needles are fine. thanks for the DIY.
Old 10-03-2004   #140 (permalink)
2slow2run
wut time is it now
2slow2run's Avatar
2slow2run is an unknown quantity at this point
Minor problems
um...i've did something to the needles.
i took it apart and bleach that sucker using clorox,409 and finally some of those oven cleaner... it work
side affect...needle not set to corect dial once is back in.
to fix it..turn on the car
rpm will jump to 1 when car is on temp is normal gas...u find out out much gas is in there..they say recommend u 2 fill it up 1st.
after ward just put the needle back where is suppost to b wit the car on.
my rpm is still a bit off but wth right
i got clear needles ...now ...imma try to do the stock face next and change all the bulbs to led
if it accidently take off everything aww daym..ill just have to buy indiglo then
ID:	39346   Click image for larger version
2slow2run is offline   Reply With Quote
Old 10-03-2004   #141 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
You know there's a diy done about this in the lighting forum. How do the needles look at night? Also, the needles should have been fine provided that you unplug the cluster, remove needles, put them back the exact resting position that you pulled em out, and them plug the connectors back in.
gearbox is online now   Reply With Quote
Old 10-04-2004   #142 (permalink)
2slow2run
wut time is it now
2slow2run's Avatar
the needle went kr8zy on me lol
the rpm was at 3 the mhz was at 40mph
the gas was full witch wasnt suppost to
the temper was daym hot as sybarian desert lol
isnt there a ezier way to buy converted bulb iinstead of doin it urself?
Old 10-04-2004   #143 (permalink)
2slow2run
wut time is it now
2slow2run's Avatar
i saw the other guy it it by smashing all the way thru to the guage using glue and
it look like drill holes n lots of wire..it was 2 complicated to do cuz i dont noe where to buy 30ft of el wire
Old 10-09-2004   #144 (permalink)
2slow2run
wut time is it now
2slow2run's Avatar
yes the original face CAN b removed
i took mines out and clear out the red filter on the back..
i convert all the bulbs in the back of the guage into LED..
mg its tight but 1 screw up
i accidently rub off the place where the engine check light n stuff on the left side
so now the pic of those r gone..i can only tell by the light..look for me and ill send a pic
the pic shown is when i put in the key n on 2nd click after i took out the needle
Old 10-09-2004   #145 (permalink)
gearbox
Super Moderator
sweet. yeah don't worry about those lights. I ended up covering some with electrical tape and stuff anyway.
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
Old 10-09-2004   #146 (permalink)
2slow2run
wut time is it now
2slow2run's Avatar
hey gearbox...thankx for the diy intrumental man really appreciated
now im hella happy
ID:	40567   Click image for larger version
ID:	40568   Click image for larger version
ID:	40569   Click image for larger version
ID:	40570   Click image for larger version
ID:	40572   Click image for larger version
ID:	40573   Click image for larger version
ID:	40574   Click image for larger version
Old 10-09-2004   #147 (permalink)
2slow2run
wut time is it now
2slow2run's Avatar
N i thought i was kr8zy enought to conver diff light colors interior but daym yall even kr8zier then me
Old 10-09-2004   #148 (permalink)
2slow2run
wut time is it now
2slow2run's Avatar
Old 10-09-2004   #149 (permalink)
gearbox
Super Moderator
Looks good. Got any night shots? Also, did you add leds under the needles to make it brighter?
__________________
www.lubecontrol.com
Member 1025782
Old 10-09-2004   #150 (permalink)
2slow2run
wut time is it now
2slow2run's Avatar
yea heres the night shot...ill probably do the need nexts week..i dont have the right tools for it yet N i dont wanna end up drill'n everything up in there
if u notice on the temp pod..theres a triangle look'n thing..it was there AFTER i rubbed off the back..on top of that theres a check engine, oil thing n stuff
its gone...so all u c its red lights
N y is my kodak cx6330 so blurry? i clean the lens wit a cotton swab.cuetip watever that called that plastic stick wit cotton edges on both ends
ID:	40579   Click image for larger version
ID:	40580   Click image for larger version
ID:	40581   Click image for larger version
Tags
04 , 2001 , 96 , black , civic , clockwise , counter , diy , gauges , guages , honda , indiglo , kmh , reverse , wire
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Looking for a 7th gen manual for free? (UPDATED!!!)
ALL of Grey's DIY's...
DIY: Trunk Shocks
Detailed smoked out taillights DIY w/ pictures
Oil Changes
DIY: tricked out trunk
DIY: No More Trunk Rattle!
SOHC VTEC Explained
DIY: Grounding kit Install
Need help with Radio Code
Site Supporters
aluminum radiator
Honda car spoilers
