Go Back   Honda Civic Forum > GENERAL > Honda Civic DIYs and Civic Tech Chat
Honda Civic DIYs and Civic Tech Chat Honda Civic DIYs and Civic Tech Chat - for the true gearheads! Bring your wrench, it's time for some Honda Civic DIY projects! Questions about problems with your car do NOT go here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 11-28-2007   #31 (permalink)
ultimatetuner10
Technical Assistant
ultimatetuner10's Avatar
ultimatetuner10 should not be questioned ultimatetuner10 should not be questioned ultimatetuner10 should not be questioned ultimatetuner10 should not be questioned ultimatetuner10 should not be questioned ultimatetuner10 should not be questioned ultimatetuner10 should not be questioned ultimatetuner10 should not be questioned ultimatetuner10 should not be questioned ultimatetuner10 should not be questioned ultimatetuner10 should not be questioned
Send a message via AIM to ultimatetuner10
Re: The ultimate DX/LX header/exhaust FAQ
by the way the link doesnt work for the o2 extenders...i need my wires extendedd cause im doing a swap and need to know if i can splice and extend or if i have to get aftermarket extenders To remove this ad, register today for free or log in if already registered!
__________________
If you drive rice, dont expect me to be nice
http://img91.imageshack.us/img91/603...5792di1rh8.jpg
Slow down, save a life, buy a honda!
BRING BACK THE STORE!! Contests, prizes, and more!! Sign up
Marketplace tips from your very own
ultimatetuner10 is offline   Reply With Quote
Sponsored Links
Old 11-28-2007   #32 (permalink)
Lord ET
Senior Member
Lord ET's Avatar
Lord ET is a glorious beacon of light Lord ET is a glorious beacon of light Lord ET is a glorious beacon of light Lord ET is a glorious beacon of light Lord ET is a glorious beacon of light
just splice the wires...or cut them and solder on a longer length of wire between the two ends. It works well for me.
Lord ET is offline   Reply With Quote
Old 11-29-2007   #33 (permalink)
ultimatetuner10
Technical Assistant
TRIZ here is defouler info
DIY Mechanical O2 simulator
not done by me
__________________
Old 12-26-2007   #34 (permalink)
briand17a2
Member
briand17a2's Avatar
briand17a2 has a spectacular aura about briand17a2 has a spectacular aura about
Quote:
Originally Posted by speedfoos View Post
Easiest way to do this, like Triz said, is buy an EX header and catback exhaust.
Then go to Summit Racing and buy 2-1/4" inlet/outlet Magnaflow hi-flow cat. It's a real cat (not a test pipe), is OBD-2A compliant and costs $70. While you're there, buy a 4' length of 2-1/4" pipe ($10-12) and a 2-1/4" formed flange for $5 (P/N: WLK-31885) .
We're at $85 plus shipping right now.
Then head over to Mandrel Bending Solutions Ebay store (Click this), buy these items:
1 piece of 2-1/4" U-bend pipe - $12
1 three-bolt 2-14" flange - $4.25
1 two-bolt and 1 three-bolt gasket - $6 ($3/each)
1 oxygen sensor bung for your post cat sensor -$4
1 L-shaped hanger - $1.76
That's $33 plus shipping from Mandrel Bend Solutions. The whole new, truly 2-1/4" downpipe and real high-flow cat has just cost you $120 plus shipping for the parts. You will reuse those spring bolts already on your car.
Now take your new EX header, catback system, and box of exhaust parts to the nearest non-chain muffler shop. Point to the box of parts and the car and say, "I want all this stuff on my car, and I want all the stuff that's currently on my car put in these boxes. I'll be back in two hours, here's $150."
Go stuff some food down your gullet, have a beer, and then come back to your brand new, tits sounding exhaust.
I'll get your pics in a second Triz. I'm pissed off at the car and don't feel like going outside right now.
Verrry nizzze! Props to foos for the exhaust system list & mandrel bender vender. Didnt see this till today, bad ass.
FYI, if no one else has tried fitting a "D16" turbo header to their D17 exhaust port, DONT. For the 2 headers...the bottom three fasteners are in the same place, but the D16 header takes 4 upper fasteners...the D17 only has 2 up top, and the D17 studs go exactly in between the inboard/outboard fasteners on a D16 header. Sigh, i suppose this is why you look at what your buying before trusting Mr. Ebay partseller's helpful application info...
FYI #2...My stock EX header had a bunch of weld slag and other whatnot immediately downstream of the flange. I ground it out, polished as much of each primary as I could, flushed with carb cleaner, compressed air, and reinstalled it. Made zero difference .
So now I've got two minor worries.
1) Less metal means less strength. Been driving like this for a month now, no cracked stock header, good times.
2) After grinding away at my stock manifold, I read on pg 119 of Corky Bell's Maximum Boost that "Reversal of the exhaust gas flow back into the combustion chamber during valve overlap is called reversion. Creating an aerodynamic barrier that reduces the reverse flow yet does not impede outward-flowing gases can pay dividends in performance."
If that weld bead i decided to grind out was supposed to be an "anti-reversion orifice", its now effectively removed. I haven't really felt any decrease in power, but prior to this pointless mod, i was putting 98.1whp to the ground...dont know if I would notice a small percentage change anyway.
Summary: D16 header DOES NOT FIT D17 w/o modification the top of flange...cost of modification (welding, grinding, then decking the surface) probably justifies buying the more expensive, properly fitting D17 manifold. D16 header fit tested. Fail = very yes.
PS, Herr Bell's book on turbocharging ist die Scheiße on der Engineering tip, yo.
__________________
briand17a2 is offline   Reply With Quote
Old 12-26-2007   #35 (permalink)
speedfoos
Boosted.......bitch.
speedfoos's Avatar
speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned
Und jetzt du hast die lichter sehen!
__________________
Quote:
Originally Posted by LogicWavelength
This thread (T.E.A.R.S.) was inspired by speedfoos. We all know about his very public and very obscene battle against his car's engine.
There's a good chance that I'm not going to answer your PM.
The Foos' 383 Stroker (and everything else) Thread....(clickme)
T.E.A.R.S. Crew Member #2
My terbow shopping list and tips thread
www.7thgenhonda.com
speedfoos is offline   Reply With Quote
Old 01-11-2008   #36 (permalink)
TRIZ
Hey! Look At Me!! I'm a Supporting Member!!Administrator
TRIZ's Avatar
TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of
Send a message via AIM to TRIZ
Bump for update: defouler info added.
TRIZ is offline   Reply With Quote
Old 01-11-2008   #37 (permalink)
greeen01civic4d
balls in ur mouth
greeen01civic4d's Avatar
greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold
u go girl!!!
seriously tho, its good information, people need to search more!!! Thanks Triz
__________________
signature courtesy of speedfoos(Thanks Clint)
go here for 7thgen resource
greeen01civic4d is offline   Reply With Quote
Old 01-11-2008   #38 (permalink)
TRIZ
TRIZ's Avatar
^ Thanks, no problem man.
Any additional information anyone wants added, let me know, I'm sure I forgot something.
Old 01-11-2008   #39 (permalink)
greeen01civic4d
balls in ur mouth
someone should make bent o2 simulators, since sometimes the sensor doesnt clear the block, its what im running with my kamikaze
__________________
Old 01-11-2008   #40 (permalink)
TRIZ
TRIZ's Avatar
There are bent O2 simulators out.
Old 01-11-2008   #41 (permalink)
greeen01civic4d
balls in ur mouth
a bent non-fouler, i got one from a member here, i could get u a pic if u wanted, it was really good quality
__________________
Old 01-12-2008   #42 (permalink)
TRIZ
TRIZ's Avatar
Write something on the difference between non foulders / defoulers and 02 simulators for me.
Old 01-28-2008   #43 (permalink)
speedfoos
speedfoos's Avatar
Just as a little FYI. Three-inch exhaust tubing will fit on a Honda Civic.
__________________
www.7thgenhonda.com
Old 09-08-2008   #44 (permalink)
ProjectMayhemR
Senior Member
ProjectMayhemR will become famous soon enough
This might be a stupid question but here it goes. The flange on the megan header has smaller holes than their resonator pipe. How do i bolt them together? Has anyone else had this problem?
__________________
maturity is overrated
ProjectMayhemR is offline   Reply With Quote
Old 09-08-2008   #45 (permalink)
TRIZ
TRIZ's Avatar
Do the holes match up? If so, just use bolts that fit in the smaller holes and yeah, they will be a little lose in the bigger holes, but if they match up then everyhting should be all good.
Tags
2003 , ac , cat , catback , civic , dx , headers , headers2002 , honda , install , lx , meagan , megan , racing , random , tech
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Looking for a 7th gen manual for free? (UPDATED!!!)
ALL of Grey's DIY's...
DIY: Trunk Shocks
Detailed smoked out taillights DIY w/ pictures
Oil Changes
DIY: tricked out trunk
DIY: No More Trunk Rattle!
SOHC VTEC Explained
DIY: Grounding kit Install
Need help with Radio Code
Site Supporters
aluminum radiator
Honda car spoilers
