Go Back   Honda Civic Forum > GENERAL > Honda Civic DIYs and Civic Tech Chat
Honda Civic DIYs and Civic Tech Chat Honda Civic DIYs and Civic Tech Chat - for the true gearheads! Bring your wrench, it's time for some Honda Civic DIY projects! Questions about problems with your car do NOT go here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 09-14-2009   #256 (permalink)
speedfoos
Boosted.......bitch.
speedfoos's Avatar
speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned
Re: The ultimate DX/LX header/exhaust FAQ
All cats typically have an arrow indicating direction of flow. If they don't have that arrow, then it doesn't matter. To remove this ad, register today for free or log in if already registered!
__________________
Quote:
Originally Posted by LogicWavelength
This thread (T.E.A.R.S.) was inspired by speedfoos. We all know about his very public and very obscene battle against his car's engine.
There's a good chance that I'm not going to answer your PM.
The Foos' 383 Stroker (and everything else) Thread....(clickme)
T.E.A.R.S. Crew Member #2
My terbow shopping list and tips thread
www.7thgenhonda.com
speedfoos is offline   Reply With Quote
Sponsored Links
Old 09-14-2009   #257 (permalink)
madAd
Member
madAd's Avatar
madAd is an unknown quantity at this point
I was wondering, since I just put that race header on my car, would it make sense at all if I got a high-flow cat and got pipe and flanges welded on it so I could bolt it in place of my resonator on my DC exhaust? Or should it be near the front of the vehicle for some reason? Or would my car be even louder without the resonator?
madAd is offline   Reply With Quote
Old 09-15-2009   #258 (permalink)
TRIZ
Hey! Look At Me!! I'm a Supporting Member!!Administrator
TRIZ's Avatar
TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of
Send a message via AIM to TRIZ
Quote:
Its typically near the front of the vehicle closer to the engine is because its easier for the wires to reach where they need to go. If you put it back 3/4ths of the way where your resonator is, then you would have to run longer wires for your O2 sensors... a pretty easy fix. It owuld be a good idea to have a cat you can bolt in place like that.
TRIZ is offline   Reply With Quote
Old 09-15-2009   #259 (permalink)
TRIZ
TRIZ's Avatar
Quote:
Originally Posted by Cleft_Asunder View Post
Okay, I understand most of it now, thanks. But I'm wondering about the DX/LX exhaust past the down pipe. Is the pipe ID different from the EX? Is that what you mean by "keeping the stock exhaust for whatever reason," because ideally I would want an EX mid pipe and muffler? Or is the mid pipe and muffler on the EX the same ID and same specs as the DX/LX?
There's a guy selling a 1-piece 4-2-1 DC header for 120 in town. Is that a good deal? I wonder if it will line up on the 6th gens unlike the 7th gens. Then all I would need to do is shorten the mid pipe for the cat. I also found a stock EX setup on ebay starting at 20 dollars, so I may just go with that.
Oh and I also wanted to ask, can a cat be installed both ways, or is there a front and back?
Well whats the point of upgrading a header if your not going to upgrade the rest of the exhaust? I"m not sure about the ID diam of your civic's exhaust, but the exhaust pipes are pretty small- like 1.25 inches if that. You typically want to have larger exhaust pipes for better flow and performance, which is the main reason ppl upgrade the header in the first place, for better flow and performance. The main reason you would need to change it with a DX/LX is because there arent very many DX/LX specific exhausts out there to choose from, they are all LX.
Old 09-15-2009   #260 (permalink)
mmajimmy19
New Member
mmajimmy19 is an unknown quantity at this point
im so lost with this lol... RElax im learning. What excalty do i need if im going to convert my lx to ex headers and exhaust? and why?
mmajimmy19 is offline   Reply With Quote
Old 09-15-2009   #261 (permalink)
speedfoos
speedfoos's Avatar
The cat is closer to the engine because of the cat "light-off". The catalyst element inside needs to reach a certain temperature to function properly - burning up all the contaminants in the exhaust stream - and to do this quickly, it needs to be as close to the exhaust ports as reasonably possible. The closer it is to the motor, the hotter the exhaust stream, facilitating the cat light-off. It has nothing to do with wire length.
Mr. MMA. If you are not going to do a custom exhaust setup, then you need everything forward of the midpipe section on an EX. The difference between the LX and EX - from head to midpipe (1st part of a catback system) - is that there are different components of varying length. The LX header is longer than the EX header, and as such, the LX downpipe (which goes between the header and midpipe) is shorter than the EX downpipe. Make sense?
__________________
www.7thgenhonda.com
Old 09-15-2009   #262 (permalink)
madAd
Member
madAd's Avatar
Yeah, that's what I was wondering about. As far as the wires go, I could have just left them where they are in my race header, even though there's not a cat between them, they think there is. But I guess the cat would be pointless if it's affected by being too far down the exhaust stream.
Old 09-16-2009   #263 (permalink)
speedfoos
speedfoos's Avatar
Not so much pointless as inefficient. It will eventually reach light-off temperature, but depending on the type of emissions testing, it might not pass right away. They would have to hot test it.
__________________
www.7thgenhonda.com
Old 09-16-2009   #264 (permalink)
madAd
Member
madAd's Avatar
Well, I'm not worried about testing, they don't do it in Michigan. I just thought maybe I should have a cat, even though I'm still probably putting out a fraction of the emissions of some vehicles.
Old 09-16-2009   #265 (permalink)
TRIZ
TRIZ's Avatar
Thanks for that info speedfoos, I had no idea about that. I figured it made more sense to have it closer, but never came across any reasoning saying it had to.
So at what point is light-off? And when you say light off, you mean any emissions codes that would come up because the cat is inefficient, would then go off because the cat is efficiently doing its job, or am I totally off on this?
And if thats the case, then why wouldnt they go ahead and put a mini cat in each of the exhaust runners, or build it into the exhaust port side of the engine some how? I'm sure there are performance drawbacks, but would this yielder less polution/ cleaner emission vehicles?
Old 09-16-2009   #266 (permalink)
Cleft_Asunder
Super Member
Cleft_Asunder's Avatar
Cleft_Asunder is a glorious beacon of light Cleft_Asunder is a glorious beacon of light Cleft_Asunder is a glorious beacon of light Cleft_Asunder is a glorious beacon of light Cleft_Asunder is a glorious beacon of light Cleft_Asunder is a glorious beacon of light
Quote:
Well the point would be when you're in a situation like mine where your stock header is cracked, but you can't find a direct replacement nor have a desire to. So cheaply, I can replace it with an EX setup. Though the EX header is cast iron, if it cracks it can cheaply be replaced by a steel one.
Any way thanks for the help, I have a good idea what I will do. But other than my idea, could I redo the whole exhaust with aftermarket for under 500? Would you go with a cat back exhaust?
__________________
'97 Civic DX 5-speed: Keyed to perfection.
http://www.civicforums.com/forums/signaturepics/sigpic34179_1.gif
Updated 96-00 timing belt DIY
Cleft recommends Raxles axles
Research the New World Order
Cleft_Asunder is offline   Reply With Quote
Old 09-16-2009   #267 (permalink)
TRIZ
TRIZ's Avatar
You could as long as you pick up some used parts to meet your budget instead of new parts. Most of the time theres just a few scrapes on them and a bolt missing- cosmetic and easy fixes. Def doable tho.
Old 09-17-2009   #268 (permalink)
speedfoos
speedfoos's Avatar
Here's a good link to how a catalytic converter functions.
http://www.aa1car.com/library/converter.htm
The light-off temperature occurs between 400-600 degrees. Copied from that link is the explanation for why a P0420 pops up.
"On 1996 and newer vehicles with OBD II onboard diagnostics, the OBD II system has a catalyst monitor to keep an eye on converter operating efficiency. The OBD II system compares O2 sensor readings upstream and downstream of the converter. If the downstream readings start to match those of the upstream O2 sensor, it indicates a drop off in operating efficiency and sets a catalyst code P0420. Other converter faults may set codes ranging from P0420 to P0439"
There is a delay built-in to account for the time it takes for a cat to reach operating (aka light-off) temperature so you don't throw a code every time you do a cold start on the car.
Be careful what you suggest on cats for every exhaust runner. The enviro-nazis might think it's a good idea.... But there are a couple reasons they don't do this.
1. It's expensive to stuff the individual runners with enough catalyst material to be effective. Think of how much surface area is in that 14"x 4" cat and now figure how much of each individual runner would have to be stuffed to reach that same surface area. Not to mention how would you get in to the small runner and secure it so the engine vibrations don't just knock it loose.
2. Balance between emissions and power. It's a trade-off. Sure, if you run 8 cats in a row, your exhaust stream will be as clean as a whistle, but holy back-pressure Batman. Nissan and some other manufacturers do something similar. For instance, my 2004 Frontier has 4 (count em 4) cats. Two coming off each cylinder bank. Luckily the secondary O2 sensor is before the secondary cat so I can remove it without having to worry about tripping a code, but Nissan decided cleaner exhaust was better than more power.
Make sense?
__________________
www.7thgenhonda.com
Old 09-17-2009   #269 (permalink)
TRIZ
TRIZ's Avatar
^ Nice, good info. I read most of it and just Bookmarked it too!
Old 09-21-2009   #270 (permalink)
Cleft_Asunder
Super Member
What exhaust brands should I look for?
__________________
Tags
2003 , ac , cat , catback , civic , dx , headers , headers2002 , honda , install , lx , meagan , megan , racing , random , tech
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Looking for a 7th gen manual for free? (UPDATED!!!)
ALL of Grey's DIY's...
DIY: Trunk Shocks
Detailed smoked out taillights DIY w/ pictures
Oil Changes
DIY: tricked out trunk
DIY: No More Trunk Rattle!
SOHC VTEC Explained
DIY: Grounding kit Install
Need help with Radio Code
Site Supporters
aluminum radiator
Honda car spoilers
