Go Back   Honda Civic Forum > GENERAL > Honda Civic DIYs and Civic Tech Chat
Honda Civic DIYs and Civic Tech Chat Honda Civic DIYs and Civic Tech Chat - for the true gearheads! Bring your wrench, it's time for some Honda Civic DIY projects! Questions about problems with your car do NOT go here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 10-22-2008   #136 (permalink)
ChemicalBoom
Member
ChemicalBoom is an unknown quantity at this point
Re: The ultimate DX/LX header/exhaust FAQ
It cost me about $900
As for your header, yes you will need a catalytic converter welded into the downpipe at some point(unless you just want a test pipe which is not street legal), because unless you get it from honda, your header will not include one.
I got the pre-made downpipe/cat combo which is why my setup was pricey, but you can buy a converter and pipe and get it made at a local shop for much less.
ChemicalBoom is offline   Reply With Quote
Sponsored Links
Old 10-22-2008   #137 (permalink)
TRIZ
Hey! Look At Me!! I'm a Supporting Member!!Administrator
TRIZ's Avatar
TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of
Send a message via AIM to TRIZ
Quote:
Originally Posted by ChemicalBoom View Post
Well, no luck and its getting worse
The nut all the way to the right is not coming out, it is also now stripped.
The bolt and oxygen sensor below the converter are, from the way i see it impossible to get to with any tool. The converter is in the way of the bolt and vice-versa. The only thing i can get in there is a pair of pliers, which just strips things...
Unless I am missing something, i am stuck...
HELP lol
As for your first problem, you need a extention for your socket. A lot of the header nuts are really hard to get off because of all the heating and cooling that goes on- they eventually eventually end up getting really hot and almost fusing themselves to the stud. When you have your extender and are ready to get the nut off, tap the end of the ratchet with a hammer instead of torquing it loose by hand, you'll split the socket if you use enough force.
For the second problem, dont worry about removing the O2 sensor from the cat/exhaust yet, you can do that once its off your car. For now, just unclip the gray sensor connector. To get that other bolt off, I'm having a hard time visualizing exactly where it is... It looks like its connected to a bracket- can you remove the bracket? From the angle you took a picture from, you should be able to use an open ended wrench.
TRIZ is offline   Reply With Quote
Old 10-22-2008   #138 (permalink)
Gumdrop
Senior Member
Gumdrop's Avatar
Gumdrop is an unknown quantity at this point
okay thanks, when the time comes (hopefully soon) im definitely buying some OBX or Megan racing headers and then put my cat w/pipin on it
Gumdrop is offline   Reply With Quote
Old 10-23-2008   #139 (permalink)
TRIZ
TRIZ's Avatar
Its headeR, not headers- we only have one manifold on our cars.
Old 10-23-2008   #140 (permalink)
ChemicalBoom
Member
the header bolt is stripped....i did use an extender in the first place the 1st 2 were cake to get off.
Old 10-23-2008   #141 (permalink)
amishman22
Member
amishman22's Avatar
amishman22 is on a distinguished road
Send a message via AIM to amishman22
very true triz.
amishman22 is offline   Reply With Quote
Old 10-23-2008   #142 (permalink)
Cleft_Asunder
Super Member
Cleft_Asunder's Avatar
Cleft_Asunder is a glorious beacon of light Cleft_Asunder is a glorious beacon of light Cleft_Asunder is a glorious beacon of light Cleft_Asunder is a glorious beacon of light Cleft_Asunder is a glorious beacon of light Cleft_Asunder is a glorious beacon of light
I don't get it, why would you need a SECOND cat integrated with the down pipe? You've already got a random tech cat under the car with sensors attached to it (if i'm not mistaken). I thought one of the main advantages is that you can eliminate the stock cast iron "header-cat" for good.
__________________
'97 Civic DX 5-speed: Keyed to perfection.
http://www.civicforums.com/forums/signaturepics/sigpic34179_1.gif
Updated 96-00 timing belt DIY
Cleft recommends Raxles axles
Research the New World Order
Cleft_Asunder is offline   Reply With Quote
Old 10-23-2008   #143 (permalink)
Cleft_Asunder
Super Member
Quote:
Originally Posted by amishman22 View Post
very true triz.
Yes, words of wisdom. -_-
__________________
Old 10-23-2008   #144 (permalink)
TRIZ
TRIZ's Avatar
Quote:
I think he was referring to getting an EX header from honda, and not the dx/lx header. The ex header has no cat in it, the lx does. If you replace the dx/lx header with an ex one, you wont have a cat in it and will need to have the cat in your downpipe, which is exactly what the random tech hi flow cat/downpipe is.
Old 10-23-2008   #145 (permalink)
ChemicalBoom
Member
^^^ Hit the nail on the head triz
Old 10-26-2008   #146 (permalink)
megawombat
New Member
megawombat is an unknown quantity at this point
I recently purchased an '01 civic LX. Over-all the car is in pretty good shape and runs well but it has some Autozone looking fart-can on it, which I would like to replace with something nicer. I do not ever plan on putting a turbo kit on and I do not drive like an a$$hole so I want to retain enough back-pressure to not loose low rpm power. After reading this post I decided that a 2" cat-back exhaust pipe is the way to go. Can I get some recommendations on the best brands of cat-back exhausts for this setup and should I even bother with the LX-EX swap with this in mind? Additionally am I correct in thinking that replacing the stock manifold/header is a waste of time?
megawombat is offline   Reply With Quote
Old 10-26-2008   #147 (permalink)
ProjectMayhemR
Senior Member
ProjectMayhemR will become famous soon enough
custom mandrel bent piping i believe is the only way to get exactly 2" piping. The stock lx/dx manifold is pretty restrictive. but doing an ex manifold with a test pipe or a high-flow cat would free things up a bit. You have to weigh the benefit vs the price of the mod. Its all about is it worth it to you? So asking if it's a waste of time is just gonna get you others opinions when really u need to ask yourself that question. You have the info^ in this thread now make a decision.
__________________
maturity is overrated
ProjectMayhemR is offline   Reply With Quote
Old 10-26-2008   #148 (permalink)
megawombat
New Member
Ok, maybe I didn't word that correctly. By "waste of time" I meant; little or no increase in performance because I do NOT ever plan on putting a turbo kit on my car.
Old 10-26-2008   #149 (permalink)
ProjectMayhemR
Senior Member
well with this car, unless you do something serious, you're not going to see anything major. You might pick up 3 or 4hp total with exhaust, header, and test pipe.
__________________
Old 10-26-2008   #150 (permalink)
ChemicalBoom
Member
Well, I finally finished. Sounds good, but the way the Random Tech downpipe bolts onto the header leaves leaks....I guess i'll hafta get it welded. And there is a lot of rattling from the undercarraige. But im happy it's done
Tags
2003 , ac , cat , catback , civic , dx , headers , headers2002 , honda , install , lx , meagan , megan , racing , random , tech
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Looking for a 7th gen manual for free? (UPDATED!!!)
ALL of Grey's DIY's...
DIY: Trunk Shocks
Detailed smoked out taillights DIY w/ pictures
Oil Changes
DIY: tricked out trunk
DIY: No More Trunk Rattle!
SOHC VTEC Explained
DIY: Grounding kit Install
Need help with Radio Code
Site Supporters
aluminum radiator
Honda car spoilers
