Go Back   Honda Civic Forum > GENERAL > Honda Civic DIYs and Civic Tech Chat
Honda Civic DIYs and Civic Tech Chat Honda Civic DIYs and Civic Tech Chat - for the true gearheads! Bring your wrench, it's time for some Honda Civic DIY projects! Questions about problems with your car do NOT go here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 03-12-2007   #1 (permalink)
TRIZ
Hey! Look At Me!! I'm a Supporting Member!!Administrator
TRIZ's Avatar
TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of
Send a message via AIM to TRIZ
DIY: Change the color of your door panels with suede!!
Several people have been asking me for the DIY because its a little tricky to find being it was orig. posted this in the headliner thread. So here it is!!
That said, here is a mini DIY (for the coupe)::::
Here is most of what you will need:
A very nice workbench to get down on
Trim panel remover (to get the door off)
Someway of getting the adhesive off (goo off, razor blade, lots of rubbing, heat gun, whatever- up to you)
Painters tape
Newspaper
Cardboard
Razorblade
Fabric
3M adhesive ( I used # 80)
Rubber cement
Putty knife
Dremel and epoxy (optional)
Phillips (to remove the door)
Flat head screwdriver (to get fabric tucked around the edge for that clean look)
Don’t have the door panel off? Go buy a "trim panel remover" from Napa or Shucks. There are other thread on here that explain this but real quick to save you guys some time…Unscrew everything you can from the door (two screws by the door handle behind a plate, removed the door handle), and then start from the bottom by the speaker and run the trim panel removed along the bottom until you bump into the clips, straddle them with the tip and apply some leverage and POP goes the clip. There are several around the door. I'll post a pic at the end of the clip placement.
This is a picture of the door panel off, power window part removed along with lower part (to get this off, you need force, you actually need to break it off, there is several rivets (three I believe) a hook, and another connector piece under the front armrest. For me, I broke this off thinking I needed to remove it to get the door off, you dont. Later on, you'll want to break or dremel it off to make the instal quicker and avoid wrinkles. Good news is its not necessary and it will stay in place even with all this stuff broken (as long as you don’t break the hook it’ll be easier on you- which I didn’t break- its built pretty sturdy, but if it gets broken oh well, everything on the door is fixable with epoxy paste and an overnight drying). If you want to fix it, which is recommended, pick up some epoxy paste that dries overnight at a hardware store. Mix it together with some putty knives and mold it around the broken pieces. Let it dry over night, and they are fixed. I can help you with this if you need more help.) I removed the fabric by just yanking it off starting at the power window area. I slid my trim panel remover in there to loosen it up and just started yanking. I removed the adhesive with some goo off (didnt work that great) so I moved to a razorblade, worked pretty well but time consuming. I took the panel outside and sprayed it down with water to removed the dust, chemicals, and all the other crap, followed by drying it off. In this picture, the arm rest is on, although its only held in by two metal clips on either side, one of which I broke, but patched back up with epoxy paste, dried rock hard- good as new. I put the armrest back on to see how far the fabric had to cover.
Tape all the areas off so you don’t get adhesive over spray. Don’t want your passengers arms sticking to your door!
I ran some tests with the adhesive spray on a large piece of cardboard I had laying around to see what the spray pattern was like and how I was going to work with it. It came out quick, and nothing like a spray paint can, which I'm pretty famil with, heh. But the important part was that I now knew what to expect. I also noticed how long it took before it dried up. Which for me, gave me about 30 seconds to lay the material down after finishing the spray. (Don’t worry about tucking the edges in as of now, we'll go back and push them in there with a putty knife or flathead screwdriver to get them in there) I realized I couldn’t do the entire panel with one spray, so I did it in sections. However many sections you do is up to you. I used cardboard to cover the fabric from over spray. This is a two person job.
I had a friend helping me. He held the fabric up in one hand, and the cardboard in another, I sprayed and spread the adhesive with a finger, wiped it off real quick as he tossed the cardboard aside, and we laid the fabric down- he held it above and I slowly smoothed it over the adhesive area. At the end, I had about an extra inch of material left over, no biggie, just cut it off. Oh... I should mention here I used microsuade and started from the front of the panel and worked my way to the back.
Apparently, the fabric I had precut and set aside ended up touching some of the chemicals that I tried to remove the OEM adhesive with. Stained the fabric, which was covered up by the pocket on the door so I wasn’t too worried, but some of the adhesive actually bled through the fabric and made dark blotches. These coupled together pissed me off. To tuck the fabric in around the edge, I used a flat head screwdriver.
I turned away for a little bit and had my friend cut out a second piece of fabric for us to lay. As I’ve said in previous posts in this thread, the 3M # 80 does not work to bond two fabrics together. Rubber cement works wonders, with an amazing hold. Laying the fabric down was much easier because rubber cement doesn’t have over spray, and the previous over spray was dried, so spent less time worry about the fabric getting messed up.
<-- this was my first layer that got really fvked up
Now, before I show you what the final product looks like, I want to explain the clips real quick. Here is a picture of where the clip placemnt is. One clip near the bottom had broke off, oh well- I’m not running to Honda to get another one-my door will stay on as you can see by all the other clips. [update- door rattles in that particular section- note: find clip and epoxy to door panel] One other clip on the side stayed attached to the door (top right of the speaker). To get the clip out of the door, I just grabbed it with a pair of pliers and slid it back in the door. Following the door panel are some close ups of the two clips I’m talking about, you can see the difference.
Here is what it looked like with both layers on (using rubber cement for the second layer).
Hope that helped clarify any of the questions you guys with the coupes had that wanted to do microfiber. If not, I’m here for questions!
TRIZ © 01-09-2007 TRIZ
POST PICS IN HERE OF YOUR COMPLETED DOOR PANELS!!
TRIZ is offline   Reply With Quote
Sponsored Links
Old 03-12-2007   #2 (permalink)
LT2004ever
I wil fix vBPlaza today
LT2004ever's Avatar
LT2004ever is a name known to all LT2004ever is a name known to all LT2004ever is a name known to all LT2004ever is a name known to all LT2004ever is a name known to all LT2004ever is a name known to all LT2004ever is a name known to all LT2004ever is a name known to all LT2004ever is a name known to all
Send a message via AIM to LT2004ever
great DIY great project, geat everyhting... if i could rep you i would... now im still searchin for some green microfiber, suede, or something. Will take on this task this weekend most likely, i save up some funds.
__________________
By speedfoos[/url]
R.I.P. 7thgen Club Member #5
Auto Driver by Force Member #2
Riding 4x4 Till Saved For Drop Member #1
"The most wasted of all days is a day without laughter" e.e.cummings
Clover Green 2001 EM2
CHEAP, RELIABLE, FAST - you can only choose two
LT2004ever is offline   Reply With Quote
Old 03-12-2007   #3 (permalink)
Eyger
A long winded 7th genr
Eyger should not be questioned Eyger should not be questioned Eyger should not be questioned Eyger should not be questioned Eyger should not be questioned Eyger should not be questioned Eyger should not be questioned Eyger should not be questioned Eyger should not be questioned Eyger should not be questioned Eyger should not be questioned
Send a message via AIM to Eyger
Nice Job Triz that's cool. I did my headliner in the same material. But I didn't like it so I ripped it off! Ha ha, oh well I want to do something crazier.
Eyger is offline   Reply With Quote
Old 03-12-2007   #4 (permalink)
element_2nice
Member
element_2nice is an unknown quantity at this point
pics... definitely would have helped...
good diy though!
element_2nice is offline   Reply With Quote
Old 03-12-2007   #5 (permalink)
SEN_ONE
CS-X3 Fresher than you
SEN_ONE's Avatar
SEN_ONE is a glorious beacon of light SEN_ONE is a glorious beacon of light SEN_ONE is a glorious beacon of light SEN_ONE is a glorious beacon of light SEN_ONE is a glorious beacon of light SEN_ONE is a glorious beacon of light SEN_ONE is a glorious beacon of light
Send a message via AIM to SEN_ONE
Nice to see new DIY's. Good job.
__________________
SEN_ONE is offline   Reply With Quote
Old 03-12-2007   #6 (permalink)
CecDogsVTEC
Member
CecDogsVTEC's Avatar
CecDogsVTEC is an unknown quantity at this point
Send a message via AIM to CecDogsVTEC
AWESOME DIY!!!!! Now I have a project over the summer. I have all black interior but I think a royal blue suede would look tight in my car. Im kinda excited!
CecDogsVTEC is offline   Reply With Quote
Old 03-12-2007   #7 (permalink)
TRIZ
TRIZ's Avatar
Quote:
good diy though!
Arent the pics showing up?
Old 03-12-2007   #8 (permalink)
SEN_ONE
SEN_ONE's Avatar
They work here.
__________________
Old 03-12-2007   #9 (permalink)
xcrxss
Member
xcrxss's Avatar
xcrxss is on a distinguished road
Send a message via AIM to xcrxss
That looks nice!
__________________
2008 Tafetta White Si
xcrxss is offline   Reply With Quote
Old 03-14-2007   #10 (permalink)
TRIZ
TRIZ's Avatar
Maybe this will make it in the DIY section... anyone think its worthy or not?
Old 03-14-2007   #11 (permalink)
CecDogsVTEC
Member
I think it is. I am going to get mine done once I get it back from the shop. I already bought the royal blue suede. I'll get some pics posted once I get it done.
Old 03-15-2007   #12 (permalink)
01HonderCivic
Don't be a n00b, search ftw
01HonderCivic's Avatar
01HonderCivic has a brilliant future 01HonderCivic has a brilliant future 01HonderCivic has a brilliant future 01HonderCivic has a brilliant future 01HonderCivic has a brilliant future 01HonderCivic has a brilliant future 01HonderCivic has a brilliant future 01HonderCivic has a brilliant future 01HonderCivic has a brilliant future 01HonderCivic has a brilliant future 01HonderCivic has a brilliant future
I'll swap in a gauge cluster for you if you want to do my door panels
Awesome work man
__________________
...Holdin' it down, Oregon style bitches!
01HonderCivic is offline   Reply With Quote
Old 03-15-2007   #13 (permalink)
TRIZ
TRIZ's Avatar
Werds, Wouldnt mind. ^^ I was looking at the rsxs cluster. Got the balls for that one?
I'll be back in portland next wednesday late night for my spring break- pushing a week and a half, yeahhh bahbay!!
Old 03-15-2007   #14 (permalink)
01HonderCivic
I'd have to research it...I believe it requires the RSX plugs as well. And a custom bezel
__________________
Old 03-17-2007   #15 (permalink)
TRIZ
TRIZ's Avatar
I know a bunch of you guys are doing this over the weekend, post some pics up after you get it done!!
Tags
05 , 8th , change , civic , color , diy , door , fabric , forums , honda , interior , panel , panels , put , suede
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Honda Civic Forum Replies Last Post
DIY.. Reducing Weight in Door Panels civictuner Honda Civic DIYs and Civic Tech Chat 35 11-10-2004 01:39 AM
DIY on stock 2001 gauges color change NorrinRadd Honda Civic DIYs and Civic Tech Chat 4 07-28-2003 01:53 PM
door panels different color corruptnu2 General Automotive Discussion 4 09-08-2002 09:34 PM
DIY: Change Your Dashlight Color pimpedcivic Honda Civic DIYs and Civic Tech Chat 40 07-24-2002 12:41 AM
DIY: Easy change of Dash light color. Civic2k2Rider Honda Civic DIYs and Civic Tech Chat 5 07-17-2002 11:51 PM
User Login
Our Partners
used new
Top 10 Threads
Looking for a 7th gen manual for free? (UPDATED!!!)
ALL of Grey's DIY's...
DIY: Trunk Shocks
Detailed smoked out taillights DIY w/ pictures
Oil Changes
DIY: tricked out trunk
DIY: No More Trunk Rattle!
SOHC VTEC Explained
DIY: Grounding kit Install
Need help with Radio Code
Site Supporters
aluminum radiator
Honda car spoilers
