Honda Civic DIYs and Civic Tech ChatHonda Civic DIYs and Civic Tech Chat - for the true gearheads! Bring your wrench, it's time for some Honda Civic DIY projects! Questions about problems with your car do NOT go here.
Welcome to civicforums.com!
Welcome to civicforums.com.
anyone know what would be involved in hooking up an outlet that stays powered when the car is powered off? sometimes I want to be able to leave my cell in the car charging when it's totally dead...
I would imagine new wiring to the fuse panel would be required, I don't even have a map of the fuse panel though so no idea what to splice into...
just run a fused connection from the a battery if you want to a constant on power wire.
gotta run a wire all the way from the battery? that sounds like a lot of work... :/
isn't there a circuit alrady in the fuse panel under the steering wheel that has constant power (like the dome light / power for the radio preset memory) that I could tap into with a device like this
Good luck, I was never able to find one under the dash in my RSX-S. I'm sure they are similar if not the exact same. I wanted my radar detector hot all the time, no luck though...
what type/gauge wire can i use to lengthen the wires that connect to the back of the cigarette outlet? i want to lengthen them so i can pull the panel farther out while the wires and outlet are still attached.
