Go Back   Honda Civic Forum > GENERAL > Honda Civic DIYs and Civic Tech Chat
Honda Civic DIYs and Civic Tech Chat Honda Civic DIYs and Civic Tech Chat - for the true gearheads! Bring your wrench, it's time for some Honda Civic DIY projects! Questions about problems with your car do NOT go here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 03-18-2002   #1 (permalink)
Grey
DIY King
Grey's Avatar
Grey has a spectacular aura about Grey has a spectacular aura about
Send a message via AIM to Grey
DIY: Push Button Ignition
This is a re-post since the link to the original died for some reason.
<< Here goes. The setup I use is like this.... I have toggle switches for my igntion wires and a push button for the starter....
Here is the DIY for it...
You have 4 wires that you are going to deal with....
This is what you will need....
(4) Toggle Switches SPST (Single Pole Single Throw)
(1) Push Button --- this will be used to roll over the starter.
(4) 50 Amp Bosh Relay's ---- these are so that you do not burn up your switches...
(1) DEI Part Number 555u ---- this is to bypass the RS4 immoblizer system.
--==DIY Push Button Ignition==--
First, you need to remove the shroud around the steering wheel.. This is done by removing the (3) screws on the bottom side of the shroud. Then it will pull apart into (2) pieces.
Next you have 2 options...
1. Run a 4-8 gauge wire from the (+) side of you batter into the car. . I did this one since I did not want to cut any wires.
2. Cut the white wire (this is about a 10-12 gage wire)
Take one of the 2 options and run it to where everyou you are gonna put your switches.
***Note*** ***1***
You do not need to bypass if you are not planning on remote start or if you do not plan on removing the steering wheel lock, because if you do not remove the steering wheel lock then you will have to leave you key in the ignition, and disconnect the ignition harness from the ignition switch.
DEI Immoblizer bypass wiring ---- Connect the antenna ring around the ignition switch cylinder
Connect the red wire to the constant 12v.
Connect the blue wire to a switch and the other end of the switch should goto the ground.
Now you need to connect all of the (#87 on the relays) to your constant 12 volts.
Next you need to connect all of the (#85 on the relays) to a good ground.
Now #86 (on the relays) needs to goto a seperate switch including the push button switch.
#30 (on the relays) needs to goto the following wires.
****NOTE ALL OF THE IGNITION WIRES are BIGGER than the rest of the wires on the Steering Colum. You can identify them by this-- they are right under the igntion switch....
Use Scotch Connectors to tap into these wires. Do not cut them, this way you can use your key too...
Relay (1) (Ignition 1) This will be the black with a yellow stripe wire.
Relay (2) (Accessory 1) This will be the black with red stripe wire.
Relay (3) (Accessory 2) This will be the white with red stripe wire.
Relay (4) (Starter) This will be the black with a white stripe wire.
Connect the oppisite ends of the switches to your constant 12 volts.
These need to be turned on in this order for you car to run correctly
Toggle Switch (1) ----------&gt;DEI Immoblizer Bypass ***1*** (you may or may not use this depending on your situation)
Toggle Switch (2) ----------&gt;Relay (1)
Toggle Switch (3) -----------&gt;Relay (2)
Toggle Switch (4) -----------&gt;Relay (3)
Push Button Switch (1) ----&gt; Relay (4) (you can use this by itself if you only want to push a button to start the car but do not want the switches)
Grey is offline   Reply With Quote
Sponsored Links
Old 03-19-2002   #2 (permalink)
CivicVTec
Ultimate Member
CivicVTec's Avatar
CivicVTec is an unknown quantity at this point
Send a message via ICQ to CivicVTec Send a message via AIM to CivicVTec
thx man...did u take some pics?
CivicVTec is offline   Reply With Quote
Old 03-19-2002   #3 (permalink)
Grey
DIY King
Grey's Avatar
I'll mention again that this is not my DIY. This is a re-post because the link to the original thread died for some reason? I would have liked pics as well. Oh well. Maybe I should DIY this in the future and post some pics?
Old 03-19-2002   #4 (permalink)
VTECnique
Diamond Member
VTECnique's Avatar
VTECnique is an unknown quantity at this point
Send a message via AIM to VTECnique Send a message via Yahoo to VTECnique
this was a big help...but i have 1 more question:
my switch is 2 prong;
I have 1 relay with an 85, 86, 30, 87, and an 87a connector(s);
it also came with thick wires (red, yellow, white, black) and 2 thinner black wires (one to the switch, one to the relay);
i got a basic of where everything goes, but some colors u have are different to what i have. It wouldn't be a prob if the instructions weren't in JAPANESE! So once again, i ask the wiring gurus for assistance.
VTECnique is offline   Reply With Quote
Old 03-19-2002   #5 (permalink)
locozoko
Member
locozoko is an unknown quantity at this point
Send a message via AIM to locozoko
u have the "euro type-r" S2000 Button Switch right? ya i got it too and since i dont read Japanese ill just pay someone to do the installation for me. i think the 60 or $70 is well worth it rather than me f*cking up my car. hehehe. [IMG]i/expressions/face-icon-small-tongue.gif[/IMG]
locozoko is offline   Reply With Quote
Old 03-20-2002   #6 (permalink)
LJ
Fernando The Donkey Lover
LJ's Avatar
LJ is an unknown quantity at this point
now, how do u do it so that you still have to do the key, i didn't quiete understand that part
LJ is offline   Reply With Quote
Old 03-21-2002   #7 (permalink)
locozoko
Member
well you still need the key.. depends how u wire it up, you can bypass it so you do the following (with what i have):
1. put the key in and turn it to the first position (on), and you can ONLY start the engine by pressing in the start button
OR
2. put the key in and put it on ON position, and either press the start button or turn the key all the way (crank it) like normal to start
im sure there are various different methods you can do with it, but im not an expert on it hehe. hope this helped
Old 04-27-2002   #8 (permalink)
crazybluehonda
Member
crazybluehonda is an unknown quantity at this point
but is there a way not to use key? im going to mold but colum completly shut. i have already ditched the steering wheel lock . but is there a way to have button instead of key. or will the stock alarm work? im guessing not becasue no key right. well let me know
crazybluehonda is offline   Reply With Quote
Old 05-23-2002   #9 (permalink)
KazzuM
Member
KazzuM is an unknown quantity at this point
you know where our trunk release is where that little keyhole is for the valet thing, well is there a way to put the ignition there so that the key has to be in then push button where the emergency light switch is. i really want this to be done to my car but i dont want to spend thousand of dollars to do it.
thanks
KazzuM is offline   Reply With Quote
Old 05-23-2002   #10 (permalink)
VTECnique
Diamond Member
VTECnique's Avatar
huh?
Old 05-23-2002   #11 (permalink)
armageddon
Member
armageddon's Avatar
armageddon is an unknown quantity at this point
Grey, you da man.[IMG]i/expressions/beer_yum.gif[/IMG][IMG]i/expressions/beer_yum.gif[/IMG]
armageddon is offline   Reply With Quote
Old 05-23-2002   #12 (permalink)
Vizyun
The Fallen Angel . . .
Vizyun's Avatar
Vizyun is an unknown quantity at this point
Send a message via AIM to Vizyun
<< you know where our trunk release is where that little keyhole is for the valet thing, well is there a way to put the ignition there so that the key has to be in then push button where the emergency light switch is. i really want this to be done to my car but i dont want to spend thousand of dollars to do it.
huh?
He's referring to the spot on the floor to the left of the driver's seat where the trunk and gas-cap release are. There is a key-hole there that disables the trunk release (that way, if you give someone the valet key, they can't get into your trunk). He said there is a way to have the ignition lock from the steering column relocated there so that you can put the key in, push the start button and be on your way. Sounds like a good idea, actually.
__________________
"Vizyun is only limited to the distance between you and the horizon to which you aspire. . ."
Vizyun is offline   Reply With Quote
Old 05-24-2002   #13 (permalink)
VTECnique
Diamond Member
VTECnique's Avatar
OOOOOOHHHHHH... i see now...
Old 08-21-2002   #14 (permalink)
2k1
Member
2k1 is an unknown quantity at this point
does this work for the 5 prongs...it's a actual S-2000 button
2k1 is offline   Reply With Quote
Old 09-06-2002   #15 (permalink)
Deejai35
Diamond Member
Deejai35's Avatar
Deejai35 is an unknown quantity at this point
Send a message via AIM to Deejai35 Send a message via Yahoo to Deejai35
I know its been a while since this post originated, but I have a question. Do you need a relay for the starter button itself? I know that many of the DIY that I have seen use it, but I ran across one that was done in a civic and they didn't use it. Will the current burn out the starter button if I splice into the power outlet for a power source?
Deejai35 is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Looking for a 7th gen manual for free? (UPDATED!!!)
ALL of Grey's DIY's...
DIY: Trunk Shocks
Oil Changes
Detailed smoked out taillights DIY w/ pictures
DIY: tricked out trunk
DIY: No More Trunk Rattle!
SOHC VTEC Explained
DIY: Grounding kit Install
Ask Me About DIY Stuff V2!
Site Supporters
aluminum radiator
Honda car spoilers
