Go Back   Honda Civic Forum > GENERAL > Honda Civic DIYs and Civic Tech Chat
Honda Civic DIYs and Civic Tech Chat Honda Civic DIYs and Civic Tech Chat - for the true gearheads! Bring your wrench, it's time for some Honda Civic DIY projects! Questions about problems with your car do NOT go here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 03-07-2002   #1 (permalink)
wh3nw0rdsesc4pe
Super Member
wh3nw0rdsesc4pe's Avatar
wh3nw0rdsesc4pe is an unknown quantity at this point
Send a message via ICQ to wh3nw0rdsesc4pe Send a message via AIM to wh3nw0rdsesc4pe
DIY: Installing Apex'i S-AFC
Installing the Apex'i Super-AFC
First things first, mount the S-AFC where you would like it to be. Be sure to leave enough slack, to run the wires behind the glove box. I mounted mine on top of the steering wheel column. I ran the wire down the right side and under the fuse box door beneath the steering. There was plenty of slack with my placement.
Ok, wires now:
1. Connect the Black wire to the ground wire (black wire) under the passenger side seat.
2. Next connect the Brown wire 3-5 inches closer to the ECU, towards the front of the car, than the black wire. This is on the same ground wire as the black wire.
3. These should be the only wires running under the seat.
4. The gray wire should connect to the Red w/ Black Stripe wire. This is the Throttle Sensor wire. The Red w/ Black Stripe Wire is located on the ECU on the very bottom connector, the gray/black one.
5. Next the RPM sensor wire, this wire is located on the top connector of the ECU, the RPM sensor wire is the dark blue wire, the wires included with the RPM sensor are attached like this: WWW-WB-WWW. Where the W=other wire and the B=RPM meter wire. You will connect the green wire to this wire.
6. Next are the MAP sensor wires, you will have to cut this wire. This is the wire that the yellow and white wires from the S-AFC will connect to. The Green w/ Red Stripe wire (MAP SENSOR wire) is located on the ECU on the bottom connector. The white wire runs directly to the Map sensor, out from the ECU, and the Yellow wire will connect to the Map Sensor wire going to the ECU.
7. Visual = ECU------GwRS---YW---SAFC----WW---GwRS------Map Sensor.
8. Now to power the A’pexi S-AFC. Run the Orange wire from the S-AFC to the Yellow w/ Black Stripe wire on the BOTTOM of the gray connector. There are 2 Yellow w/ Black Stripe wires make sure you connect it to the bottom one. Now the Red wire from the S-AFC will connect to the Yellow w/ Black Stripe wire above the Orange wire. Power is all set.
This is what I have done to install my S-AFC, (Yes, it works fine). Special thanks to Boosted for some info. I have tried to make this as simple as possible, if you have any ?’s PM me and I will try my best. You cannot and will not hold me accountable for any mechanical problems encountered with this DIY, it is SOLEY up to you on installing this product. Mine is installed and is working fine, except the fact that I have yet to go to a DYNO, but I will as soon as I get some more cash flow… enjoy people!!!!
__________________
i logged on for the first time in a few years on June 18th, 2007 at 10:32 P.M. haha
wh3nw0rdsesc4pe is offline   Reply With Quote
Sponsored Links
Old 04-16-2002   #2 (permalink)
AEMcivic
Member
AEMcivic is an unknown quantity at this point
Send a message via AIM to AEMcivic
Wow, thanks for the great DIY man.
AEMcivic is offline   Reply With Quote
Old 04-16-2002   #3 (permalink)
wh3nw0rdsesc4pe
Super Member
No prob, glad someone appreicates this....
Old 06-19-2002   #4 (permalink)
WhiteRiceBoi
Diamond Member
WhiteRiceBoi's Avatar
WhiteRiceBoi is an unknown quantity at this point
Send a message via AIM to WhiteRiceBoi Send a message via Yahoo to WhiteRiceBoi
good DYI man, APEXi r00lz
WhiteRiceBoi is offline   Reply With Quote
Old 06-19-2002   #5 (permalink)
wh3nw0rdsesc4pe
Super Member
thanks, but I wonder if anyone has actually used it....lol
Old 06-30-2002   #6 (permalink)
BlueLightning
Member
BlueLightning's Avatar
BlueLightning is an unknown quantity at this point
Send a message via ICQ to BlueLightning Send a message via AIM to BlueLightning Send a message via MSN to BlueLightning Send a message via Yahoo to BlueLightning
may i ask what is the main thing does it do??? i see couple of ride have it.. what wold it do to you car?? i can see that it would control the power butlet me know
BlueLightning is offline   Reply With Quote
Old 07-03-2002   #7 (permalink)
skitzo
Member
skitzo is an unknown quantity at this point
Send a message via AIM to skitzo
How do you like it in the LX, I was going to get one but didnt know if it would be worth 3 bills.
skitzo is offline   Reply With Quote
Old 07-03-2002   #8 (permalink)
wh3nw0rdsesc4pe
Super Member
Bluelightining - the air flow converter lets you simulate how much air is going into the engine, you can up the air so that the ECU thinks more air is going in, therefore it counters the air with more fuel...
It works better with more mods, and with all the engine mods out for the 7th gen's (LOL), you can definitley feel a difference I had mine tuned with a pretty major increase in the air ratio, you can tell a difference.
Old 07-03-2002   #9 (permalink)
JAKE
Member
JAKE is an unknown quantity at this point
Send a message via AIM to JAKE
Awsome DIY, i wonder if its the same for the V-AFC cause thats what i have and i called Apexi and they said they havent hooked one up for the 7th gens yet. I heard the air and the fuel ratio part will work but the vtec controller on it wont work. But me and a shop are going to get my ECU diagrams and go by there and hopefully get it to work and send the plans to Apexi. Ill let you fellas and ladies know what happens. thanks for the DIY once again.
JAKE
JAKE is offline   Reply With Quote
Old 08-26-2002   #10 (permalink)
IronFist
IronFist's Avatar
IronFist has a reputation beyond repute IronFist has a reputation beyond repute IronFist has a reputation beyond repute IronFist has a reputation beyond repute IronFist has a reputation beyond repute IronFist has a reputation beyond repute IronFist has a reputation beyond repute IronFist has a reputation beyond repute IronFist has a reputation beyond repute IronFist has a reputation beyond repute IronFist has a reputation beyond repute
Any more info yet?
IronFist
IronFist is offline   Reply With Quote
Old 03-23-2003   #11 (permalink)
KeNsHiN
LEVA
KeNsHiN's Avatar
Send a message via AIM to KeNsHiN
i see nothing but "x's" and i need this DIY please email to me.
glycerin57@yahoo.com thanks
__________________
*Sig removed because over size limit*
KeNsHiN is offline   Reply With Quote
Old 03-23-2003   #12 (permalink)
wh3nw0rdsesc4pe
Super Member
i guess the pics didn't transfer over onto the new server. i didn't save them, all he said to save was your member's ride profile and the private messages, so i thought these would transfer, i don't have them, on my computer here, and i doubt my computer at home still has them. if you need help IM me at - wastethedayaway i remember the whole install.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Looking for a 7th gen manual for free? (UPDATED!!!)
ALL of Grey's DIY's...
DIY: Trunk Shocks
Detailed smoked out taillights DIY w/ pictures
Oil Changes
DIY: tricked out trunk
DIY: No More Trunk Rattle!
SOHC VTEC Explained
DIY: Grounding kit Install
Need help with Radio Code
Site Supporters
aluminum radiator
Honda car spoilers
