Go Back   Honda Civic Forum > GENERAL > Honda Civic DIYs and Civic Tech Chat
Honda Civic DIYs and Civic Tech Chat Honda Civic DIYs and Civic Tech Chat - for the true gearheads! Bring your wrench, it's time for some Honda Civic DIY projects! Questions about problems with your car do NOT go here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 02-14-2002   #1 (permalink)
ph0ng
Senior Member
ph0ng's Avatar
ph0ng is an unknown quantity at this point
Send a message via ICQ to ph0ng Send a message via AIM to ph0ng Send a message via Yahoo to ph0ng
New DIY for Hyper Blinker - others were lost
*Disclaimer* This DIY requires willingness to soder in very small and exact area. Not recomended for the beginner.
But if you are willing to do this, this project can cost you anywere between $0.00 - $0.75, and time.
Will save you the $28+shipping hyperblinker.com charges.
Needed supplies:
- solder + soldering iron
- #3 phillips
- nimble hands and needle nose pliers
- 100k ohm - 150k ohm resister. you can try different values, but I wouldn't suggest anything smaller than 100k
*smaller the numer = faster blink
ph0ng is offline   Reply With Quote
Sponsored Links
Old 02-14-2002   #2 (permalink)
ph0ng
Senior Member
ph0ng's Avatar
1. remove fuse pannel for easy access, requires phillips
Old 02-14-2002   #3 (permalink)
ph0ng
Senior Member
ph0ng's Avatar
2. Find and remove Blinker relay. Watch out for the 2 tabs, bottom and top, spread and pull.
Old 02-14-2002   #4 (permalink)
ph0ng
Senior Member
ph0ng's Avatar
3. Now open up the relay housing.
Old 02-14-2002   #5 (permalink)
ph0ng
Senior Member
ph0ng's Avatar
4. find R1 on the pc board... notice it's the smallest resistor... get ready to soder!
Old 02-14-2002   #6 (permalink)
ph0ng
Senior Member
ph0ng's Avatar
5. Now that you have sodered your resistor (I used 150k ohm - 5 finger discount from Fry's) in paralell with R1, I used electrical tape to protect the exposed components and just laid the resistor flat.
Old 02-14-2002   #7 (permalink)
ph0ng
Senior Member
ph0ng's Avatar
6. Before you seal up the caseing, go plug it into your fuse panell and test it out... Hurray, you now have a rice, I mean hyperblinker!
Now go show off at the races and remember, fast blinker = fast car
Old 02-14-2002   #8 (permalink)
ph0ng
Senior Member
ph0ng's Avatar
Sorry, just notice I started this thread @ 4:20 PST... Time to go celebrate!
Old 02-14-2002   #9 (permalink)
Grey
DIY King
Grey's Avatar
Grey has a spectacular aura about Grey has a spectacular aura about
Send a message via AIM to Grey
K3wl, it works. I did everything but solder on a resistor to see if it worked. I was going to use a small potentiometer that would allow me to adjust it just the way I like it. I chickened out after I got a little sloppy with the soldering iron and almost tore off the leads to R1. I ended up just soldering the original resistor back on and I forgot about it.
I was thinking that if I just change out my signal bulbs with the LED type then the resistence of the circuit would go down and the blinking rate would go up. All without any modification of the relay. I think I'll take on this approach instead. I do want faster blinkers though. They're safer when changing lanes at high speeds. Same thing goes for sidemarkers.
Grey is offline   Reply With Quote
Old 02-15-2002   #10 (permalink)
Mokushi
Member
Mokushi's Avatar
Mokushi is an unknown quantity at this point
Nice DIY phong! I would have done one myself after I made one for my car, but didn't have a digi handy. I have a question for you though. You have a coupe right? The reason I ask is that my friend asked me to make one for her 2k2 ex sedan and when I pulled the relay out and looked at it, I was like "WTF?" It looked totally different than my coupe's. Also, one of the damn parts on there heated up so much while I was experimenting, that it burned my darn finger. She still wants me to make one for her car, but do you know how to DIY it for the sedan?
Mokushi is offline   Reply With Quote
Old 02-15-2002   #11 (permalink)
ph0ng
Senior Member
ph0ng's Avatar
1. yes, 2k1coupe LX
2. no clue dude. I would assume to find the resistor with the highest resistance, like the 133k on the coupe, and try to attach the same or higher level resistor just like we did on the coupe. Or if not that, find where R1 is, and do the same, match the resistance of what ever it is and see what happens.
Strange they have a different design, but keep on experimenting. Worst that can happen, you blow a fuse or fry the relay...
Old 02-18-2002   #12 (permalink)
Blckcivic01
Member
Blckcivic01 is an unknown quantity at this point
Send a message via ICQ to Blckcivic01 Send a message via AIM to Blckcivic01
the 100K dont work its just solid and makes a bussin noise and the 150k dont buzz but are solid. goin wit some 180k thats really high but it might work
Blckcivic01 is offline   Reply With Quote
Old 02-21-2002   #13 (permalink)
Vinas
Member
Vinas is an unknown quantity at this point
<< 6. Before you seal up the caseing, go plug it into your fuse panell and test it out... Hurray, you now have a rice, I mean hyperblinker!
If you had pics in this thread I can't see them anymore, is there a URL with them?
Also, how fast do yours blink using that 150k resistor?
Vinas is offline   Reply With Quote
Old 02-23-2002   #14 (permalink)
ph0ng
Senior Member
ph0ng's Avatar
sorry there guys, had to mirror my pictures to another server.
As for how fast it was w/ the 150k resistor, mathmatically, its a little slower than 2x
and 133k would make it exactly 2x
Old 02-23-2002   #15 (permalink)
ph0ng
Senior Member
ph0ng's Avatar
<< K3wl, it works. I did everything but solder on a resistor to see if it worked. I was going to use a small potentiometer that would allow me to adjust it just the way I like it. >>
Thanks for the idea Grey, I took the 150k off and instead wired some 30 gauge wire off the 133k and cut a hole in the top of the box and wired it to a 200k potentiometer.
For those of you who don't know what a "pot" (potentiometer) is, it's basically an adjustable resistor. So a 200k pot will adjust from 0 ohms - 200k ohms. This way you can make your blink rate anywhere from almost normal to circut board frying fun fast.
Here's a pic installed.
Tags
7th , blinker , dim , diy , gen , headlight , hyperblinker , phong , rellay
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Looking for a 7th gen manual for free? (UPDATED!!!)
ALL of Grey's DIY's...
DIY: Trunk Shocks
Oil Changes
Detailed smoked out taillights DIY w/ pictures
DIY: tricked out trunk
DIY: No More Trunk Rattle!
SOHC VTEC Explained
DIY: Grounding kit Install
Ask Me About DIY Stuff V2!
Site Supporters
aluminum radiator
Honda car spoilers
