Honda Civic DIYs and Civic Tech ChatHonda Civic DIYs and Civic Tech Chat - for the true gearheads! Bring your wrench, it's time for some Honda Civic DIY projects! Questions about problems with your car do NOT go here.
Welcome to civicforums.com!
Welcome to civicforums.com.
Today I was driving my '01, and for some reason smoke started to come from the turn signal arm/column area. For some reason I turned the lights off, and it seemed to then stop, but that may be a coencodent.
There are no check engine lights, and everything still works.
Any idea as to what burnt up?
Sponsored Links
that my friend is probably u frying an electrical wire or a fuse popped for something by the driver side kick panel
__________________ 2006 RSX-S NHBP
2004 Civic LX coupe SSM sold... ....i miss it...
1984 AE86 sold
1987 AE82 corolla fx-16 (redtop swapped) no longer have
1993 K20A2 swapped EG sedan no longer have
1995 Eclipse (sold)
1986 AE86 Corolla (sold)
Your wire for your headlights is fried. There's a recall on the headlight switch assembly. take it to the dealer and they'll fix it. After my fix that wire still frys. You can pop the cover and see the fried wire for yourself.
__________________ If the room ain't spinning you ain't drunk.
^^ummm... YES! Think about that for a second... something is frying and smoke is coming out of your steering column.
hmmmmmmmmmmmmmmmm....
A friggen electrical fire can start in your car! Do you want your car to go up in flames? Better yet do you want to burn alive in your car?!
Go get that sh!t fixed!!!
I made my dealer switch it out but then that lil weird bulb on the headlight won't come on when a put on the park lights, changed the bulb and it still doesn't work took it to the dealer and they had to change the wiring no problems since.
If a wire burns out, that's it, it's done. Hence the reason why it only smoked for about 5 seconds. Do you really think it's constantly burning and smoking everytime I drive the car, .
.....And then the bare positive exposed wire that melted touches a part of your METAL engine bay (which is basically like touching two ends of a battery together).... gets grounded... short circuit.. BLAM. FIRE.
I think this was R1style's point.
__________________ Riceteam: Ricedat
Quote:
Originally Posted by PitchBlack
A blind squirrel finds a nut every once in awhile is all I'm saying...
