Go Back   Honda Civic Forum > GENERAL > Honda Civic DIYs and Civic Tech Chat
Honda Civic DIYs and Civic Tech Chat Honda Civic DIYs and Civic Tech Chat - for the true gearheads! Bring your wrench, it's time for some Honda Civic DIY projects! Questions about problems with your car do NOT go here.
Welcome to civicforums.com!
Welcome to civicforums.com.
Closed Thread
LinkBack Thread Tools
Old 12-19-2004   #16 (permalink)
es2
bubble party!!!
es2's Avatar
es2 can only hope to improve
Quote:
Originally Posted by Jrfish007
I didn't know the 7thegn EX where based on the VTEC-E... That's to bad So then I could take an HX ECM, put in my car and get 50+ MPG. BUt there was VTEC lean on the 92-95 civics too (or actually 94-95), just a not in passing
but doesn't a hx have no ac
__________________
"A B16 is a hard working minority - makes the most of it's time and is very efficient. ... While a B18C is a rich lazy ass white guy, who doesn't have much work to do at all - it's all done for him."-Katman
es2 is offline
Sponsored Links
Old 12-19-2004   #17 (permalink)
Civic04
Senior Member
Civic04's Avatar
Civic04 is an unknown quantity at this point
Send a message via AIM to Civic04 Send a message via MSN to Civic04
so normal running conditions (pre vtech) both exhaust valves open all the way and 1 intake valve opens all the way and 1 intake valve opens part way. When vtech kicks in under the preset conditions both exhaust valves open the same as before (becase no vtech on the exhaust side) and both intake valves open (fully) in the hotter cam profile .
Yes? No?
Civic04 is offline
Old 12-19-2004   #18 (permalink)
4drcivic2k1
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1's Avatar
4drcivic2k1 is an unknown quantity at this point
Yes.
4drcivic2k1 is offline
Old 12-20-2004   #19 (permalink)
C Orndorff
Once boosted now i-VTEC
C Orndorff's Avatar
C Orndorff is an unknown quantity at this point
Quote:
Yes? No?
VTEC dose nothing to exhaust on a SOHC motor. and the intake part is correct.
C Orndorff is offline
Old 12-20-2004   #20 (permalink)
Jrfish007
Jrfish007's Avatar
Jrfish007 is a name known to all Jrfish007 is a name known to all Jrfish007 is a name known to all Jrfish007 is a name known to all Jrfish007 is a name known to all Jrfish007 is a name known to all Jrfish007 is a name known to all
Send a message via AIM to Jrfish007
Quote:
Yeah they have no AC, no CD, no sun roof... basically a DX with a VTEC motor?
Jrfish007 is offline
Old 12-20-2004   #21 (permalink)
Jrfish007
Jrfish007's Avatar
Quote:
OKay so our newer (D17) motor has VTEC on the intake, but it simply uses to cam lobes instead on three like the D16's. Does the VTEC-E affect the exhuast then or not? IF not, how come they get such good gas milage? You can not possibly say they get 50+ MPG when I am getting around 32 with the same motor. I've played with plenty of ignition curves, fuel curves and such and you won't get much better than what the factory gives you (maybe 5 MPG better), but that was on a '94 D16. So there must be somehting much more than the ECU to get that kind of MPG.
Old 12-20-2004   #22 (permalink)
Jrfish007
Jrfish007's Avatar
Man, I hope this thread doesn't get into i-VTEC...
Old 12-20-2004   #23 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
I'm getting 20mpg max now does that mean my vtec is broken
gearbox is online now
Old 12-20-2004   #24 (permalink)
C Orndorff
C Orndorff's Avatar
NO SOHC VTEC Effects exhuast, ever. I am not just saying they are the same motor i know they are, just read the tech book pages I listed. If you took a HX and put a EX ECU in you would have a EX (almost the HX has one valve that dosent open as much but very very close)
Old 12-20-2004   #25 (permalink)
C Orndorff
C Orndorff's Avatar
Quote:
No your ECU will always follow the same fuel map (unless you are changing it with piggy back) thats why its bad to lower your VTEC without adding more fuel.
I get about 25mpg but thats because i run rc 550cc injectors with a buch of boost.
Old 12-20-2004   #26 (permalink)
aznboysrfr
DOHC i-VTEC TiMEX
aznboysrfr's Avatar
aznboysrfr has much to be proud of aznboysrfr has much to be proud of aznboysrfr has much to be proud of aznboysrfr has much to be proud of aznboysrfr has much to be proud of aznboysrfr has much to be proud of aznboysrfr has much to be proud of aznboysrfr has much to be proud of aznboysrfr has much to be proud of aznboysrfr has much to be proud of aznboysrfr has much to be proud of
gsr vtec crosses over at 4400 rpms.
__________________
恐怖を教えて野郎
aznboysrfr is offline
Old 12-20-2004   #27 (permalink)
gearbox
Super Moderator
Okay maybe you might know this. How exactly does our ecu work? I've heard things like if you reset it, all the fuel maps get erased and the manual just says do it for idle learn. I've reset it whenever adding or removing mods, and most of the time the idle is already fine. Is it true that the fuel maps have to be relearned, or are they a permanent part of the ecu. I'm also using a vafcII to add a little fuel under wide hi vtec maybe 1-2% correction due to it running lean in lower rpms.
Old 12-20-2004   #28 (permalink)
C Orndorff
C Orndorff's Avatar
No the ECU know the fuel and igniton maps permanently. Thats why swaping out ECU's within B motors is so popular. And if you put a D17A2 ECU on a D17A6 you would see some small gains. because the EX ECU is set with a better igniton and fuel map
Old 12-22-2004   #29 (permalink)
4drcivic2k1
I can tell you how that works if you like?
Old 12-23-2004   #30 (permalink)
C Orndorff
C Orndorff's Avatar
Here is how i-VTEC works. http://asia.vtec.net/article/ivtec/
Closed Thread
Tags
01 , 1996 , 2003 , cam , civic , d16y8 , dohc , forum , good , honda , retard , sohc , specs , timing , vtec
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Honda Civic Forum Replies Last Post
Sema Pics 2003 ( 56K killer ) PunkingCivic Off Topic 6 11-12-2003 11:52 PM
vtec from vtec3 civicRS General Automotive Discussion 19 01-30-2003 08:51 PM
engine codes Gizmo General Automotive Discussion 12 01-30-2003 04:51 PM
SOHC OR DOHC zagzig General Automotive Discussion 16 08-22-2002 11:30 AM
User Login
Our Partners
used new
Top 10 Threads
Looking for a 7th gen manual for free? (UPDATED!!!)
ALL of Grey's DIY's...
DIY: Trunk Shocks
Detailed smoked out taillights DIY w/ pictures
Oil Changes
DIY: tricked out trunk
DIY: No More Trunk Rattle!
SOHC VTEC Explained
DIY: Grounding kit Install
Need help with Radio Code
Site Supporters
aluminum radiator
Honda car spoilers
