Go Back   Honda Civic Forum > GENERAL > Honda Civic DIYs and Civic Tech Chat
Honda Civic DIYs and Civic Tech Chat Honda Civic DIYs and Civic Tech Chat - for the true gearheads! Bring your wrench, it's time for some Honda Civic DIY projects! Questions about problems with your car do NOT go here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 03-20-2005   #76 (permalink)
HyaBoosta
HyaBoosta's Avatar
Send a message via AIM to HyaBoosta
I doubt that the pressure sensor is keeping it from reving higher. I think it is a main harness problem To remove this ad, register today for free or log in if already registered!
HyaBoosta is offline   Reply With Quote
Sponsored Links
Old 03-20-2005   #77 (permalink)
exturbo6
Post Master General
exturbo6's Avatar
exturbo6 has a brilliant future exturbo6 has a brilliant future exturbo6 has a brilliant future exturbo6 has a brilliant future exturbo6 has a brilliant future exturbo6 has a brilliant future exturbo6 has a brilliant future exturbo6 has a brilliant future exturbo6 has a brilliant future exturbo6 has a brilliant future exturbo6 has a brilliant future
Send a message via AIM to exturbo6
so i guess i should have them check all both the harnesses. they didnt install the pressure senor b.c they said it didnt do anyhting. but im thinking since they didnt take out the icu fromt he tsi kit that the e-manage isnt working right. both are trying to work at same time. can this cause this not to work right? thanks steve
exturbo6 is offline   Reply With Quote
Old 03-23-2005   #78 (permalink)
NashVegasEX
Senior Member
NashVegasEX's Avatar
NashVegasEX is an unknown quantity at this point
HELP!!! I installed emanage and car would not get over 3800rpm ... Now car will not start ... It cranks but won't turn over ... Lemme know what settings to put up.. Right now its parked behind my work in a not so safe place and I could use some help ...
NashVegasEX is offline   Reply With Quote
Old 03-23-2005   #79 (permalink)
HyaBoosta
HyaBoosta's Avatar
make sure that your map sensor wires are hooked up right. away and to ecu. Make sure they have a really good connection too. That is whats is causing you to not rev above 3800. Make sure your rotary settings are correct too. make sure your rotary settings are right. and do not connect any of the vtec wires seeing as it does not work for our cars yet.
Old 03-23-2005   #80 (permalink)
NashVegasEX
Senior Member
Quote:
Much thanks .... on the main unit we installed everything except Yellow(VTEC in) and Light Blue(VTEC out) .... what about the purple VTM wire?
Old 03-23-2005   #81 (permalink)
HyaBoosta
HyaBoosta's Avatar
yeah the vtm wire is for the vtec too. you can leave that out as well. On the emenage I have that came from the DC5 greddy kit, it doesn't even have those wires on the main harness. Just remove that and make sure that the rpm wire is on the rpm wire and not the one that it says in the DIY. the rpm wire is in the top connector not con. A.
Old 03-23-2005   #82 (permalink)
NashVegasEX
Senior Member
when U say rpm wire, do you mean "Brown--RPM--Blue (Pinout 26, Con E)"? Thats how I wired it .... Engine Speed Pulse I guess it is?? Also for the rotary switches on an EX, should I use 4-8-c or 4-8-E? The support tool is updated to 1.13 and main unit to 1.39 ....
Old 03-23-2005   #83 (permalink)
HyaBoosta
HyaBoosta's Avatar
yeah you have the rpm wire in the right conn. The rotary settings for vtec are 4-8-E. so after you remove the vtec and vtm wire change the setting to 4-8-C
Old 03-23-2005   #84 (permalink)
NashVegasEX
Senior Member
ok thanks ... I have the ignition and injector harness's installed and the unit shows green Active LED and orange Interaction ... No flashing codes or anything ... I am using no map selects but I did do the throttle procedure ....
Old 03-23-2005   #85 (permalink)
HyaBoosta
HyaBoosta's Avatar
yeah all you have to do is set the TPS. You set the tps with the ignition in the on position but the car not cranked right? how is it running now?
Old 03-23-2005   #86 (permalink)
NashVegasEX
Senior Member
ok, In the support tool when I power up to the ON position, in main settings it doesnt have any of the blocks filled in . . . Also, the active light is green but the Interface light is orange even when the USB cable is unplugged ... My car hasnt started in a day now ..
Also, now when I look at the version number, I have firmware 1.13 and main unit -- --???
Old 03-23-2005   #87 (permalink)
HyaBoosta
HyaBoosta's Avatar
oooooo you need to go to the support tool and on the communication screen comes up click on the update main unit and when the file screen comes up click on the gsc file and hit ok and let it update. then it will load all the jumper settings and rotary to the emanage itself. then you'll be good. you might have some communication problems like I did. make sure it's on com port 3. if you have any other problems then PM me.
Old 05-18-2005   #88 (permalink)
mclean987
Diamond Member
mclean987 is an unknown quantity at this point
hi whats the advantage of a emanage over the vafc2 again ? oh yeh it can adjustignition timing anything else? can it change rev limit? is it muhc better than the vafc2 for all motor and boost?
mclean987 is offline   Reply With Quote
Old 05-18-2005   #89 (permalink)
dezod
7thgen Power Maker
dezod's Avatar
dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold
Send a message via AIM to dezod
Quote:
VAFC2 doesn't read boost, allow for as much tuning flexability, control timing, have a lap top support interface for ease of programming, have an anti-stall function, a boost cut limiter function...
E-manage w/ harnesses & support tool > VAFC
__________________
Constantly redefining the 7thgen Civic's performance... Dezod Motorsports.
7thgen Dedicated Section
Dezod Myspace
W: www.dezodmotorsports.com
P: 716-362-8771
E: sales@dezod.com
Aim: Dezod mtrsprts
dezod is offline   Reply With Quote
Old 06-21-2005   #90 (permalink)
dezod
7thgen Power Maker
dezod's Avatar
updated 1st post.....links fixed
__________________
Dezod Myspace
P: 716-362-8771
E: sales@dezod.com
Aim: Dezod mtrsprts
Tags
blinking , civic , emanage , forum , forums , gray , greddy , green , install , manage , pin , red , setting , tps , wire , yellow
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Looking for a 7th gen manual for free? (UPDATED!!!)
ALL of Grey's DIY's...
DIY: Trunk Shocks
Detailed smoked out taillights DIY w/ pictures
Oil Changes
DIY: tricked out trunk
DIY: No More Trunk Rattle!
SOHC VTEC Explained
DIY: Grounding kit Install
Need help with Radio Code
Site Supporters
aluminum radiator
Honda car spoilers
