Go Back   Honda Civic Forum > GENERAL > Honda Civic DIYs and Civic Tech Chat
Honda Civic DIYs and Civic Tech Chat Honda Civic DIYs and Civic Tech Chat - for the true gearheads! Bring your wrench, it's time for some Honda Civic DIY projects! Questions about problems with your car do NOT go here.
Welcome to civicforums.com!
Welcome to civicforums.com.
View Poll Results: Who does your oil change?
I do my own 500 68.21%
I take it to a quick lube place 116 15.83%
I take it to the dealership 117 15.96%
Voters: 733. You may not vote on this poll
LinkBack Thread Tools
Old 08-21-2004   #46 (permalink)
specter542
I'm NeonImpact's a55hat!
specter542's Avatar
specter542 should not be trusted specter542 should not be trusted specter542 should not be trusted specter542 should not be trusted
Send a message via AIM to specter542
change your own god damn oil, its not that hard.
i worked at jiffy lube this past summer btw.
specter542 is offline   Reply With Quote
Sponsored Links
Old 08-23-2004   #47 (permalink)
Pharoh
Bobaganoosh!
Pharoh's Avatar
Pharoh has much to be proud of Pharoh has much to be proud of Pharoh has much to be proud of Pharoh has much to be proud of Pharoh has much to be proud of Pharoh has much to be proud of Pharoh has much to be proud of Pharoh has much to be proud of Pharoh has much to be proud of Pharoh has much to be proud of Pharoh has much to be proud of
Send a message via AIM to Pharoh Send a message via MSN to Pharoh
good for you. Not everyone can be so blessed as to work at Jiffy Lube and change oil for a living.
Pharoh is offline   Reply With Quote
Old 08-23-2004   #48 (permalink)
specter542
specter542's Avatar
Quote:
i was changing my oil wel before being employed there...its truly not that hard. u drop the plug, let the oil drain, take the old filter off, lube the new one and put it on, plug the pan, add oil (3.7qts for a ex), start the car, check the level....my car is slammed too so i gotta go through all that hassle with the jack too.
Old 08-23-2004   #49 (permalink)
VP Stylee
Senior Member
VP Stylee's Avatar
VP Stylee can only hope to improve
Send a message via AIM to VP Stylee
crap i knew i forgot something, how bad is it if i forgot to lube the rubber thing on the filter before i put it on
VP Stylee is offline   Reply With Quote
Old 08-23-2004   #50 (permalink)
streetglower
7thGen Junkie
streetglower's Avatar
streetglower is a name known to all streetglower is a name known to all streetglower is a name known to all streetglower is a name known to all streetglower is a name known to all streetglower is a name known to all streetglower is a name known to all
Send a message via AIM to streetglower
Quote:
Probably not a big deal, but it might be hard to take it off next time you do a oil change
streetglower is offline   Reply With Quote
Old 08-23-2004   #51 (permalink)
specter542
specter542's Avatar
lubing the gasket creates a seal and a lubricated contact \point....my advice would be make sure u lube it next time
Old 08-24-2004   #52 (permalink)
SpeedDemon214
New Member
SpeedDemon214 is an unknown quantity at this point
Castrol Syntec 10W-30 with FRAM oil filter. works good enough for me
SpeedDemon214 is offline   Reply With Quote
Old 08-24-2004   #53 (permalink)
Jrfish007
Jrfish007's Avatar
Jrfish007 is a name known to all Jrfish007 is a name known to all Jrfish007 is a name known to all Jrfish007 is a name known to all Jrfish007 is a name known to all Jrfish007 is a name known to all Jrfish007 is a name known to all
Send a message via AIM to Jrfish007
Take to the dealer, they do it cheaper than I can ($10.99 with all the Honda parts and oil). I ask to see the oil every time though, don't know why? I'll be getting rid of my car before the warrenty is up.
They top all th efluid and wahs the car too.
Jrfish007 is offline   Reply With Quote
Old 08-24-2004   #54 (permalink)
pnoyster2k1cvic
Ultimate Member
pnoyster2k1cvic's Avatar
Send a message via Yahoo to pnoyster2k1cvic
I use Mobil 1 5w-30 Full Synthetic, I started doing my own oil change before the 35k maintenance, coz the bastards at the dealership's changing me 340buckets for it, even if I just changed my ac filter and i have no airfilter to be replace so I bought a case of 1quart Manual Transmission Oil, a honda oil filter, and a Mobil 1 5w-30 5quarts, and a gallon of coolant, and it came up to about 100+buckets
for the 35k maintenance I flushed my transmission fluid three times like the manual said, drained my radiator twice, changed my oil...
I still have about 8quarts of transmission oil, and about 2quarts of engine oil... I would never bring my car again to a dealership/or anybody for oil change... it's a bit messy but it's fun doing it, knowing that you DIY...
bring you used oil to any quick lube place like Jiffy Lube, Pepboys, Autozone... they will take your oil with no cost to you... save earth man! here's a link to where you dump your oil>>> http://www.earth911.org/master.asp?s...=1&serviceid=1
__________________
"Si Vis Pacem, Para Bellum"
"casus belli"
pnoyster2k1cvic is offline   Reply With Quote
Old 08-28-2004   #55 (permalink)
dragoon
Post Master General
dragoon's Avatar
Send a message via AIM to dragoon
do my own, because no damn shops can get under my car
__________________
2004 Berlina Black Honda S2000 Hardtopped
SOLD 2002 Turbo EM2
dragoon is offline   Reply With Quote
Old 08-28-2004   #56 (permalink)
ctx66
Super Member
ctx66 will become famous soon enough ctx66 will become famous soon enough
what kind of ghetto shops do you take it to that dont have a lift
ctx66 is offline   Reply With Quote
Old 08-29-2004   #57 (permalink)
slvrcivic
Super Member
slvrcivic's Avatar
slvrcivic will become famous soon enough slvrcivic will become famous soon enough
http://www.authorized-amsoil-dealer-...motor-oil.com/
slvrcivic is offline   Reply With Quote
Old 09-21-2004   #58 (permalink)
down_
Broken Arm, How Am I Suppost To Shift
down_'s Avatar
down_ should not be trusted down_ should not be trusted down_ should not be trusted
Send a message via AIM to down_ Send a message via MSN to down_
belive it or not.. honda oil filters actually have one of the best filter elemets.. and they use castrol so i just take it to them
down_ is offline   Reply With Quote
Old 09-21-2004   #59 (permalink)
civic2nr819
Senior Member
civic2nr819's Avatar
civic2nr819 is an unknown quantity at this point
mobil 1 and a fram filter every 3k.
__________________
04 ssm coupe
04 gsxr 600 (R.I.P.)
04 Z1000
civic2nr819 is offline   Reply With Quote
Old 09-21-2004   #60 (permalink)
Jrfish007
Jrfish007's Avatar
If you look on the Honda oil filter, it says FRAM. And like Down said, they use castrol synthetic blend.
And the deal where I live sells 3 filters for the price of two, so they are actually cheaper than a good quality filter form the auto store.
Tags
18 , 1997 , 2003 , 97 , blend , change , civic , crv , fuel , honda , interval , liter , mobil , oil , rail
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Looking for a 7th gen manual for free? (UPDATED!!!)
ALL of Grey's DIY's...
DIY: Trunk Shocks
Detailed smoked out taillights DIY w/ pictures
Oil Changes
DIY: tricked out trunk
DIY: No More Trunk Rattle!
SOHC VTEC Explained
DIY: Grounding kit Install
Need help with Radio Code
Site Supporters
aluminum radiator
Honda car spoilers
