Go Back   Honda Civic Forum > GENERAL > Honda Civic DIYs and Civic Tech Chat
Honda Civic DIYs and Civic Tech Chat Honda Civic DIYs and Civic Tech Chat - for the true gearheads! Bring your wrench, it's time for some Honda Civic DIY projects! Questions about problems with your car do NOT go here.
Welcome to civicforums.com!
Welcome to civicforums.com.
View Poll Results: Who does your oil change?
I do my own 500 68.21%
I take it to a quick lube place 116 15.83%
I take it to the dealership 117 15.96%
Voters: 733. You may not vote on this poll
LinkBack Thread Tools
Old 07-30-2009   #301 (permalink)
Cleft_Asunder
Super Member
Cleft_Asunder's Avatar
Cleft_Asunder is a glorious beacon of light Cleft_Asunder is a glorious beacon of light Cleft_Asunder is a glorious beacon of light Cleft_Asunder is a glorious beacon of light Cleft_Asunder is a glorious beacon of light Cleft_Asunder is a glorious beacon of light
Re: Oil Changes
My mom takes her 05 element to honda, but a couple oil changes ago the dip stick showed that it was overfilled. I don't know what to make of it. I wonder how difficult it is to do an oil change and filter swap on an element... To remove this ad, register today for free or log in if already registered!
__________________
'97 Civic DX 5-speed: Keyed to perfection.
http://www.civicforums.com/forums/signaturepics/sigpic34179_1.gif
Updated 96-00 timing belt DIY
Cleft recommends Raxles axles
Research the New World Order
Cleft_Asunder is offline   Reply With Quote
Sponsored Links
Old 08-19-2009   #302 (permalink)
ottotheclown
New Member
ottotheclown is an unknown quantity at this point
Talking Re: Oil Changes
Quote:
Originally Posted by btwracing View Post
I'll be honest and say that I take it to the dealer. I have time constraints plus insufficient working space at my apt.
I use Honda engine oil and tranny fluid to be on the safe side.
btwracing
Honda oil is Mobil 5000 dino.
ottotheclown is offline   Reply With Quote
Old 08-21-2009   #303 (permalink)
Matt300
New Member
Matt300 is an unknown quantity at this point
Re: Oil Changes
Quote:
Originally Posted by Running Riot View Post
jack stand work on dropped cars if you jack from the control arms or the front frame support. They make slim jacks for dropped cars. Im dropped 2.5" up front and 2.25 rear and my jack works just fine.
Ah, maybe I need to find me one of those then. I can get a regular jack under there, but I'm slightly scraping the front every time I want to get under the car. If I get down there and push up with my hands, we can slide the jack under.
Matt300 is offline   Reply With Quote
Old 08-22-2009   #304 (permalink)
Running Riot
Senior Member
Running Riot's Avatar
Running Riot will become famous soon enough
Send a message via AIM to Running Riot
Re: Oil Changes
Quote:
it is now. It used to be different. Classic/Coggin Honda in Orlando uses Penzoil. Penzoil = ick. Some others use Castrol. Castrol =
__________________
B16 10.4:1 JDM Pistons ITR Manifold 70.2mm Throttle Body Skunk2 Stage 1 Pro Cams AEM FPR DC Header Magnaflow Custom 2.5" exhaust BDL Fuel Rail Nology Individually Grounded Wires Fidanza 7.5lb Flywheel Exedy Clutch Goodridge Braided Steel Clutch Line Fidanza Short Shifter Skunk2 knob JUN Chip
IM SO JDM I EVEN HAVE SARS
Running Riot is offline   Reply With Quote
Old 08-23-2009   #305 (permalink)
Running Riot
Senior Member
Re: Oil Changes
I dropped 20lbs and it helped me slide under my car easier too lol
__________________
Old 10-10-2009   #306 (permalink)
hb pickup
New Member
hb pickup is an unknown quantity at this point
Re: Oil Changes
Oil changes suck after you'd had access to a lift for years & then U don't any more. I always put tin foil under the filter against the block like a funnel over the driveshaft to the drain pan. A LITTLe less mess
hb pickup is offline   Reply With Quote
Tags
18 , 1997 , 2003 , 97 , blend , change , civic , crv , fuel , honda , interval , liter , mobil , oil , rail
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Looking for a 7th gen manual for free? (UPDATED!!!)
ALL of Grey's DIY's...
DIY: Trunk Shocks
Detailed smoked out taillights DIY w/ pictures
Oil Changes
DIY: tricked out trunk
DIY: No More Trunk Rattle!
SOHC VTEC Explained
DIY: Grounding kit Install
Need help with Radio Code
Site Supporters
aluminum radiator
Honda car spoilers
