Go Back   Honda Civic Forum > GENERAL > Honda Civic DIYs and Civic Tech Chat
Honda Civic DIYs and Civic Tech Chat Honda Civic DIYs and Civic Tech Chat - for the true gearheads! Bring your wrench, it's time for some Honda Civic DIY projects! Questions about problems with your car do NOT go here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 01-14-2005   #136 (permalink)
abmerop18
Jam out with your clam out.
abmerop18's Avatar
abmerop18 has a brilliant future abmerop18 has a brilliant future abmerop18 has a brilliant future abmerop18 has a brilliant future abmerop18 has a brilliant future abmerop18 has a brilliant future abmerop18 has a brilliant future abmerop18 has a brilliant future abmerop18 has a brilliant future abmerop18 has a brilliant future abmerop18 has a brilliant future
shoot me a pm with what you think i need to do. i have to run somewhere now. To remove this ad, register today for free or log in if already registered!
__________________
abmerop18 is offline   Reply With Quote
Sponsored Links
Old 01-15-2005   #137 (permalink)
abmerop18
abmerop18's Avatar
anyone know what the problem could be????
__________________
Old 01-29-2005   #138 (permalink)
abmerop18
abmerop18's Avatar
How come my airflow meter pulse output says it is in use? How do i get it to read 'Not in use'? Also, what should my airflow meter change setting be at? We currently have it at HN_PR-1.
__________________
Old 05-09-2005   #139 (permalink)
Mex
Ultimate Member
Mex's Avatar
Mex is a jewel in the rough Mex is a jewel in the rough Mex is a jewel in the rough
Send a message via AIM to Mex
so has anyone tried the resistor idea for VTEC? my install is coming up here soon, within the next month. i'm trying to do as much research as i can before the install. i'll be running my ex @8psi on SLPs return fuel kit w/ rsx injectors
Mex is offline   Reply With Quote
Old 07-06-2005   #140 (permalink)
tfnaaf
BLDNPSI Mod
tfnaaf's Avatar
tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned
Quote:
Originally Posted by MadWheel
Ok guys, because Greddy has no idea how to translate things into English or write a working manual, many of us have had problems. Optoisolator and boosted2k2 have both got it to work great, BUT they have LX's. This is good and all, but they are wired completely different (except for the TPS, power, and ground). The jumpers are also VERY different.
Here's what you want to wire:
Emanage:------------------ECU:
Red ---- +12VDC-----Yelow w/Black stripe (pinout 2, connector A)
Black ---- GND--------Black (pinout 4, connector A)
Brown----RPM--------Blue (pinout 7 on connector A)
*Grey------TPS---------Red w/Black stripe (pinout 15 on connector A)
White---Map Input--Green w/red stripe (pin 19, conn A, away from ECU)
Green---Map Out----Green w/red stripe (pin 19, conn A, TO ECU)
**Yellow--VTEC IN-----Green w/yellow stripe (pin 15, conn B, TO ECU)
**Lt. Blue-VTEC OUT--Green w/yellow stripe (pin 15, conn B, AWAY from ECU
Purple---VTM Out----Blue w/black stripe (Pin 9, Conn B, TO ECU, cut and terminate signal from engine, the purple wire is to be soldered directly to the blue/blk wire going into the ECU. Tape off the cut part of the wire that is no longer connected to the ECU.
* - Greddy left the gray wire out of the wiring instructions. This is your throttle position signal.
** - THIS IS WHY MY CAR WAS MESSED UP. Greddy wrote the directions BACKWARDS for VTEC cars. Reverse what they say and you'll be golden.
Ok, after wiring in the harness, you need to set your Emanage switches and jumpers. You could have done this before the wiring, but it really doesn't matter yet.
Jumper settings:
JP1: 1-2
JP2: 1-2
JP3: 2-3
JP4: 1-2
JP5: see writeup...
JP6: (1-2) but because I didn't select them on the maps, it throws no codes
JP7: OPEN
---For jumpers 5 and 6, this is for sub injector controlling. I have mine enabled (1-2) but because I chose not to select the maps in the support tool software, it isn't doing anything differently. I did this because if I do use it as an injector controller, I don't have to open it back up again later to mess with the jumpers.
ROTARY Switches:
This has been debated/discussed for quite some time. 4-8-C works great on DX's and LXs, but within 2 hits of VTEC you have a CEL and an engine in limp mode. 4-8-E works VERY well. No codes, smooth idle, VTEC adjustment. This is the switch settings that you WANT for any 01-04 EX civic. It has been tried on my 5-speed boosted EX, and Dezod's currently NA Auto EX. So there's no debate that this setting won't work with an EX. It works flawlessly.
Suggestions: Buy an OBDII scanner (you can find them at autozone). It will come in handy and help you trouble shoot any problems you may have. Solder all of your connections. Don't take shortcuts but crimping unless it's only a temp thing. Soldering is the way to go, why risk it? I mounted my emanage in my center console behind the shifter. Very easy access and the wire lenghts are absolutely perfect.
That about sums it up. MAD PROPS TO DEZOD. He's the guy who went through all this hassle for 2 days on his own car to figure this out, and looked up quite a bit.
Here's some links for you guys:
Upgrade your firmware to V1.39 here:
FIRMWARE
Upgrade your Emanage software to V1.11 here:
SOFTWARE
Here's a pic of the mounted Emanage. Thanks again to Dezod for his support. Hopfully this writeup that took me over 30 min to do helps people out in the future. Good luck guys!
this has one small correction needed...You may want to revise your DYI i just found that the brown wire dont go to A-connector #7, it goes to E-connector #26 Engine speed pulse its a blue wire also. this may help on some installs where they are having issues with tunning. It should read as follows...
E-manage------------ECU
Brown----RPM--------Blue (pinout 26 on connector E, Engine speed pulse)
__________________
169.8whp / 154 ft lbs tq @ 7psi with an auto trans!
Click Image for my turbo install!
Or
Check out my 1966 OLDS 442 Project in the works!
DIY Mechanical O2 simulator
DIY Head gasket
DIY Front Wheel Bearing
How to tune short term/long term fuel trim
tfnaaf is offline   Reply With Quote
Old 07-14-2005   #141 (permalink)
BlackFire
Senior Member
BlackFire is an unknown quantity at this point
Then wich cable of the e-manage goes into the A-Connector #7??
BlackFire is offline   Reply With Quote
Old 07-14-2005   #142 (permalink)
tfnaaf
BLDNPSI Mod
tfnaaf's Avatar
Quote:
There is no set cable for connector "A" you just have to follow the DIY and IMO all but the RPM as stated above
__________________
Or
DIY Head gasket
Old 11-05-2005   #143 (permalink)
DaRk_MauL
Super Member
DaRk_MauL is a glorious beacon of light DaRk_MauL is a glorious beacon of light DaRk_MauL is a glorious beacon of light DaRk_MauL is a glorious beacon of light DaRk_MauL is a glorious beacon of light
Send a message via MSN to DaRk_MauL
so i have same problem connecting to main unit. i just put in the power and ground wires.so the emanage has power
(green active led on) connect the usb/serial connector en run the support tools.
Wen the support tool is done opening the active led goes off.support tool is saying online.but i can not update main unit.
it not interacting
I updated it to this:
updated the emanage.
support tools 1.25
emanage version ..-..
update version 1.47How can i connect because i have to reset the unit.
__________________
http://users.telenet.be/seriousspace/Jdmvicbanner.jpg
NA [I/H/X]:15.68sec on 1/4 mile
boosted: not yet
DaRk_MauL is offline   Reply With Quote
Old 11-05-2005   #144 (permalink)
DaRk_MauL
Super Member
I Tried alot in the mean time but it just wont connect.
__________________
boosted: not yet
Old 11-08-2005   #145 (permalink)
dezod
7thgen Power Maker
dezod's Avatar
dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold
Send a message via AIM to dezod
Check your serial to USB adapter. The GReddy cable is real selective with them.
__________________
Constantly redefining the 7thgen Civic's performance... Dezod Motorsports.
7thgen Dedicated Section
Dezod Myspace
W: www.dezodmotorsports.com
P: 716-362-8771
E: sales@dezod.com
Aim: Dezod mtrsprts
dezod is offline   Reply With Quote
Old 11-08-2005   #146 (permalink)
DaRk_MauL
Super Member
i dont use a serial to usb adapter only the cable that came with the
emanage.
__________________
boosted: not yet
Old 11-21-2005   #147 (permalink)
BlackFire
Senior Member
Any real solution for the "VTEC Input Error" (Code 14) on the e-manage on EXs??
I really want to make it work before installing my turbo kit.
I'm using Dezod's PnP Harness and I have the same error as all other EX owners. No CEL but still having that Error Code 14 on e-manage (VTEC Input Error).
Jumper settings exactly as in this thread.
Rotary settings: 4-8-E
Versions:
Support Tool: 1.20
Firmware: 1.40
Airflow meter: Tried every settings: from HN_PR-1 to HN_PR-5 and I have the same error on each of them.
I did not found the 820ohm, 1w resistor but tried an 1k ohm, 1w resistor and still having the same error, did not noticed any change in the Input behavior so the resistor have been removed.
Some of you might think that PR versions of the EM2 are different than US but it is not. It is exactly the same version as US.
Please let me know what else can I try?
Since I have the PnP harness by Dezod I don't know what to do to make the OEM ECU control the VTEC again if I don't get it to work properly.
Old 12-26-2005   #148 (permalink)
maxquebec
New Member
maxquebec's Avatar
maxquebec is an unknown quantity at this point
bUT Some one do you know a solution to correct Vtec with E-manage ??
maxquebec is offline   Reply With Quote
Old 12-26-2005   #149 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
hmm this sucks. i wanted the pnp harness but if it has problems i dunno
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is online now   Reply With Quote
Old 04-14-2006   #150 (permalink)
04_CIVIC_HFP
Member
04_CIVIC_HFP's Avatar
04_CIVIC_HFP is an unknown quantity at this point
Send a message via MSN to 04_CIVIC_HFP
can i have pics of the emanage installed. I need to know where all the wires go and it is pissing me off. So if anyone has pics shoot me up please.
__________________
civicseven.com
04_CIVIC_HFP is offline   Reply With Quote
Tags
04 , 05 , 06 , aav , adjusting , blue , civic , emanage , error , jp7 , jumpers , rotary , rx8 , setting , settings , software , switch , vtm
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Looking for a 7th gen manual for free? (UPDATED!!!)
ALL of Grey's DIY's...
DIY: Trunk Shocks
Detailed smoked out taillights DIY w/ pictures
Oil Changes
DIY: tricked out trunk
DIY: No More Trunk Rattle!
SOHC VTEC Explained
DIY: Grounding kit Install
Need help with Radio Code
Site Supporters
aluminum radiator
Honda car spoilers
