Honda Civic DIYs and Civic Tech ChatHonda Civic DIYs and Civic Tech Chat - for the true gearheads! Bring your wrench, it's time for some Honda Civic DIY projects! Questions about problems with your car do NOT go here.
Welcome to civicforums.com!
Welcome to civicforums.com.
Autocross: Because Life is more fun on three wheels......
"I know Solo only comes one minute at a time, but what an intense, non-stop, fast-forward car control exercise minute it is. Sure, the velocity is higher in road racing, but inside the car it is slow-motion in comparison. In Solo, the turns come like machine-gun rounds. "
Randy Pobst
You don't want the engagement point too high or in the future it might slip on you. Somewhere near the middle usually works best. But, I haven't tinkered with mine yet so I can't help you. Too bad it's hydraulic and not cable, those are cake.
I have an idea on how to do it on older Civics, there is a screw around where the clutch pedal and firewall meet and can be adjusted there, dont know if that works for the 7thgen
__________________ 7thGen.MT.C.
Quote:
Originally Posted by SkipBarber
cheap, easy mods + D17 + good hp gains = not possible. it's an oxymoron.
Quote:
maybe i've turned a ricer down the right path today.
I tried that but It just kinda lowers the clutch physicaly. the Engagement part is still up way up...
Does honda have the capabilities to lower the clutch? even if it's hydraulic?
Thanx
I know how to lower the clutch already inside the car the part where the clutch kinda hydraulic gold shaft thing below the car.
first you just untighten the nut then adjust it lower to lower the engagement. I had to learn this from my bro, he knows how to adjust since he drives an Si and he lowered his clutch engagement also.
it's not just the physical height I'm talking bout here there are 2 adjustments that can be done right on the clutch inside the car, there is this but and bolt type of adjustment which is in front of the clutch pedal... when you see it it's also gold colored nut and bolt... this is just to adjust the physical height... don't adjust this till you've adjusted the shaft first...
the shaft is what the clutch pedal pushes... it's a gold colored metal shaft with a nut located near the pedal side and not the firewall side. untighten the nut then tighten the shaft inwards to lower the clutch engagement.
then adjust the front nut and bolt to lower the pedal physically so that there won't be that much slack when you depress the pedal.
__________________ 01 ES2, if you dont know what that is.. SEARCH
78 X1/9, if you dont know what that is.. i dont blame you
Honda Trained Technician
Project 5lug: Coming Soon
