Go Back   Honda Civic Forum > GENERAL > Honda Civic DIYs and Civic Tech Chat
Honda Civic DIYs and Civic Tech Chat Honda Civic DIYs and Civic Tech Chat - for the true gearheads! Bring your wrench, it's time for some Honda Civic DIY projects! Questions about problems with your car do NOT go here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 07-06-2004   #1 (permalink)
brad M
New Member
brad M is an unknown quantity at this point
not going past 4000 rpm
gone thru the all data tests on vtec code, and it says to replace ECM. does anyone know want the hell is going on with these cars because i see alot of people are having the same problems. any help would be great. To remove this ad, register today for free or log in if already registered!
brad M is offline   Reply With Quote
Sponsored Links
Old 07-06-2004   #2 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
I'm assuming the car is stock. There have been issues with the ecm going out, but very rarely. So you did an ODBII diagnostic and it says replace the ecm? It might also be the vtec solenoid, but it's hard to tell. If your car is under warranty, just take it back and have them fix it.
__________________
________________________________________
Restore Performance, Reduce Costs
www.lubecontrol.com
LC20 - go 10k miles on a single oil change
Go Here For Real Medicine
http://www.youngliving.com
Member 1025782
The DX-Resource
http://bellz.sqweebs.com/
gearbox is offline   Reply With Quote
Old 07-06-2004   #3 (permalink)
Samari
Ultimate Member
Samari's Avatar
Send a message via AIM to Samari
that sucks man, i hope it warrentied though. good luck with that.
Samari is offline   Reply With Quote
Old 07-06-2004   #4 (permalink)
tinman
tinman's Avatar
tinman is just really nice tinman is just really nice tinman is just really nice tinman is just really nice tinman is just really nice
4000 rpm is limp-home mode. Something is telling the ECU to go into this safe mode.
If the ECU is indeed bad, you are running on the back-up chip. Honda ECU's have a fail-safe. What codes are you getting?
tinman is offline   Reply With Quote
Old 07-07-2004   #5 (permalink)
SuperFrankie
SuperFrankie's Avatar
SuperFrankie should not be trusted
Send a message via AIM to SuperFrankie Send a message via Yahoo to SuperFrankie
i have to replace the ecm in my 97 ex my tranny isn't shifting right and it was traced back to that
SuperFrankie is offline   Reply With Quote
Old 07-08-2004   #6 (permalink)
KaZeLL
Ultimate Member
KaZeLL's Avatar
KaZeLL will become famous soon enough
Send a message via AIM to KaZeLL Send a message via MSN to KaZeLL
do me a favor and check the oil...and pm me to let me know if it was empty....
__________________
jazell26@hotmail.com
If you need me
KaZeLL is offline   Reply With Quote
Old 07-10-2004   #7 (permalink)
supermex
supermex's Avatar
supermex is a name known to all supermex is a name known to all supermex is a name known to all supermex is a name known to all supermex is a name known to all supermex is a name known to all supermex is a name known to all supermex is a name known to all
I had the same problem and it was the crank sensor broken.
But the computer does the same if any crucial sensor is bad.
Is like tinman said is on a safe mode
__________________
MY SHOW CAR IS FASTER THAN MY JDM CAR...FOR NOW
NX & AEM sponsored car.
2004 HONDA TUNING featured car.
1st Place at NOPI Nationals 2006
1st Place Funk Master Flex 2007
1st Place HIN's Night Shift 2007
434.3 hp 352 Lbs torque @ 21 Psi fully build D17A1
CARS WEBSITE
DRIVEN!
supermex is offline   Reply With Quote
Old 07-10-2004   #8 (permalink)
brad M
New Member
problem solved :)
finally found out what was causing my CEL coming on and not going over 4000RPM. CEL code was P1259 vtec melfunction. went trough all the trouble shooting step by step and was getting mad that everything was checking out fine but said the computer needed to be updated or replaced. after hours of trying everything i finally pulled off the valve cover to inspect rocker ass. turns out that on the intake side of rocker's by cyl. 4 on top of rocker ass. is a 14mm bolt that blocks off a hole for oil passage for vtec. the bolt back out letting the pressure bleed of and causing CEL to come on. finally i can rev out with no problem and enjoy my tuning that i did.
Old 07-11-2004   #9 (permalink)
tinman
tinman's Avatar
Interesting cause.... have to write that one down. Thanks for posting that.
Old 07-11-2004   #10 (permalink)
KaZeLL
Ultimate Member
KaZeLL's Avatar
nice glad you solved...
__________________
If you need me
Old 07-11-2004   #11 (permalink)
Hatorade
SPLAT!!!
Hatorade is an unknown quantity at this point
^^^ yea thats really good to know. i need to save this post just in case glad to see it was an easy cheap fix.
Hatorade is offline   Reply With Quote
Old 07-14-2004   #12 (permalink)
tugboat
New Member
tugboat is an unknown quantity at this point
Send a message via AIM to tugboat
i hve 2001 civic ex and got the same code P1259 and my car revs only to 4000rpm and won't let it go over 80mph (it sucks) Brad M was your car a 2001?. I guess i Might have the same problem u had.
tugboat is offline   Reply With Quote
Tags
p1259
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Looking for a 7th gen manual for free? (UPDATED!!!)
ALL of Grey's DIY's...
Need help with Radio Code
Detailed smoked out taillights DIY w/ pictures
DIY: Trunk Shocks
Oil Changes
SOHC VTEC Explained
DIY: tricked out trunk
DIY: No More Trunk Rattle!
DIY: Grounding kit Install
Site Supporters
aluminum radiator
Honda car spoilers
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
