Honda Civic DIYs and Civic Tech ChatHonda Civic DIYs and Civic Tech Chat - for the true gearheads! Bring your wrench, it's time for some Honda Civic DIY projects! Questions about problems with your car do NOT go here.
Welcome to civicforums.com!
Welcome to civicforums.com.
When I am in between 3000 and 3500rmps my engine makes like a lound vibrating noise or something. Pretty high pitched. You drop below 3000 or go over 3500 and it immediately goes away. It sounds a lot louder when it is really cold and when it is hot out it sounds like it is totally gone? What the hell is it?
Sponsored Links
it could be the crank pulley or other pulleys... i have the same problem but its cuz i didn't lubricate when i installed my rvm pulley... it is gone when its hot outside, and loud when its cold outside...
oh and try turning on the a/c... if it gets louder, then it really is one of the pulleys... cuz when i turn on my a/c, it gets really loud... but if not, then maybe its something else...
Well i just tried the AC thing. I didn't notice it getting any louder. mmm, not sure. But thaks for your help CivicHX, i'll check to see if the pulleys are problem
I heard it on my car before, a few times when it was cold. Never hot.
I just figured It was some vibration that came from the vtec engaging, or maybe not deciding to be on or off because of the cold? Maybe it is the vtec NOT engaging because of the cold, and the engine gets a slight out of breath sound starting about that rpm? Maybe above 3500 vtec is forced on no matter what as a saftey thing so one could um... accelerate if they really needed to.
I noticed you have an EX as do I (with vtec), and civicHX01 has the super econo vtec. Anyone with a VP, LX or DX (non-vtec civic) ever hear this noise?
A bold huh? I guess i could just take it to a shop and have them check it out. I'll probably take it in on monday. I'll let you guys know what the final verdict is on that freaky noise.
i have an LX and i got the same noise, i had it before i put my pulleys on and after i put them on its still the same so i dont think its my pulleys, i've been told it was either that i need a valve adjustment or something w/ the exhaust up front like header or heat shield .. im still up for more suggestions cause i dont know exaclty what it is and i dont have the money to go have something fixed if thats not what it is.
how many people have had this problem?? maybe we can complain to honda and get a recall or something for the people who have it and are still totally stock
i started hearing it about 60000 miles, i had my timing belt replaced the same time i put my pulleys on bout 2 weeks ago at 85000 miles, but i still hear it .. like a quick tapping noise.
i'll try to get a free diagnostic from a shop and then i'll post what they said it was
Sorry to revive a dead thread but my civic is starting to make a vibrating noise like this when I accelerate. Did anyone figure out what the problem is????
vibrating noise when accelerating.. most likely a motor mount.. check for this by holding the brakes and loading the engine in a gear, and have someone check out hte engine rocking back and forth
usually the front mount is busted.. ive replaced mine twice then i put energy poly inserts in
__________________ 01 ES2, if you dont know what that is.. SEARCH
78 X1/9, if you dont know what that is.. i dont blame you
Honda Trained Technician
Project 5lug: Coming Soon
Check the hood. With the hood closed, raise the front up and down. If there's play, lower the bracket. If bracket is as low as it can go, dremel the holes longer at the top.
