Go Back   Honda Civic Forum > GENERAL > Honda Civic DIYs and Civic Tech Chat
Honda Civic DIYs and Civic Tech Chat Honda Civic DIYs and Civic Tech Chat - for the true gearheads! Bring your wrench, it's time for some Honda Civic DIY projects! Questions about problems with your car do NOT go here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 02-21-2004   #1 (permalink)
somean2
Member
somean2 is an unknown quantity at this point
Send a message via ICQ to somean2
need help on racing seat install
i just bought 2 after market seat which came with slider. i search forums, but didn't find much about seat swap. anyway, i run into 2 problem............
1st bracks????
i took out the passager seat and unplug the wires. since my new seats only came with slider. do i need new brackets? i am thinking custom make. which one will be better??????? if i need new brackets, where could i buy them for cheap??????
2nd seat belt??????
i disconnet the seat belt buckle from my stock passager seat. i have NO IDEA how could i bolt on to my new seat...... what did you guys do.
3rd posting pic on forums
i took a few pictures but i have no idea how to post it. can anyone help.
i really hope that someone could help me on this. i am really looking forward to have to in my car. thanks people.................[
somean2 is offline   Reply With Quote
Sponsored Links
Old 02-21-2004   #2 (permalink)
scatman
05 600RR - 118hp/360lbs.
scatman's Avatar
scatman is a splendid one to behold scatman is a splendid one to behold scatman is a splendid one to behold scatman is a splendid one to behold scatman is a splendid one to behold scatman is a splendid one to behold scatman is a splendid one to behold scatman is a splendid one to behold scatman is a splendid one to behold scatman is a splendid one to behold scatman is a splendid one to behold
Send a message via AIM to scatman
go to carxpressions.com and buy some brackets, its worth it...they're like 30-35 bucks a piece...what kind of seats did u buy, my tenzo's came with a spot to mount the oem seatbelt , but i didnt hook it up, i just plugged everything back in with the oem seat belt buckle hiding under the seat where it cant be seen
scatman is offline   Reply With Quote
Old 02-21-2004   #3 (permalink)
2k2redcivic
2k2redcivic's Avatar
2k2redcivic has a spectacular aura about 2k2redcivic has a spectacular aura about
Send a message via AIM to 2k2redcivic
what did you guys do about the airbag sensor wire?? i know if you run it without connecting it, it will throw a airbag code. or is there someway to bypass it
__________________
dynoed @ 162whp @ 4lbs
with a nast bend in my intercooler pipe f'in up my spool up.
lots of parts forsale turbo and n/a
http://www.7thgencivic.com/forums/showthread.php?t=185584
http://www.7thgencivic.com/forums/showthread.php?t=188027
http://www.7thgencivic.com/forums/showthread.php?t=179543
VISIT MYSPACE!!! http://www.myspace.com/18854606
2k2redcivic is offline   Reply With Quote
Old 02-21-2004   #4 (permalink)
WhiteCastle
WhiteCastle's Avatar
WhiteCastle is a glorious beacon of light WhiteCastle is a glorious beacon of light WhiteCastle is a glorious beacon of light WhiteCastle is a glorious beacon of light WhiteCastle is a glorious beacon of light WhiteCastle is a glorious beacon of light
Send a message via AIM to WhiteCastle
you need some universal brackets like he said. make sure to disconnect wires under the seat , than once you have your seats pulled out unbolt the stock seatbelt holders bolt them on. In reality its very very easy to instal new seats.
Almost if not as easy as an air intake.
WhiteCastle is offline   Reply With Quote
Old 02-21-2004   #5 (permalink)
somean2
Member
ok thanks guys. i guess i have to order brackets. but i still ahve no idea how to mount the seat belt
also, is the bracket selling at carxpressions.com universal? will my seats able to bolt on them?????? thanks a lot guys
Old 02-22-2004   #6 (permalink)
WhiteCastle
okay for the seat belt, you can directly unbolt it from your current seats.
very easy be carefully doing this becuase that long black shaft part says explosive . anways once you get your brackets you might need to bend the tip just a little on the part that inserts into the bracket so you can get a tight fit.
I just bent it slightly on the cement than torque it in. note: nothing fits like it should with aftermarket parts ever!
just make sure bracket says universal or you can order a pair through tenzo. They are extremely cheap.
Like I said remember only four bolts and 2 plugs in removing the seat.
Remove plugs under the seat first. They can be reused with your buckets so your SRS light doesnt go on.
Old 02-22-2004   #7 (permalink)
somean2
Member
thank you very much WhiteCastle. i know what i am doing now. now i am want to know if the tenzo selling at carxpression.com are universal. i just email them. hopefully i will get an answer soon. thank you very much everyone
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Looking for a 7th gen manual for free? (UPDATED!!!)
ALL of Grey's DIY's...
DIY: Trunk Shocks
Detailed smoked out taillights DIY w/ pictures
Oil Changes
DIY: tricked out trunk
DIY: No More Trunk Rattle!
SOHC VTEC Explained
DIY: Grounding kit Install
Need help with Radio Code
Site Supporters
aluminum radiator
Honda car spoilers
