Go Back   Honda Civic Forum > GENERAL > Honda Civic DIYs and Civic Tech Chat
Honda Civic DIYs and Civic Tech Chat Honda Civic DIYs and Civic Tech Chat - for the true gearheads! Bring your wrench, it's time for some Honda Civic DIY projects! Questions about problems with your car do NOT go here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 07-22-2003   #136 (permalink)
slamtank
Super Member
slamtank's Avatar
slamtank is an unknown quantity at this point
how do u think about this item(bottom - entire gold)?
its $16 at Circuit city and $3 on ebay.
a guy at circuit city said its good cuz its gold which conduct better and its reuseable since its bolt on type.
compare this one to another one..
which one do u think is better?
slamtank is offline   Reply With Quote
Sponsored Links
Old 07-22-2003   #137 (permalink)
YS
Platinum Member
YS's Avatar
YS is an unknown quantity at this point
Send a message via ICQ to YS
the bottom one BUT to expensive .............
but if its only $3 on ebay just get the bottom one ........... why do you want the re-useable one?
YS is offline   Reply With Quote
Old 07-22-2003   #138 (permalink)
slamtank
Super Member
slamtank's Avatar
i dont care about reuseable thing but the bottom one is thicker than upper one.. its about 7mm..if the bolt is short it would make problem but i think i will be okay cuz nobody will make it if its thickness cause any problem..
is it okay that the bottom one doesnt have rubber part? whole surface of that one is gonna conduct electricity..is that fine? when 2 or 3 of them overlap at negative terminal?
Old 07-23-2003   #139 (permalink)
YS
Platinum Member
YS's Avatar
it's ok ........ it's GROUND cable right??? the whole body is the ground ......
Old 07-27-2003   #140 (permalink)
eni9ma
Member
eni9ma's Avatar
eni9ma is an unknown quantity at this point
Thumbs up
You guys inspired me to do this mod and so I did. I felt a slight improvement but mainly in the speakers. All in all it was worth it.
$20.00 for 4 gauge wire from Ebay.
$5.00 for the ring terminals from Home Depot.
$6.00 for some Heat Shrinks from Home Depot.
TOTAL $31.00 *Not bad*
Here are some pictures:
INSTALL
__________________
eni9ma is offline   Reply With Quote
Old 07-27-2003   #141 (permalink)
Grey
DIY King
Grey's Avatar
Grey has a spectacular aura about Grey has a spectacular aura about
Send a message via AIM to Grey
Looks good eni9ma!
Quote:
Originally posted by jjj784
here's my $.02. in a way, hks reduces resistance more than happies. why? because they are wired in parallel instead of serial. it gives current a better path to follow.
parallel: 1/r1 + 1/r2 + 1/rn = 1/r total
serial (daisy chain): r1 + r2 + rn = r total
who knows, maybe i'm wrong. maybe the difference is next to nothing.
It's not as easy as that. I think it's easier to think of it this way... The negative battery terminal is essentially the ground for the car. A stock car has this terminal wired to the chassis. All of the electrical components in the car have to have a ground for them to work. They have to be wired to the negative battery terminal for them to work. A large copper wire might be a better conductor than the steel chassis. You'll have a better conduit for the electrons. They'll have a shorter path and less resistence.
That's why a parrallel network might be better than a series network. Then again, there's another issue here. A daisy chain is basically one cable in series with connecting points to the chassis. So... The electricity has a choice. It will take the path of least resistence. That might be directly through the chain of wire into the negative battery terminal, but it might also be through only some of the wire into the chassis and then through the chassis into the negative battery terminal. The problem is that we don't know which one is more optimal. That's why letting the electrons decide might be the best bet.
It's a complex issue, and I have no clue how multiple electrical components wanting the same circuit at the same time affect the whole system? ??? Using parrallel connections would theoretically get rid of this "issue", but we'de need to be sure that the cable is better for the electrons to flow through than the chassis is. If we knew that for sure, then we could be sure that the parrallel system (HKS style) was the optimum one.
Grey is offline   Reply With Quote
Old 07-27-2003   #142 (permalink)
cdmx
Post Master General
cdmx's Avatar
cdmx will become famous soon enough cdmx will become famous soon enough
Send a message via AIM to cdmx
Quote:
Originally posted by gearbox
I tried upgrading the stock engine to radiator support wire and the car didn't like it. It wasn't as quick off the line. Strange. It seems like the car has good days and bad. Sometimes it will drive so much faster for no apparent reason. ..But that's an entirely different problem.
Its the weather, on a cool day my car drives awesome...i love cool days
cdmx is offline   Reply With Quote
Old 07-27-2003   #143 (permalink)
cdmx
Post Master General
cdmx's Avatar
Quote:
Originally posted by slamtank
am i good to go with this?
click
what about gold plated ring terminal?
i found some of them on ebay..they were about $2.50~3.50 per pair.
is that a good price?
No Just cause its made by stinger doesn't mean its better...Go with the 0.99 cent 2058 OFC strand wire...Much better beacuse of the wire count. here is a link...check out his other auctions. http://cgi.ebay.com/ws/eBayISAPI.dll...ory=32810&rd=1
Old 07-27-2003   #144 (permalink)
cdmx
Post Master General
cdmx's Avatar
gearbox said autozon has 10 gold ring terminals for $10.00
and what i saw on ebay was 2 gold ring terminals $2.50 - 3.00
and i guess ebay usually has cheaper prices..is there any reason like gold quality or something?
if you buy in more bulk its gonna be cheaper. Thats a decent price for those terminals....
Check out www.partsexpress.com but im still trying to find a cheaper place
Old 07-28-2003   #145 (permalink)
slamtank
Super Member
slamtank's Avatar
www. part sex press .com
thats what i thought when i looked at it
Old 07-28-2003   #146 (permalink)
slamtank
Super Member
slamtank's Avatar
if theres any better thing even if its only look
i'd spend $0.23 more per foot
also, shipping is free on stinger one
Old 07-28-2003   #147 (permalink)
slamtank
Super Member
slamtank's Avatar
INSTALL
what is heat shrinks?
is it a rubber thing that covers wire and terminal preventing short?
Old 07-28-2003   #148 (permalink)
cdmx
Post Master General
cdmx's Avatar
I just figured out that happies kit is ALOT LESS HASTLE than what im going through now. The wire was cheap but finding gold ring terminals is hard...It comes out cheaper but its alot of hastle.
AUTOZONE DOES NOT CARRY GOLD RING TERMINALS atleast mine dont
pepboys does in quatity of 2 for about 5.99
circuity city charges 4.99 for 2
same for best buy
Radioshack caries Sh|t
and this guy at car audiomasters wanted like 30, 40 bucks for 20 pieces(im making 2 kits)
AND i was at home depot and lowes they only sell tin plated copper terminals which is not what we want. The gold ring terminals are much better.
SO the only place left is to buy online...i found some places but im waiting on them to email me.
SO far i spent $26.78 on 22 feet of 4 gauge 2058 strands of OFC wire.
Ive got all the tools so only thing left are the terminals.
I'll keep u guys posted on what i find (BUT I STILL SUGGEST TO GO WITH HAPPIES KIT.........I WISH I DID!)
Old 07-28-2003   #149 (permalink)
cdmx
Post Master General
cdmx's Avatar
never noticed that!!
Old 07-28-2003   #150 (permalink)
cdmx
Post Master General
cdmx's Avatar
oh man i just bought 2 gold battery terminals, they cost me 30 bucks but i just couldn't pass it up. They accept 0/1 gauge, 1 4 gauge, and 2 8 gauge. woo im gonna have a pretty gounding kit.....(i saw these terminals for like 25-30 each at circuity city) I luv ebay
Tags
2003 , 2006 , car , civic , diy , ground , grounding , honda , hyper , information , install , kit , si , valves , wire
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Looking for a 7th gen manual for free? (UPDATED!!!)
ALL of Grey's DIY's...
DIY: Trunk Shocks
Detailed smoked out taillights DIY w/ pictures
Oil Changes
DIY: tricked out trunk
DIY: No More Trunk Rattle!
SOHC VTEC Explained
DIY: Grounding kit Install
Need help with Radio Code
Site Supporters
aluminum radiator
Honda car spoilers
