Go Back   Honda Civic Forum > LOCAL/GEOGRAPHIC FORUMS > California > South Cali
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 04-22-2004   #1 (permalink)
VtecViXen
Guest
Posts: n/a
Rough Idle
Hey I was talkin to a homie on 7thGen today and seems we have a similar problem with rough idle'ing... for some reason Im not idling high or anything, just rough, and it gets loud like every couple minutes for like 30 secs or something. Ive heard alot of people with something similar. Replaced the battery thinking it may be that, no. Checked my spark plugs, good there. And i dont know what the problem could be. Honda doesnt seem to know either. To remove this ad, register today for free or log in if already registered!
Sponsored Links
Old 04-22-2004   #2 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
Rough idle can be caused by a number of things. Iridium plugs will improve it, but you may also want to check your ground wire connections and maybe even upgrade them. There's one to the tranny and chassis, and another one from the engine to chassis (silver I think). Make sure connections aren't corroded.
gearbox is offline   Reply With Quote
Old 04-22-2004   #3 (permalink)
VtecViXen
Guest
Posts: n/a
only other thing we could think of is maybe the ECU
Old 04-22-2004   #4 (permalink)
MangoEX
Just Be
MangoEX's Avatar
MangoEX should not be trusted
Send a message via AIM to MangoEX
My guess is ECU...
MangoEX is offline   Reply With Quote
Old 04-22-2004   #5 (permalink)
MangoEX
Just Be
MangoEX's Avatar
no sounds like her problem goes beyond spark plugs and grounding wires, especially if she hasn't touched those from the factory. I'd start at the engine/tranny mounts, then work my way to the ecu
Old 04-22-2004   #6 (permalink)
gearbox
Super Moderator
You could try resetting the ecu by pulling the battery for 5 mins, then reconnecting and just let the car idle for 10 mins. Then turn it off and back on to go drive.
But check the ground wire (silver one). It grounds the ECU.
Old 04-22-2004   #7 (permalink)
gearbox
Super Moderator
Good idea. It may be engine mounts or something that's causing vibration. Make sure the plugs are torqued to 14 ft/lbs.
Old 04-22-2004   #8 (permalink)
VtecViXen
Guest
Posts: n/a
just seems strange so many people have a similar thing goin on
Old 04-22-2004   #9 (permalink)
yourinmyw0rld
yourinmyw0rld's Avatar
yourinmyw0rld has a spectacular aura about yourinmyw0rld has a spectacular aura about
Send a message via AIM to yourinmyw0rld
does ur RPM gauge go up and down????
yourinmyw0rld is offline   Reply With Quote
Old 04-22-2004   #10 (permalink)
VtecViXen
Guest
Posts: n/a
no rpm is cool, thats the weird part
Old 04-23-2004   #11 (permalink)
Nodnero
Nodnero's Avatar
Nodnero has a spectacular aura about Nodnero has a spectacular aura about
Send a message via AIM to Nodnero
Hmmm. . . . check your fuel filter. That COULD be something, it was a problem with my suburban. Could be the same thing.
__________________
- DU MA!
Nodnero is offline   Reply With Quote
Old 04-23-2004   #12 (permalink)
kafyn722
Platinum Member
kafyn722's Avatar
Send a message via AIM to kafyn722
i know i know, its a honda. j/p
kafyn722 is offline   Reply With Quote
Old 04-23-2004   #13 (permalink)
fonto
The LA Clipper
fonto's Avatar
fonto is a name known to all fonto is a name known to all fonto is a name known to all fonto is a name known to all fonto is a name known to all fonto is a name known to all fonto is a name known to all
Do you play your radio alot with your car off? When you car starts does it do it, or do you have to drive a couple miles before it happens?
I know with my car it always runs at atleast 14.3-14.4 volts (up to 14.7) when i start the car, but it will drop down after a few minutes of driving and playing the radio.
The civic battery is weak as heck though...I would try upgrading your grounds...and maybe think about a better battery...and always turn your car on if you are using any of the electronics in the car.
fonto is offline   Reply With Quote
Old 04-23-2004   #14 (permalink)
x007den
Senior Member
x007den's Avatar
x007den is an unknown quantity at this point
Send a message via AIM to x007den
Quote:
yup, try this out. it might not do it but its another thing off your checklist.
x007den is offline   Reply With Quote
Old 04-23-2004   #15 (permalink)
VtecViXen
Guest
Posts: n/a
yeah i replaced the battery with a interstate, so it aint that.....ill check the fuel filter and im also gonna try to reset the ecu i guess.
Tags
2000 , 2001 , civic , forums , honda , idle , idleing , idling , problem , reset , rough , si
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
SOCAL's Official Whoring Thread!
The OFFICIAL Tuesday night meet thread!
Official SoCal Post Nonsense Thread
So-cal Shops
July 25th: Tech Day ***COMPLETED***
Official 2nd Annual 909/626 MEET: *December 6, 2003*
Post your pic, v.III
SoCal Member List(Updated: 10/16/07)
Official: Bonfire Meet Next Saturday!!
so cal and nor cal meet JUNE 18th 2005
Site Supporters
aluminum radiator
Honda car spoilers
