Go Back   Honda Civic Forum > LOCAL/GEOGRAPHIC FORUMS > West > Arizona
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 04-01-2004   #61 (permalink)
FALKEN
FALKEN's Avatar
FALKEN is a glorious beacon of light FALKEN is a glorious beacon of light FALKEN is a glorious beacon of light FALKEN is a glorious beacon of light FALKEN is a glorious beacon of light FALKEN is a glorious beacon of light
can i use yellow headlight bulbs??
(the color thats in my fogs or like the Lexus fogs)
i believe the law states that the lighting to the front on the vehicle must be white or amber in color...so wouldnt this be legal??
FALKEN is offline   Reply With Quote
Sponsored Links
Old 04-01-2004   #62 (permalink)
NorrinRadd
Super Member
NorrinRadd's Avatar
NorrinRadd is an unknown quantity at this point
I believe you can as long as you have an amber reflector in the front somewhere.
NorrinRadd is offline   Reply With Quote
Old 04-01-2004   #63 (permalink)
AZ2K1Civic
AZ2K1Civic's Avatar
here are the statutes that apply...nothing is mentioned of the color yellow
28-931 Lamp Colors
A. Front clearance lamps and those marker lamps and reflectors mounted on the front or on the side near the front of a vehicle shall display or reflect an amber color.
B. Rear clearance lamps and those marker lamps and reflectors mounted on the rear or on the sides near the rear of a vehicle shall display or reflect a red color.
C. All lighting devices and reflectors mounted on the rear of any vehicle shall display or reflect a red color, except that:
1. The stoplight or other signal device may be red, amber or yellow.
2. The light illuminating the license plate or the light emitted by a backup lamp shall be white.
28-938 Spot and Auxiliary Lamps (this is just an FYI)
2. Not more than two fog lamps that are mounted on the front at a height of not less than twelve inches and not more than thirty inches above the level surface on which the vehicle stands and that are aimed so that when the vehicle is not loaded none of the high intensity portion of the light to the left of the center of the vehicle shall project, at a distance of twenty-five feet ahead, higher than a level of four inches below the level of the center of the lamp that is aimed.
28- 947 Special Restrictions on Lamps
A. A person shall direct a lighted lamp or illuminating device on a motor vehicle, other than a head lamp, spot lamp, auxiliary lamp or flashing front direction signal, that projects a beam of light of an intensity greater than three hundred candlepower so that no part of the beam strikes the level of the roadway on which the vehicle stands at a distance of more than seventy-five feet from the vehicle.
B. A person shall not drive or move a vehicle or equipment on a highway with a lamp or device on the vehicle that is capable of displaying a red or red and blue light or lens visible from directly in front of the center of the vehicle. Lights visible from the front of a vehicle shall be amber or white. This section does not apply to an authorized emergency vehicle or a vehicle on which a red or red and blue light or lens visible from the front is expressly authorized or required by this chapter.
__________________
Think about this next time you're pulled over (nws ads)
AZ2K1Civic is offline   Reply With Quote
Old 04-01-2004   #64 (permalink)
FALKEN
FALKEN's Avatar
if i installed these and i was stopped while driving at night...
would the citation be for equipment violation or a moving violation??
Old 04-01-2004   #65 (permalink)
AZ2K1Civic
AZ2K1Civic's Avatar
^^equipment violation
__________________
Old 04-06-2004   #66 (permalink)
FALKEN
FALKEN's Avatar
i might buy some that are 'DOT approved' from www.jcw.com
Old 04-06-2004   #67 (permalink)
AZ2K1Civic
AZ2K1Civic's Avatar
^^then you're ok
__________________
Old 04-07-2004   #68 (permalink)
dragin
Diamond Member
dragin's Avatar
dragin will become famous soon enough dragin will become famous soon enough
Send a message via ICQ to dragin Send a message via MSN to dragin
Quote:
Originally posted by AZ2K1Civic
How long have you lived in AZ? Are you currently holding a job in AZ?
Answer these 2 questions and I can answer yours...
give or take bought 18 months. no job (saved up like crazy b4 i moved out here) cars are still reg. to my house back in illinois (still own it)
__________________
The original pavement scrapen reflector collector,
Runnin 40 equipment violations strong.
dragin is offline   Reply With Quote
Old 04-07-2004   #69 (permalink)
dragin
Diamond Member
dragin's Avatar
what about noise violations (not exhaust) car stereo'..... how do they determine "to loud" and what is the ticket for?
aslo when does loud music in a house become disturbing the peice?
(after what time?) i know during the day it should be ok to have resonably loud music, but if a complaint is issued the only thing that can be done is ask you to turn it down.........?
Old 04-08-2004   #70 (permalink)
AZ2K1Civic
AZ2K1Civic's Avatar
Quote:
After 18 months I believe you've established residency...is the car registered in your name?
__________________
Old 04-08-2004   #71 (permalink)
AZ2K1Civic
AZ2K1Civic's Avatar
It becomes 'disturbing the peace' when neirghbors start complaining...usually you get one warning and the 2nd time you get a citation...3rd time someone is going to jail.
10pm is about the normal time when things should quiet down
__________________
Old 04-08-2004   #72 (permalink)
dragin
Diamond Member
dragin's Avatar
good stuff! thanx. no im on the title but its not registered under my name
Old 04-27-2004   #73 (permalink)
FALKEN
FALKEN's Avatar
ive now got some yellow H4s (2500K) in the ride...
do you think the cops are going to bother me??
Old 04-27-2004   #74 (permalink)
alex053
alex053's Avatar
what do i need to legally own a fully automatic weapon?
__________________
2006 Smoke Nissan Titan LE
2002 IBP Lexus IS 300
2006 Yamaha Rhino
alex053 is offline   Reply With Quote
Old 04-28-2004   #75 (permalink)
Rufus
I drink Windex...it keeps me from streaking...
Rufus's Avatar
Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of
a plane ticket to Iraq
Rufus is offline   Reply With Quote
Tags
28922 , az , fight , violation
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
whats next?
AZ babble
New Rims & Tires!!
ARIZONA - LAW QUESTIONS
NEXT MEET: 7thGen-and-a-Friend-Event
ARIZONA - For Sale Items
Tech Day SOON!
ARIZONA - 7thGen MEET *SEPTEMBER 25th. 2004*
Girlfriend + Your Car + Bikerack = BAD
MEET: gathering interest/ideas
Site Supporters
aluminum radiator
Honda car spoilers
