Go Back   Honda Civic Forum > LOCAL/GEOGRAPHIC FORUMS > West > Arizona
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 01-09-2004   #46 (permalink)
FALKEN
FALKEN's Avatar
FALKEN is a glorious beacon of light FALKEN is a glorious beacon of light FALKEN is a glorious beacon of light FALKEN is a glorious beacon of light FALKEN is a glorious beacon of light FALKEN is a glorious beacon of light
AZ2K1Civic: can you answer some of these?? To remove this ad, register today for free or log in if already registered!
FALKEN is online now   Reply With Quote
Sponsored Links
Old 01-09-2004   #47 (permalink)
AZ2K1Civic
AZ2K1Civic's Avatar
Quote:
Originally posted by Rufus
What kind of a ticket will I get if I'm nailed watching Girls Gone Wild (edited version of course) on my in-dash while driving?
If it is the edited version then you have nothing to worry about. If its not the edited version then you can be charged with sexual indecency...If other people can see it from outside the car.
There was a case where a couple guys in a blinged out Escalade were watching porn at night with the windows down and a family in a minivan pulled up next to them. The adults in the minivan had children in the car and called the police. Im pretty sure the guys in the Escalade were stopped and charged because the tv screens were in plain site.
__________________
Think about this next time you're pulled over (nws ads)
AZ2K1Civic is offline   Reply With Quote
Old 01-09-2004   #48 (permalink)
AZ2K1Civic
AZ2K1Civic's Avatar
Quote:
Originally posted by Alex053
is this legal...just some retard with a light bar on his jeep??
As long as its not a red/blue light bar it should be cool. Now, if he tries to pull people over with it then he's in a world of shit...impersonating a law enforcement officer.
Security companies use the yellow light bars on their vehicles like construction companies to warn people of their presence.
__________________
Old 01-09-2004   #49 (permalink)
AZ2K1Civic
AZ2K1Civic's Avatar
Quote:
Originally posted by FALKEN
when driving in the dark...can i run with my parking lights and a set of driving lights, or do i need to have my headlights on also (driving lights are amber)
These are the statutes I found that apply to your question JT...there are more too but I figured I would spare you
28-922. Lighted lamps required
At any time from sunset to sunrise and at any other time when there is not sufficient light to render clearly discernible persons and vehicles on the highway at a distance of five hundred feet ahead, a vehicle on a highway in this state shall display lighted lamps and illuminating devices as required by this article for different classes of vehicles, subject to exceptions for parked vehicles as provided in this article.
From this it looks ok to me as long as the lights you're using can be seen and illuminate to the specified distances in the statutes
28-931. Lamp colors
A. Front clearance lamps and those marker lamps and reflectors mounted on the front or on the side near the front of a vehicle shall display or reflect an amber color.
B. Rear clearance lamps and those marker lamps and reflectors mounted on the rear or on the sides near the rear of a vehicle shall display or reflect a red color.
C. All lighting devices and reflectors mounted on the rear of any vehicle shall display or reflect a red color, except that:
1. The stoplight or other signal device may be red, amber or yellow.
2. The light illuminating the license plate or the light emitted by a backup lamp shall be white.
28-941. Multiple beam road lighting equipment arrangement
Except as otherwise provided in this article, the head lamps, the auxiliary driving lamp or the auxiliary passing lamp or combinations of the head lamps, driving lamp or passing lamp on a motor vehicle other than a motor driven cycle shall be arranged so that selection may be made between distributions of light projected to different elevations, subject to the following requirements and limitations:
1. There shall be an uppermost distribution of light, or composite beam, so aimed and of sufficient intensity to reveal persons and vehicles at a distance of at least three hundred fifty feet ahead for all conditions of loading.
2. There shall be a lowermost distribution of light, or composite beam, so aimed and of sufficient intensity to reveal persons and vehicles at a distance of at least one hundred feet ahead, and under any condition of loading, none of the high intensity portion of the beam shall be directed to strike the eyes of an approaching driver.
3. A new motor vehicle, other than a motor driven cycle, that is registered in this state and that has multiple beam road lighting equipment shall be equipped with a beam indicator that is:
(a) Lighted when the uppermost distribution of light from the head lamps is in use and not otherwise lighted.
(b) Designed and located so that when lighted it is readily visible without glare to the driver of the vehicle.
4. A person shall not operate a motor vehicle with a colored transparent or translucent substance or material installed, affixed or applied on or in front of the head lamps, the auxiliary driving lamp or the auxiliary passing lamp or combinations of the head lamps, driving lamp or passing lamp that would obstruct, reduce or interfere with the visibility or effectiveness of the head lamps or that would change the color of light emitted. This paragraph does not prohibit the placement of clear transparent material mounted in front of the head lamps, fog lamps or auxiliary driving lamps.
28-947. Special restrictions on lamps
A. A person shall direct a lighted lamp or illuminating device on a motor vehicle, other than a head lamp, spot lamp, auxiliary lamp or flashing front direction signal, that projects a beam of light of an intensity greater than three hundred candlepower so that no part of the beam strikes the level of the roadway on which the vehicle stands at a distance of more than seventy-five feet from the vehicle.
B. A person shall not drive or move a vehicle or equipment on a highway with a lamp or device on the vehicle that is capable of displaying a red or red and blue light or lens visible from directly in front of the center of the vehicle. Lights visible from the front of a vehicle shall be amber or white. This section does not apply to an authorized emergency vehicle or a vehicle on which a red or red and blue light or lens visible from the front is expressly authorized or required by this chapter.
__________________
Old 01-09-2004   #50 (permalink)
AZ2K1Civic
AZ2K1Civic's Avatar
Quote:
Originally posted by Dorkinator
I've been wondering for awhile, just out of general curiosity and because my dad couldn't answer it [him being an ex-cop and all], what is the law for neons? I've heard so many different things about what colors are illegal, if its really illegal to drive with them on or cops just hate it..so can someone please just kinda explain everything?
28-940. Additional lighting equipment
A motor vehicle may be equipped with any of the following:
1. Not more than two side cowl or fender lamps that emit an amber or white light without glare.
2. Not more than one running board courtesy lamp on each side of the motor vehicle that emits a white or amber light without glare.
3. Not more than two backup lamps either separately or in combination with other lamps, but a backup lamp shall not be lighted when the motor vehicle is in forward motion.
I dont know what a 'cowl' is and I cant find it in the definitions either. I cant seem to find a statute that directly talks about neons or the LED wandshield washer nozzels but I think this may be close. Im gonna keep looking though
Its gonna be different for each city...but I know that in Tempe they will pull you over for having the neons on while the vehicle is in motion.
And the LED washer nozzels have to be white or amber colored
__________________
Old 01-09-2004   #51 (permalink)
AZ2K1Civic
AZ2K1Civic's Avatar
RUFUS- FYI
28-963. Television prohibition
A person shall not drive a motor vehicle equipped with a television viewer or screen or any other means of visually receiving a television broadcast that is either:
1. Located in the motor vehicle at any point forward of the back of the driver's seat.
2. Visible, directly or indirectly, to the driver while operating the motor vehicle.
__________________
Old 01-09-2004   #52 (permalink)
Civicious
Super Member
Civicious's Avatar
Civicious is an unknown quantity at this point
Quote:
Originally posted by AZ2K1Civic
RUFUS- FYI
So basically this law is saying that the fancy CD / DVD players with screens many people have installed as there primary audio in the dash are illegal because they are in direct or indirect view of the driver.
I wonder if an officer would charge you if the screen was not in use at the time driver was stopped?
Civicious is offline   Reply With Quote
Old 01-09-2004   #53 (permalink)
AZ2K1Civic
AZ2K1Civic's Avatar
That would make those fancy reciever/equalizers okay to have in the dash. No television or DVD movies
__________________
Old 01-10-2004   #54 (permalink)
alex053
alex053's Avatar
so i got pulled over tonite in Avondale for failure to stop at a red light and 65+ in a 40. said he paced me (BS never broke 55 but i did turn right without stoping). im gonna request a civil trial and keep rescheduling....but will with wave my right to take trafic school and how many times can i reschedule to drag it out as long as possible?
__________________
2006 Smoke Nissan Titan LE
2002 IBP Lexus IS 300
2006 Yamaha Rhino
alex053 is offline   Reply With Quote
Old 01-10-2004   #55 (permalink)
Rufus
I drink Windex...it keeps me from streaking...
Rufus's Avatar
Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of
What kind of fine do I get just for watching a DVD while driving?
Rufus is offline   Reply With Quote
Old 01-12-2004   #56 (permalink)
AZ2K1Civic
AZ2K1Civic's Avatar
I dont know...Its a class 2 misdemeanor so there could be some jail time but I doubt that would happen.
__________________
Old 03-10-2004   #57 (permalink)
FALKEN
FALKEN's Avatar
can a sherriff deputy serve papers on someone??
Old 03-10-2004   #58 (permalink)
AZ2K1Civic
AZ2K1Civic's Avatar
What kind of papers? Whose jurisdiction is the person in?
__________________
Old 03-10-2004   #59 (permalink)
FALKEN
FALKEN's Avatar
in Maricopa County...papers like for Divorce, Child Support etc.
Old 03-10-2004   #60 (permalink)
AZ2K1Civic
AZ2K1Civic's Avatar
I patrol Deputy wouldnt serve those...we have a civil division that handles that
I could serve an order of protection....restraining order
__________________
Tags
28922 , az , fight , violation
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
whats next?
AZ babble
New Rims & Tires!!
ARIZONA - LAW QUESTIONS
NEXT MEET: 7thGen-and-a-Friend-Event
ARIZONA - For Sale Items
Tech Day SOON!
ARIZONA - 7thGen MEET *SEPTEMBER 25th. 2004*
Girlfriend + Your Car + Bikerack = BAD
MEET: gathering interest/ideas
Site Supporters
aluminum radiator
Honda car spoilers
