ok, well after analyzing this, I've come up with a few things to say, playing Devil's advocate, of course:
swtnshyboi: do you really think the guy in the civic was "racing" you from behind? I don't see what the point of "downshifting to see if he can catch up" is a valid method of testing whether a 7th gen can "catch up" with you or not. In my humble opinion, I think you're an idiot because you could easily switch lanes if you didn't want the car following you rather than having something to prove to a 7th gen ( being that your exhaust tailpipe blows out more shit than his does)
to others:
a 7thgen civic will NOT beat an rsx base and will NOT beat an Si with i/h/e combo. Let us understand the fact that both these cars are DOHC and i-vtec. Let us also understand that our civics (yes I have an '02 ex vic) have less displacement, 33 less hp and less torque. A 7th gen MIGHT be able pull almost even with an Si from 0 to about 60 with i/h/e, but an Si will pull after that.
It is true that the Si hb's are slower than the coupes, but they are also still Si's. As far as I know, they run high-mid 15's in the 1/4 mile ... which is more than any civic can say ... even with i/h/e ... although some can vouch that their n/a vics can also pull high/mid 15's (which in this case, a modded si would run low 15's).
As far as the weight difference goes, it really doesn't matter. Supras are extremely heavy cars, yet still have about a 5 second 0-60 time, so acceleration really isn't a problem. A 150 pound weight difference isn't going to give us a 33 hp advantage.
As far as modding the 7th gen:
the best i/h/e combo (to my knowledge) would only yield about 18 hp...
hp header (high flow cat) ~ 7whp, k&n fipk/v2 ~ 6 whp, tanabe super r. medalion ~ 5 whp ... which gives 18whp ... on top of the 113 whp it already has ... so ... 131. This is still 10 or so whp less than either cars. Perhaps add the kms intake manifold, port/polish, vafc and we might yield about 140/145 whp. Ok, so in that case, we could potentially take a STOCK Si or base rsx. Ergo, the Vic would have basically the same HP, but with a cheaper car ... so we would spend less for the same power. However, the potential for our cars is lower ... because are cars are STILL SOHC ... and a lot of us have a dx/lx.
I end this note with a link to this site...
www.car-videos.com
According to this site, it also notes how a base rsx (although it has the same motor) will beat an Si. With
this this comparison
heh ... we can also see how the rsx type r fairs against a type s ...
here
