Go Back   Honda Civic Forum > GENERAL > Honda Civic Racing, Street Encounters and Competition Racing
Honda Civic Racing, Street Encounters and Competition Racing Honda Civic Racing happens on the street and on the track. There are different setups needed if you are using your Honda Civic for drifting, drag racing, or track racing. Share your stories of Honda Civic racing here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 03-04-2005   #151 (permalink)
Jrfish007
Jrfish007's Avatar
Jrfish007 is a name known to all Jrfish007 is a name known to all Jrfish007 is a name known to all Jrfish007 is a name known to all Jrfish007 is a name known to all Jrfish007 is a name known to all Jrfish007 is a name known to all
Send a message via AIM to Jrfish007
^^^ ofcourse as I siad the COG moved, but that's agian hard to compinsate for, it falls under one of those variable I didn't account for. To remove this ad, register today for free or log in if already registered!
Jrfish007 is offline   Reply With Quote
Sponsored Links
Old 03-04-2005   #152 (permalink)
Jrfish007
Jrfish007's Avatar
Quote:
Originally Posted by 82801BA
Exact COG needs finite element method, may be we don't know how to do it, but I will eventually do. BTW, F*L is not angular momentum. That's the turning moment. Angular momentum is "moment of moment", kind of like Rx(RxF). Well, a pure Dynamics book is very much different than Physics book anyway.
Remembering those days when I took dynamics, it has all kind of rotation and translation problems. We actually had the ABS thing for homework but it turned out that ABS takes much more distance to stop the car (rotation+translation vs. pure translation)!! And all kind of "curve grade" involved in the problems.
Physics is easy, but "Applied Physics" is not that simple.
Yeah, I was treating the turn as a wrench, but that is clearly wrong, you're right it should be moment equation. I guess I was just over simplifing, but I think my point is still clear, that the wieght in that back is going to be more than just it's "dead" weight as we called it.
My physics class made the assumption ABS stppoed the brakes from alowing the car to lock the tire. SO the tire would never skid, hence you would only have the static friction, where as a skiding tire used the kinetic friction fractor, you can probably see why we came up with ABD has a shorter stopping distance, given that assumpution.
And yeah, I know a couple of guys in Applied physics (it's a course here pretty much only physics major take) and they told me about it, sounds way to much for me. But then I talk about the equations of momentum transport ChemE's use and the freakout, it amazing how much difference there is. Of course, ChemE momentum Transopt only deal in the microscopic world, actually closser to nano, but whatever.
Old 03-04-2005   #153 (permalink)
nindoo
Why is my vagina bleeding?
nindoo has a spectacular aura about nindoo has a spectacular aura about
Quote:
Originally Posted by 04civicvp
Yes, I had a 97 Jetta with the 2.0 8v. BTW, the 2.0 8v is 115 hp. My car also weighed 2720 lbs with me and 1/4 tank of gas, had a GIAC chip, Eurospec 262 cam, custom CAI, Techtonics cat-back, and lightweight Enkei Racing rims. When I last dyno'd the car is put 121 hp, and 125 tq to the wheels. Not your typical 2 liter Jetta.
How come civic ex coupes don't do 15s, there 2533 pounds and dyno 115 whp stock? Is it possible with a civic ex coupe as well, with driving techniques.
nindoo is offline   Reply With Quote
Old 03-04-2005   #154 (permalink)
Jrfish007
Jrfish007's Avatar
Quote:
Different gearing, that would be my guess. Civic's aren't that far from the 15's, they run what, 16.3 stock I think is the best I've seen.
Jetta may have a better power curve too. Those look like small tires on that car, are they the factory size?
Old 03-04-2005   #155 (permalink)
82801BA
Super Member
82801BA's Avatar
82801BA is an unknown quantity at this point
Send a message via ICQ to 82801BA Send a message via AIM to 82801BA Send a message via MSN to 82801BA Send a message via Yahoo to 82801BA
I don't see much Civic dyno'd at 115 whp stock. Mine dyno'd 105.8 stock. After all kinds of bolt-on I eventually gets to 120 whp. Then I decided to get better midrange so I put on cam gear, maxed out at 5300rpm (instead of 6300) and 111 whp. They dyno'd the car with cam gear retarded I got 125 whp at 6700rpm. *4th gear.
__________________
Dynaudio 3-way is the worst system for tuning, but it's the best sound I've ever heard of....Finally, done tuning for staging....
82801BA is offline   Reply With Quote
Old 03-05-2005   #156 (permalink)
nindoo
Yeah its hard to compare Dynos, you can go on four diff dynos with the same car and the dynos will be completely diff, I'm giving you AEM's dynos.
Old 03-05-2005   #157 (permalink)
nindoo
I've toyed with dudes in Jettas, but I guess the newer ones are heavier, and older ones are probabaly not in as good condition. I'm from Montreal Canada we have harsh winters, maybe our cars get wear out faster.
Old 03-05-2005   #158 (permalink)
04civicvp
Member
04civicvp's Avatar
04civicvp is an unknown quantity at this point
Send a message via AIM to 04civicvp
The Jetta has a much broader torque curve than the Civic. My car was making peak torque around 3000 rpm, and peak horsepower around 5800 rpm. The Civic EX peaks at 4800 rpm and 6300 rpm. Those wheels are actually 15" and the car came with 14". The overall diameter of the tire is 1/2" shorter than stock with the setup I had. They were also a lot lighter. I was able to pull 2.25 60ft times on those street tires.
As for the gearing, the Civic's have much shorter gearing than the Jetta. The stock gearing on that car had a 3.67 final drive, 3.45 1st grear, 1.94 2nd gear, 1.29 3rd gear, 0.97 4th gear, and 0.80 5th gear.
Just to add, my Jetta was running those times with 172,000 miles on. Of course I was always a bit of a fanatic when it came to maintenance.
__________________
-Jeff, MECP certified installer
2004 Civic VP coupe auto - custom CAI, OBX Type R exhaust (rear section)
Best 1/4 Mile: 17.098 @ 79.16 mph
04civicvp is offline   Reply With Quote
Old 03-05-2005   #159 (permalink)
04civicvp
Member
04civicvp's Avatar
The Civic is 2533 without driver and gas. If you want to compare that to how much my Jetta weighed, you would have to take 2712 - 195 (me) - 22 (gas) which equals 2495 lbs. You say 115 whp stock for the EX (sounds a bit generous to me) vs my 121 whp in my Jetta. Now consider torque numbers. I had 125 ft-lbs at the wheels. The Ex only makes 114 ft-lbs at the crank.
__________________
Old 03-05-2005   #160 (permalink)
nindoo
Yeah that makes more sense, the Jetta is lighter and has more hp and more torque which equals 15s. Actually the 2533 pounds is the curb weight, its not even the gross weight, so with all the fluids its probabaly even heavier. How come your Jetta is so light, are the older jettas lighter?
I looked up AEM dyno for the stock EX civic, and its 111whp not 115.
Old 03-05-2005   #161 (permalink)
04civicvp
Member
04civicvp's Avatar
I wish I still had that Jetta. Yes they are lighter, plus it was a base model without power windows which had a stock curb weight of 2591 lbs. For daily driving I had removed the spare tire and jack, removed the steel rear bumper reinforcement beam, and the wheels only weighed 11lbs a piece. Also, the aftermarket exhaust and suspension were lighter than the stock parts.
I got rid of the car for two main reasons. First, I wanted a low mileage car. Second, I got sick of replacing blown trannies. The VW stock transmission does not like a lot of abuse.
__________________
Old 03-05-2005   #162 (permalink)
nindoo
The impact bumpers are heavy. It would be cool to remove them, but its hard to remove them for a daily driving car.
Old 03-05-2005   #163 (permalink)
82801BA
Super Member
82801BA's Avatar
We are supposed to get into 6th and 7th gen Civic isn't it?
__________________
Old 03-05-2005   #164 (permalink)
nindoo
So what can I do to my 7th gen EX to keep up with a 6th gen si? Anything?
We can mod the suspension and wheels, and the 7th gen will have sick sick handling, similar curb weight, bu thte 7th gen has a more rigid chassis. But what can we do about the engine and transmission?
Old 03-05-2005   #165 (permalink)
82801BA
Super Member
82801BA's Avatar
Basically nothing if you keep D17 with no FI. There's a chance if you meet with a stock Si and the driver who drives it knocks the engine(shifting too fast with too little or too much fuel) everytime he shifts into gear then you are going to win.
__________________
Tags
6th , 7th , civic , gen
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Honda Civic Forum Replies Last Post
My friend's high 13 second geo storm awd turbo Voiceofid General Automotive Discussion 45 11-01-2003 11:12 PM
Anyone Up For Some Street Racing Tonight In Dfw! 20th_ae_gti Honda Civic Racing, Street Encounters and Competition Racing 67 08-23-2003 04:01 AM
"Our civics suck!" aki Honda Civic Racing, Street Encounters and Competition Racing 23 08-08-2003 03:54 PM
Going dual exhaust!!!! CivicRacer5 Honda Civic DIYs and Civic Tech Chat 59 07-17-2003 11:17 PM
User Login
Our Partners
used new
Top 10 Threads
fastest 1/4
1/4 mile times; D17A1 & D17A2
Civic Lx-T vs 2 SRT4's and Lancer
Surviving the snow
Civic Vs. Scion tC
ex 5spd vs. rsx base 5spd
Is 7th gen civic faster than 6th gen civics?
6thgen SI got owned by EX
New Civic SI Vs. 02 my Civic Ex 5spd (sedan)
me vs. 350z
Site Supporters
aluminum radiator
Honda car spoilers
