Go Back   Honda Civic Forum > GENERAL > Honda Civic Racing, Street Encounters and Competition Racing
Honda Civic Racing, Street Encounters and Competition Racing Honda Civic Racing happens on the street and on the track. There are different setups needed if you are using your Honda Civic for drifting, drag racing, or track racing. Share your stories of Honda Civic racing here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 02-19-2004   #1 (permalink)
vivid_BLUE
make it a habit
vivid_BLUE's Avatar
vivid_BLUE will become famous soon enough
Send a message via AIM to vivid_BLUE Send a message via Yahoo to vivid_BLUE
Civic Vs. SE-R spec-v
Can a Civic with a k20a2 swap beat a stock SE-R v-spec in the quarter mile? To remove this ad, register today for free or log in if already registered!
__________________
vivid_BLUE is offline   Reply With Quote
Sponsored Links
Old 02-19-2004   #2 (permalink)
dre2600
Platinum Member
dre2600's Avatar
Send a message via ICQ to dre2600
I think the Spec V would still win, that 2.5l block is pretty good at developing large amounts of torque at low RPM...mind you, consequently, launches are harder because revving over 2000 or 3000rpm on a launch will give insane wheel spin.
Not to mention that they respond a lot better to mods...a Hotshot header alone on a Spec V will give you 10+ (-wheel-) horsepower, and removing the counterbalance shaft frees up another 8whp.
The only way a Vic w. a swap would win is if the Spec V driver was inexperienced at launching, had insane amounts of wheelspin and couldn't handle the sometimes sloppy tranny the Spec Vs have.
dre2600 is offline   Reply With Quote
Old 02-19-2004   #3 (permalink)
vivid_BLUE
make it a habit
vivid_BLUE's Avatar
you dont think it wouldn't even be close?
__________________
Old 02-19-2004   #4 (permalink)
dre2600
Platinum Member
dre2600's Avatar
Like I said, only if the Spec V driver isn't good at launching, which admitedly, can be hard with the Spec V's 6-speed tranny. The K20A2 needs the revs to get going.
Old 02-19-2004   #5 (permalink)
nookiemonster
RESIDENT ROTOR HEAD
nookiemonster's Avatar
nookiemonster is a glorious beacon of light nookiemonster is a glorious beacon of light nookiemonster is a glorious beacon of light nookiemonster is a glorious beacon of light nookiemonster is a glorious beacon of light
The Spec will definitely get the jump off the line, and it will be a fight for the civic to catch up once it reaches the height of its power curve. It would be 10 times worse, if the spec driver can launch well, and has upgraded urethane motor mounts, to reduce wheel hop.
In the end, it really is a driver's race though...
nookiemonster is offline   Reply With Quote
Old 02-19-2004   #6 (permalink)
guamcivic2k1
YoUnG N SuXsExFul
guamcivic2k1's Avatar
Send a message via AIM to guamcivic2k1 Send a message via MSN to guamcivic2k1
k20a2 the type-s motor? if it is..the outcome usually is type-s on top...k20's get alot out of mods..intake alone makes alot of horsepower..
guamcivic2k1 is offline   Reply With Quote
Old 02-19-2004   #7 (permalink)
Anotherslo1
Super Member
Anotherslo1's Avatar
Anotherslo1 is an unknown quantity at this point
Send a message via AIM to Anotherslo1 Send a message via Yahoo to Anotherslo1
^^^^Yup, smoked my this guys SPEC-V constantly when I had just the swap. Maybe he was a bad driver, I DON't KNOW, but none-the-less, it wasn't too close. Although, his 3 rd gear did pull more then mine.
__________________
-Justin
My Ride
AIM: Anotherslo1
"I-VTEC'n since November 2002!"
Be a part of the 7thGen SoCKS! (So Cal K Swaps): drivetofast, em2guy, juncivic, quicksilver, hondaluver, dru106, wantaturbo, aznboysrfr, CdKoInU, ME!
Anotherslo1 is offline   Reply With Quote
Old 02-19-2004   #8 (permalink)
nookiemonster
RESIDENT ROTOR HEAD
The SE-R has a more user friendly power band, but like I said, a driver's race at best...I'm almost positive that the SE-R would get the jump though because of it's torque advantage.
Old 02-19-2004   #9 (permalink)
vivid_BLUE
make it a habit
vivid_BLUE's Avatar
Quote:
What do you mean by more user friendly powerband?
__________________
Old 02-19-2004   #10 (permalink)
nookiemonster
RESIDENT ROTOR HEAD
I mean that they get their max power output sooner in the RPM range. Also known as more torque. The SE-R is a notoriously torquey little ****. A definite contender, and you guys really should give it more credit.
However, I would give the slight advantage to the K powered civic....but like I said...the SE-R has low end where the K20A2 has high end pull...
Driver's race.
Old 02-19-2004   #11 (permalink)
Logan3024
Sunkist_em2 = Fagness
Logan3024's Avatar
Logan3024 is a name known to all Logan3024 is a name known to all Logan3024 is a name known to all Logan3024 is a name known to all Logan3024 is a name known to all Logan3024 is a name known to all Logan3024 is a name known to all Logan3024 is a name known to all
Send a message via AIM to Logan3024
Driver's race.
So 160 lb/ft ='s a tourqey little ****? Civic would own a spev v, most people are running 15's that i know of. It even listed a running 15.6 stock (linkspec v stats
So basically you have
200 hp civic @2500 lbs vs. 170 hp spec v @ 2700 lbs.
__________________
Retired Ricer
Logan3024 is offline   Reply With Quote
Old 02-19-2004   #12 (permalink)
Hawk
You boost, I-VTEC
Hawk's Avatar
Hawk is a jewel in the rough Hawk is a jewel in the rough Hawk is a jewel in the rough
i can tell you from a first hand experince yes. From about a 40mph roll, had no problem. left him as soon as i hit 5th.
if it was from a dead stop i have no idea, haven't launched in my car, nore do i care. I'd probably say like nookie said, the SER would get the jump, but i think the k20'd vic would pull past on the top end.
__________________
http://OpieandAnthony.com
Hawk is offline   Reply With Quote
Old 02-19-2004   #13 (permalink)
7thGenLX
Super Member
7thGenLX's Avatar
Send a message via AIM to 7thGenLX
the thing about spec's are well i know mine is very hard to launch because of the massive amount of torque gives a massive amount of wheelspin if it is launched from anything over 2k....even at 2k it spins like a mother****** but i think the spec-v would deff get the jump out of the whole if the driver can launch and if its an 04 it will be even harder to catch up bc of the improved knock sensor and shit ive seen stock 04's running 14.8, 14.9 bone stock
__________________
1999 Electron Blue Si
Greddy Front Lip(gone), Wings West Sides And Rear, 17" 5zigen Corpse, Kumho Ecsta Supra 205/40/ZR17, AEM cai, DC Sports header, Apex'i N1 Axle-Back Exhaust, Springs And Tokico Shocks, Custom Leather, CF interior Kit, DC Sports Short Shifter, ITR Knob, Comptech Rear LTB, Cross Drilled/Slotted Rotors,
7thGenLX is offline   Reply With Quote
Old 02-19-2004   #14 (permalink)
Zzyzx
Autocross Junky
Zzyzx's Avatar
Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned
I'm with DIZZLE on this one, I just find if funny when people call a car with a whole 175 LB-Ft of torque to be "A massive ammount". Sure its more then us, but its not all that much.
Plus the SE-R is making its peak acceleration at only 4,000 RPM (whats the redline on those things?) where the swaped civic is making peak acceleration at 6000 RPM. Given those numbers and the fact that the swaped civic is at least 200 LBS lighter then the sentra, I'd say that the SE-R will get the jump on the civic off the line, but the civic will more then make up for it in the long run.
"Its better to make peak torque at a High RPM rather then a Low RPM because then you can take advantage of Gearing"
Zzyzx is offline   Reply With Quote
Old 02-19-2004   #15 (permalink)
robbclark1
Retired suspension supermod.
robbclark1's Avatar
robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold
Send a message via AIM to robbclark1 Send a message via MSN to robbclark1 Send a message via Yahoo to robbclark1
yeah there is too much torque to get to the wheels. Once it catches though, it is off. It will most definitely take the civic off the line, but it's powerband isn't as large as the k20. Hondas are notorious for low torque and high hp (faster acceleration). It will be close.
__________________
Life isnt a test drive, gotta live a little. (02fpcivic)
Suspension FAQ
Autocross FAQ
If you pretend that cars are moving cones, then the roads become your personal autocross course.
I live my life 1 cone at a time, for those 70 seconds or less, I'm free
Thanks to ALPHSTER for the sig!
robbclark1 is offline   Reply With Quote
Old 02-19-2004   #16 (permalink)
nookiemonster
RESIDENT ROTOR HEAD
From specplace.com The very website you posted.
Looks like a driver's race to me. And yes, in the compact car segment 180 lb-ft of torque is pretty damn respectable. And correct me if I'm wrong, but I do believe reading that the Spec V comes with a LSD stock. Getting power to the wheels shouldn't be a problem.
__________________
http://www.msprotege.com/members/shaolin/sig2.jpg
Porsche Cayenne S Loaded
2005 Berlina Black S2000
2004 RX-8 6 MT Sports Package (gone )
1994 RX-7 TT (father's car) maybe mine someday?
Old 02-19-2004   #17 (permalink)
NcSpecv81
Member
NcSpecv81 is an unknown quantity at this point
if drivers equal and can launch capably well...se-r on the stop with the civic eventually catching up and passing...just imho..if it was the a3 ide say se-r all the way...however throw alot of mods on the a2 it would be a different outcome where the spec would be raped anything after 2nd gear...hondata bastages =o)
NcSpecv81 is offline   Reply With Quote
Old 02-19-2004   #18 (permalink)
nookiemonster
RESIDENT ROTOR HEAD
Once you start talking mods, it gets stupid. Please don't get into this. We can talk about how a turbo D17 would rape a stock B16, but then what would the point of this be? The topic at hand is what would happen with a K20A2 civic vs. SE-R Spec V.
Old 02-19-2004   #19 (permalink)
Zzyzx
Autocross Junky
Zzyzx's Avatar
Hm, if an RSX-S is doing 15.2 how much faster would it be if it were 300+ lbs lighter?
and I agree with nookiemonster, I try to never compair moded cars. (this case is an exception because I believe we are compairing unmodified engines) once you start tweaking the winner is who ever has the most $$$$
Old 02-19-2004   #20 (permalink)
dre2600
Platinum Member
dre2600's Avatar
I don't know, talking mods with the Spec V I find is necessary, it seems that a lot of things about that car were poorly designed, namely the header being so close to the cat and the counter balance shafts to reduce engine vibration. Frankly I don't find the new VQ engines in the Spec Vs to be much of a step up from the old KA24s in the 240SX owing to the aforementioned design flaws.
The LSD is a nice touch though, but a Spec V engine w. upgraded header and removed balance shaft will gain 20 whp easily.
Old 02-19-2004   #21 (permalink)
xX03EXx
Sweetest Dude on 7th Gen
xX03EXx's Avatar
xX03EXx will become famous soon enough xX03EXx will become famous soon enough
Send a message via AIM to xX03EXx
I can't even believe you all do not think the k20a2 would win. It would own hands down. I don't care what anyone says. I have seen it done before, stock vs stock. RSX s won every time. Close gearing, more hp, higher redline, lighter car....the civic has all the advantages.
xX03EXx is offline   Reply With Quote
Old 02-19-2004   #22 (permalink)
dre2600
Platinum Member
dre2600's Avatar
Yeah, but the Civic has no LSD, that K20A2 would have a harder time getting the power to the ground.
Old 02-19-2004   #23 (permalink)
vivid_BLUE
make it a habit
vivid_BLUE's Avatar
Quote:
True, but couldn't you just buy one?
__________________
Old 02-19-2004   #24 (permalink)
dre2600
Platinum Member
dre2600's Avatar
I may be mistaken, but other than the Phantom Grip, which many people don't consider a 'true' LSD, I'm not sure if there is a LSD available for our Vics. I'm not terribly farmiliar with swaps, but were one to swap a K20A2 into a Civic that might also entail switching out the axles, which might make it possible to buy an LSD for an RSX (of which there are many available) and stick it onto the Vic.
Old 02-19-2004   #25 (permalink)
NcSpecv81
Member
dude if there was a vq engine in the spec-v.... spec-v > k20a2 civic any day of the week
Old 02-19-2004   #26 (permalink)
nookiemonster
RESIDENT ROTOR HEAD
I haven't heard of an LSD out for the civic, but I do believe that you could use one designed for the RSX if you're using the correct tranny. I do know that I had a quaife LSD on my EG hatch a couple years back.
Old 02-19-2004   #27 (permalink)
Hawk
You boost, I-VTEC
Hawk's Avatar
i'm gonna be getting a DC5 Type R LSD for my car, it tends to have torque steer. Taking off at a light without tire spin is tricky, but very possible
Old 02-19-2004   #28 (permalink)
vivid_BLUE
make it a habit
vivid_BLUE's Avatar
How do LSDs work? And is it as easy to take one from an RSX and put that in our cars as is sounds?
__________________
Old 02-19-2004   #29 (permalink)
civicex01
Member
civicex01 is an unknown quantity at this point
Send a message via AIM to civicex01
civic hands down
more power + less weight (both fwd and comparible gearing) = civic by 2 car lengths
civicex01 is offline   Reply With Quote
Old 02-19-2004   #30 (permalink)
MMILX
Senior Member
MMILX's Avatar
MMILX is an unknown quantity at this point
I'd think the Civic would win, but isnt it kind of a silly comparison?
I mean a stock Spec-V costs what? LIke 17 and change, and right now Nissan has 2k back, so that 15k... Even with some options, you're still looking around 17k... A little more than a stock EX would be, right?
And its safe to say a stock Spec-V would beat the stock EX.
I know its a bit off topic, but I guess I think its just a silly comparison.
But I do feel a Civic with the RSX-S engine would win once the cars get rolling...
The guy in the Spec-V would just be better in the pocketbook
__________________
01 Civic LX Coupe A/T
white/tan beater
stock, w/ Blinder LaserJammer
MMILX is offline   Reply With Quote
Tags
counterbalancers , removing , spec
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
fastest 1/4
1/4 mile times; D17A1 & D17A2
Civic Lx-T vs 2 SRT4's and Lancer
Surviving the snow
Civic Vs. Scion tC
ex 5spd vs. rsx base 5spd
Is 7th gen civic faster than 6th gen civics?
6thgen SI got owned by EX
New Civic SI Vs. 02 my Civic Ex 5spd (sedan)
me vs. 350z
Site Supporters
aluminum radiator
Honda car spoilers
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
