Go Back   Honda Civic Forum > GENERAL > Honda Civic Racing, Street Encounters and Competition Racing
Honda Civic Racing, Street Encounters and Competition Racing Honda Civic Racing happens on the street and on the track. There are different setups needed if you are using your Honda Civic for drifting, drag racing, or track racing. Share your stories of Honda Civic racing here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 11-24-2008   #61 (permalink)
fathan16
New Member
fathan16 is an unknown quantity at this point
Re: Surviving the snow
if you slide while braking and about to rear end someone, it's usually better just to drive off the road, ive done this and ended up with no damage and pulled back onto the road To remove this ad, register today for free or log in if already registered!
fathan16 is offline   Reply With Quote
Sponsored Links
Old 03-06-2009   #62 (permalink)
Schuy
Member
Schuy is an unknown quantity at this point
I live in MN, and dont think ebraking is a great way to make corners lol, if you dont have front traction already, odds are that you will end up spinning or just sliding sideways into the nearest solid object (curbs will bend your rims up nicely).
For starting on ice and snow i always use the 2 option in my auto, since that produces less tourqe and thereby less wheel spin from a dead stop.
For braking, just let of the gas earlier and dont slam the brakes, you'll do fine.
Schuy is offline   Reply With Quote
Old 03-06-2009   #63 (permalink)
DDragon7
Ultimate Member
DDragon7's Avatar
DDragon7 is a glorious beacon of light DDragon7 is a glorious beacon of light DDragon7 is a glorious beacon of light DDragon7 is a glorious beacon of light DDragon7 is a glorious beacon of light
Umm, technically, in D2 in an auto, you have more torque because it keeps your car in a lower gear.
__________________
I <3 My Honda
(Rep Me and I Rep Back)
2001 Civic SiG, 5spd, Eternal Blue, 126k km
www.ottawahondaclub.com - Admin
DDragon7 is offline   Reply With Quote
Old 03-08-2009   #64 (permalink)
Schuy
Member
Quote:
You just use it when you start then shift back up to d4 when your moving. It just produces less wheel spin then starting in d4 and getting 1st gear. Yes if you were to actually drive on ice in 2 you get more torque. Its just 2 not D2, D2 implies you have first, but in civics you dont
Old 03-11-2009   #65 (permalink)
sl33pyriceboi
Ultimate Member
sl33pyriceboi's Avatar
sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold
Send a message via AIM to sl33pyriceboi
actually, u dont "get more torque" from driving in D2.
all D2 does is locks it in 2nd gear...and because ur lower gears have alot of torque, it helps for hauling stuff.
(maybe you know this but i understood ur answer incorrectly, or u type it out wrong)
and whoever said using ur Ebrake in snowy condition should not be contributing to this thread. because most of the weight in the civic is in front, if you manually engage in ur ebrake, ur rear will slide outta control.
__________________
7thGen.MT.C.
Quote:
Originally Posted by gearbox View Post
alot of people just talk to say something. most of the time they have no idea wtf is going on lol
Quote:
Originally Posted by manahoonie View Post
lol. well we got newbs to use the SEARCH button.... NOW the next step is to look at the date
Step 1) SEARCH
Step 2) DATE CHECK
sl33pyriceboi is offline   Reply With Quote
Old 03-11-2009   #66 (permalink)
sl33pyriceboi
Ultimate Member
Quote:
no no no and more no. that IS INCORRECT. your car doesnt produce more torque in D2 (say in 2nd gear) then it would in D4 (on 2nd gear). as i stated, D2 locks ur car in 2nd gear, so you can MANUALLY select the topgear u are in.
I REPEAT, IT DOES NOT GIVE YOU MORE TORQUE.
__________________
7thGen.MT.C.
Step 1) SEARCH
Step 2) DATE CHECK
Old 03-11-2009   #67 (permalink)
sl33pyriceboi
Ultimate Member
seriously, i Ebraked (lightly too) on accident while taking a turn this past winter, and my car did a full 180 into the guardrail
__________________
7thGen.MT.C.
Step 1) SEARCH
Step 2) DATE CHECK
Old 03-11-2009   #68 (permalink)
Schuy
Member
Alright let me be clear on what i mean. In "2" (NOT D2!) you get ONLY 2nd gear. NO 1st...at ALL. SO when when you take off from a stop in 2 you will produce less wheel spin because you have LESS torque BECAUSE YOU ARE IN A HIGHER GEAR THAN 1st. DDragon said that being in 2 would produce more tourque than d4. IT WOULD be true, if you NEVER shifted out of 2 and just drove high RPMS in 2, since then you would be hitting full HP without shifting to speed up. BUT that was completely beyond the point, the point was to start driectly in 2nd gear because it allows for a slower, more controlled, start, then once up to a decent rolling speed, run the shifter back up to d4 and let the car do as it will. Its simply, read the manual for your car, it clearly explains this. IT WILL NOT HELP YOU TOW ANYTHING AS IT STARTS IN 2ND GEAR, YOU WOULD BE PUTTING MASSIVE STRAIN ON YOUR ENGINE DOING THIS AS YOU WANT ALL YOUR LOW GEARS WHEN TOWING IN ANY VEHICLE. (Do not tow in a civic, btw. Terrible idea)
You are correct that you would NOT get more tourqe in second by locking in second than being there in d4. That was not even close to what i said.
Tags
2005 , 2006 , 2007 , civic , civics , d2 , drive , gear , good , honda , moving , rear , snow , surviving , torque
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
fastest 1/4
1/4 mile times; D17A1 & D17A2
Civic Lx-T vs 2 SRT4's and Lancer
Surviving the snow
Civic Vs. Scion tC
ex 5spd vs. rsx base 5spd
Is 7th gen civic faster than 6th gen civics?
6thgen SI got owned by EX
New Civic SI Vs. 02 my Civic Ex 5spd (sedan)
me vs. 350z
Site Supporters
aluminum radiator
Honda car spoilers
