Quote:
Originally posted by cosmicjim Any have any settings they run at the track (circuit style) for tire pressure? Im running the same PSI for all four tires. I find that i tend to understeer into the corners. I know some guys at the track run with less PSI in the rears, but they all have different cars; just wanted to hear some 7th gens speak up.
BTW, im running on stock firestones (at around 30 PSI hot) and only have a RSX-S rear anti-sway bar. |
Only 30 psi? damn thats low. I run my falken Azenis sports at 42 front and 30 rear (205/50R15) and they have VERY stiff side walls.
If you're runing with the stock tires I'd suggest 45+ on the front! Really you shoud be checking your tire roll over to see what pressure you need to be at.
Just mark the tire in a few places on the edge of the tire (Between the tread and the sidewall) when you corner the tire will rollover and wear off some of the marking telling you how much your tire is rolling over. add or remove psi as needed.
Like this,
See the tick marks on the tires?
__________________
Las Vegas SCCA
Autocross: Because Life is more fun on three wheels......
"I know Solo only comes one minute at a time, but what an intense, non-stop, fast-forward car control exercise minute it is. Sure, the velocity is higher in road racing, but inside the car it is slow-motion in comparison. In Solo, the turns come like machine-gun rounds. "
Randy Pobst
