laid to rest-b20v arguments
Rep Power: 0 laid to rest-b20v arguments
Ok, so I'm sick and tired of people taking me back and forth with"go with the b16 turbo cause the b20 can't handle boost" or "b18 cause the b20 can't handle high rev so it's inefficient for track"and all that BS... you don't need boost nor do you have to settle for strictly low end performance. The answer is simple, so you have your b20 block right...which is nothing more than a bored out b18... so weight isn't an issue, you replace the stock pistons with high comp to solve that low compression problem, you stick a girdle on the bottom and install h beam rods, arp rod bolts and head studs so your bottom end is nice and stable. Bottom end complete, maybe a bladed crank and a baffled oil pan for good measure. Now the head, I've heard the b18c7 flowed the best for na set UPS...but that's just what I've heard...ALOT. Simply install some, oh idk, stage 3 bisimoto cams, springs, and retainers, ecu tune and very smooth timing and ... voila... K killer that has a strong, reliable platform... Now was that so hard? Why didn't you guys figure this out before...problem solved?
Received 1,440 Likes
Rep Power: 338 Re: laid to rest-b20v arguments
huh? pics or it did not happen
nickeynick
04-27-2015 01:23 PM
