| Re: GB: Denso Iridium Plugs IK20 & IK22 when i swapped from $2 ngk v-power copper plug to the denso iridium, i noticed zero difference. the only benefit of the denso is that they require less electrical energy to make the SAME spark. i tested this with a voltmeter. therefore, it doesnt put as much strain on the electrical system. this does not mean you gain more power, the spark from the iridium is still the same. it just uses less alternator power to make the spark. its a good upgrade without any bad side effects if you have the money. but dont expect it to make your car faster.
__________________
Restore Performance, Reduce Costs www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring. |
