Fully Built R18 Stepping Up
Old 11-18-2011
420Coupe's Avatar
420Coupe is an unknown quantity at this point
A little introduction I will have the progression of the build in chronological order. First page is the Turbo kit Build, Second Page will be Motor build thread.
The vehicle is currently in Jo Tech Performance's hands.
*Stainless steel Turbo manifold,Downpipe,Dumptube
*Aluminum 2.5in Intercooler piping
*Aluminum 3' Inch intake with KN filter
*intercooler
*Tial 38mm vband
*Tial 50 mm blow off
*Precision 5857b turbo
*Walbro fuel pump
*FIC 625cc injectors
*Flashpro
*CMB tuning - by Colombia!
Heres some Pics of the progress, amazing welds !!
:drooling::drooling:
:turboleghump:
FINISHED PRODUCT
Dyno Results were @ 7 psi
Old 11-18-2011
420Coupe's Avatar
Re: Fully Built R18 Stepping Up
Full Motor Build
Hahaha that said All work is being done by Jotech Performance (Jo) definitely content with the extra effort they put in to pick up customers car!!
Thanks JC!! On to the parts!
Engine -
*R18A1 Block
*CP Pistons
*Pauter Rods
*EAGLE Sleeves (Machine Work)
*Custom Head Studs
*SuperTech Custom Retainers
*SuperTech Custom Springs
*ACL Race Bearings
*Injected OEM Mounts (3M Window Weld)
*Custom Intake Manifold - by Gato Performance
*Thermal Gaskets
*GoPower Cam (still debating)
Transmission - (lets see till when it holds!)
*MFactory Helical LSD
*MFactory FD 4.678
*Clutch Masters 'Stage 4' 6 puck clutch
*Stainless Steel Clutch line
*Hybrid Racing Shifter Bushings
*Hybrid Racing Base Bushings
Forced Induction -
*Jotech R18 Turbo Kit
*Precision 5857 Journal Bearing Billet .63 A/R (debating on buying Str8JDM's 5857 BB .82 A/R)
*DEI T3 Turbo Blanket
*Tial 38mm vband
*Hondata 4bar Map Sensor
*Skunk2 76 mm Exhaust
*Stainless steel Turbo manifold, Downpipe, Dumptube (Ceramic Coated)
*intercooler
***CMB TUNING***
Fuel System -
*255 Walbro Fuel Pump
*Jotech Fuel Return Kit
*Fuel Injecter Clinic 1000cc Injectors
*Custom Fuel Rail
*All fittings will be AN and Stainless steel Braided lines
Suspension/Brakes -
*Skunk2 Pro-C Coilovers (8k Front, 12k Rear)
*Full-Race Traction *****
*Goodridge Stainless Steel Brake Lines
*ARP Extended Studs
*Hawk HPS Front
Up'ed the boost to 9 psi and results are as followed
Old 01-03-2012
Live for the Twisties
MindBomber's Avatar
How did I miss this thread, wow.
Outstanding build.
Old 01-04-2012
A true genius admits that he/she knows nothing.....CLOSED SAT/SUN
Gunner's Avatar
Gunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to all
Nice..Great build..+1 for the R-18..
Old 01-15-2012
johng35's Avatar
johng35 is an unknown quantity at this point
Looks great. Nice job.
that bay is so tight, that was a feat to get it to fit, let alone work.
Where did you get the guage cluster for the dash ? Custom ?
Old 01-23-2012
420Coupe's Avatar
Xvracing.com for cf one other one is from xlr8performance
Old 01-23-2012
420Coupe's Avatar
Thanks guys
Should be finishing soon
Little update!
Transmission
Old 05-18-2012
420Coupe's Avatar
Just got head back from 4Piston Racing - port and polish
Old 05-23-2012
MindBomber's Avatar
4 Piston builds unbelievable heads.
I moved this thread to members rides, it will garner more attention here.
Old 05-24-2012
krudmuphin's Avatar
Awesome ride!
There's an 8th gen in my town that's got a nearly identical turbo setup. Sounds like a monster!
Old 05-24-2012
420Coupe's Avatar
Yes they do I am expecting big gains from they're work, as well as this is the first R18 head they've ever touched. Thanks BTW
Originally Posted by krudmuphin
Awesome ride!
Really ? I would definitely be interested in seeing what some one else put down # wise. although if its an 8th im pretty sure its an SI(K20Z3) and not the base model ex,ex-l,lx,dx (R18A1)
I have not found any one in the US that has built an R18 only people i have come across are Russians (R18A2) with CP Pistons/Manly Rods and all running GT2860RS making 325 PS = ~ 300whp but all of them under 1 bar (~14 psi).
To my knowledge i am the first person to SLEEVE an R18, thanks to the help of Golden Eagle Manufacturing. Although it has just taken utterly and entirely too long of a custom project. But i do understand no company releasing a product till they are satisfied it meets their Standards. My plans are to run 1.5-3.5 bar (25-45psi) Maxing out the 5857 jb PTE Precision Turbo.
Old 05-24-2012
krudmuphin's Avatar
Nope, it's a Borrego Beige Metallic non-Si coupe. Next time I see it, I'll get pics and ask the owner about the specs. If I remember correctly, he had about 9lbs of boost and tipping 215-230 HP from his R-series. Pretty neat stuff!
Old 05-24-2012
tipnitty's Avatar
tipnitty is on a distinguished road
Holy ****. Well done sir.
Old 05-24-2012
KurtzN1's Avatar
KurtzN1 is an unknown quantity at this point
Beautiful build. Looks like you didn't cheap out anywhere, great job! What tires do you plan on running?
Old 05-24-2012
420Coupe's Avatar
Thank you sir!
haha definitely not cheap planning on running 235/40-17 until i either get wider rims to support the 245/40-17. Hankook RS-3
Old 05-24-2012
MindBomber's Avatar
I was wondering about that, I'm glad you mentioned it. Up until this thread I'd never heard of 4 piston doing an R18 head.
Old 05-25-2012
Dr Krieger of Modification
mac25's Avatar
killer bro!
Old 05-28-2012
420Coupe's Avatar
Haha hopefully once we get it up and running I'll be sending it back to 4Piston for CNC Port and Polish for some real gains!
Originally Posted by mac25
killer bro!
thank you sir!
Old 05-30-2012
Teachmehowto20's Avatar
Teachmehowto20 is an unknown quantity at this point
wow, super nice job, idk why i would paint all the pipes flat black as well as the intercooler to make the sleeper look even more...sleeper, but really nice so far
Old 05-31-2012
EM2ti
maxtierney's Avatar
Hats off to you. Incredible build!
Old 06-02-2012
420Coupe's Avatar
Who informed you on my plans ?! going all black with everything, definitely hate that after 15k miles any anodized red is now fading to an orangish red. Decided to avoid all this by going black, discoloration is extremely difficult according to the people i spoke to at both a powder coating facility and anodizing.
Why thank you sir, going crazy that its almost been a year but will be well worth it to be able to bring the R series to a whole new level.
Old 07-20-2012
420Coupe's Avatar
World's First Sleeved R18A1 thanks to Golden Eagle!
Old 07-20-2012
Whachya lookin at?
BlueEM2's Avatar
Looks great man
Old 07-21-2012
mac25's Avatar
wow there's like no space between those pistons. did you increase the bore?
Old 07-21-2012
420Coupe's Avatar
Originally Posted by BlueEM2
Looks great man
thanks bro!
Actually thats a bare block before it went out to get bored to proper diam, i believe im going 1mm overbore maybe more depending on the pistons shape from CP
Old 07-21-2012
skate or die
Tragedy's Avatar
Holy cow lots of fun in there
Old 07-22-2012
420Coupe's Avatar
Old 07-22-2012
rjones7755's Avatar
Wow...im guessing you'll be upping the boost?
Old 07-23-2012
420Coupe's Avatar
yep 25+ lbs minimum
Old 08-08-2012
420Coupe's Avatar
Slowly but surely getting there
Quick Reply: Fully Built R18 Stepping Up
