MAD JDM! hood hinge shims..... would you and should i?
Old 11-13-2005
ncirom2003's Avatar
ive seen alot of threads about this on HT and after consideration i could care less if some people think my front end is busted. i think i might just do it from time to time like when im at the track or something, i highly doubt ill keep it like that everyday, but then again i might not, i guess the only way is through trying to see if it helps cool.
from what ive read it (althought i dont know how much i agree with alot of these) it will add downforce to front wheels, decrease engine temps, decrease air intake temps, create a vacuum to reduce drag, allow for more rapid air flow up through the engine bay, and for individual throttle bodies its said to act as ram air and really help to suck in that air.
again, you be the judge of what reason you want to believe but eitherway ill most likely try this once at the track or something once ive got a few more gauges to monitor everything.
http://honda-tech.com/zerothread?id=1387229
http://www.honda-tech.com/zerothread?id=1416016
http://honda-tech.com/zerothread?id=1302176&page=3
Old 11-13-2005
2k1civic.com O. G.
AzNmiKex215's Avatar
looks gay to me. maybe it will be the next big JDM trend, like black 16 inch rims, and slanted stickers on the bumper.
Old 11-13-2005
Formerly 2blu
Nick's Avatar
i guess. If u are going all out.
Old 11-13-2005
show0and2go's Avatar
show0and2go is an unknown quantity at this point
I think it may help out a little, but I think it looks quite shitty imo. Its all up to you, but I wouldnt do that to my car.
Old 11-13-2005
Life Begins > 6800rpms
blouisgod's Avatar
looks like the hood isn't on right. if you need cowl induction for itbs or whatever, get the proper hood for it.
Old 11-13-2005
ncirom2003's Avatar
but the benifet i see is not paying for a new hood, and id only have it like this sometimes, so i wouldnt have to drive around with an ugly cowl hood 24/7.
but yea i see how its ugly lol of course.
Old 11-13-2005
omg that looks retarded. i would get a vented hood before i did that.
Old 11-13-2005
ncirom2003's Avatar
but the point here is that looks are not the concern at all.
Old 11-13-2005
7thGenerasianCivic's Avatar
lol. tight! JDM all the way! hahaha
Old 11-13-2005
ncirom2003's Avatar
yes i was joking with MAD JDM!
i pride myself in not being one of those people that calls everything jdm!
Old 11-13-2005
I just burnt my tongue
ragingSPAM's Avatar
thats easy to do too...just unbolt it and put some washers underneather the hinges
Old 11-13-2005
ncirom2003's Avatar
yea i know that, im asking what people think of it and what they think any advantages would be, because i get mixed reviews on HT,
Old 11-13-2005
I log in from time to time
dirtySAMURAI's Avatar
if i ever get into autocross with the miata, i'll have to do this. something about the 1.6L engine overheating easily...
my thoughts on this for a civic? well, if you have no money/don't want a new hood and it's only a temp solution, then go for it. if it's going to be like that everyday, be prepared for flaming.
Old 11-13-2005
jdmtytedoridori
Al Gore FTW's Avatar
i have a friend with an fc, and a friend with an s14, and they both have done it. its pretty sweet, when its cold out you see steam coming from under the hood. so it must do something.
Old 11-13-2005
dre2600's Avatar
Vented would probably be a better idea, hot air rises, it'd more efficiently exit out a top vent and see more ready induction through the top as well at speed. On previous muscle cars, raised hoods were for the sheer size of the block too, you swap in a Merlin big block you'll need to raise the hood somehow, even the new MSP6 has a raised hood for that very reason.
Plus it just looks bad...
Old 11-13-2005
b00stinem2's Avatar
b00stinem2 is an unknown quantity at this point
werd
Old 11-13-2005
skipbarber's Avatar
worthless, if you do it for looks, or any reason for that matter...you're a retard.
Old 11-13-2005
Wicked Moderatuh
fraga's Avatar
No I would not...do whatever you want...just looks like they forget to close the damn hood right...
Old 11-14-2005
ncirom2003's Avatar
why am i a retard? because people like you would just look at it and flame on about ricers balh blah, and be too stupid to think of possible advantages like lower under hood temps. you my friend are the retard
oh and i not even once ever said id do this for looks, obviously it looks retarded. a little extra performance is worth it to me, over having someone think my hoods on wrong. btw there is no way to have hood like this from incorrect mounting, its just not possible, youd have to put the shims.
Old 11-14-2005
DaddyFatSacks's Avatar
DaddyFatSacks is an unknown quantity at this point
Find more info NCIROM, i'd be interested to see if this does make a differance, and a DIY way to do it.
Old 11-14-2005
Words on a User Title
ramcosca's Avatar
It's like saying my coupe is JDM...
Or that the Corvettes are built in Mexico...
(Well... there's more change for coupes to be JDM than Corvettes being built in Mexico... )
Old 11-14-2005
Still in the game...
scatman's Avatar
i dunno......kinda makes i look like the hood was hit or somethin
Old 11-14-2005
ncirom2003's Avatar
well once ive got my turbo setup all put on the car, im definately going to do this at least once to check how the temps are doing and what not.
diy is simple, remove hood bolts, get longer ones with washers or shims and replace them with shims between hood and hinge. you can do this one side at a time to make it easier on yourself.
Old 11-14-2005
You boost, I-VTEC
Hawk's Avatar
I love seeing the birth of the next "Lambo door"
Old 11-14-2005
ncirom2003's Avatar
ughh
this is function over form. the end.
Old 11-14-2005
cheukkin's Avatar
cheukkin is an unknown quantity at this point
it's not a new stuff in japan....
Old 11-14-2005
mrstocks's Avatar
mrstocks is an unknown quantity at this point
I like it. looks really clean.
Old 11-14-2005
You boost, I-VTEC
Hawk's Avatar
ughh
Aluminum wings are functional, yet they are trendy.
Old 11-14-2005
yourinmyw0rld's Avatar
This JDM thing is getting more trendy
Old 11-14-2005
diskreet's Avatar
Would I? No.
Should you? God no its just another ricer crazy to sell more crap on ebay. dont be those guys
JDM doesnt even mean JDM anymore. it means "mimic as many borderline rice trends as possible"
If anyone called my vic JDM id be pissed cause of stuff like this.
Quick Reply: MAD JDM! hood hinge shims..... would you and should i?
