Go Back   Honda Civic Forum > GENERAL > Honda Civic Member's Rides
Honda Civic Member's Rides Honda Civic Member's Rides - Want to show off your Honda Civic mods? Need help deciding what Civic part, mod, or even what version Honda Civic to buy? Anything and everything about your very own Honda Civic member's ride goes here.
Welcome to civicforums.com!
Welcome to civicforums.com.
Closed Thread
LinkBack Thread Tools
Old 06-06-2003   #1 (permalink)
Chrissy
Member
Chrissy's Avatar
Chrissy is an unknown quantity at this point
cool diy /w underbody neons. even better if you have alarm or keyless entry.
got some neons today for my civic and installed them and instead of hooking them up directly to the battery and the neon's on and off switch, i did something different.
i hooked them in parellel up to the left parking light and voila... you have your neons flash each time you lock/unlock your door and plus have them instantly turn on when you switch the headlights on. no more damn switches. i made a switch that bypasses the neons just in case i cant drive while neons are on (e.g. some states). now to prevent the fuse from blowing, replace with a 15 amp fuse (300 watts).
Chrissy is offline
Sponsored Links
Old 06-06-2003   #2 (permalink)
civicvtec1ps
Search and Learn
civicvtec1ps's Avatar
civicvtec1ps is just really nice civicvtec1ps is just really nice civicvtec1ps is just really nice civicvtec1ps is just really nice civicvtec1ps is just really nice
Send a message via AIM to civicvtec1ps Send a message via MSN to civicvtec1ps Send a message via Yahoo to civicvtec1ps
and wheres pics!!!
__________________
2008 Chicane S2k (5-01 08 Project Begins)
civicvtec1ps is offline
Old 06-06-2003   #3 (permalink)
Chrissy
Member
Chrissy's Avatar
Quote:
Originally posted by civicvtec1ps
and wheres pics!!!
will be there tomorrow when it is bright outside... fairly easy diy to do. from a skill level 1-10, i rate it as a 1, like the throttle body heater bypass.
Chrissy is offline
Old 06-06-2003   #4 (permalink)
REDchirp
Ultimate Member
REDchirp's Avatar
REDchirp should not be trusted REDchirp should not be trusted
wow... chrissy this sounds awesome... can you PM me with all the instructions you did... like in detail so i can do the same.... well... actually i'm installing red... so i just need info on the bypass switch and to blink them when unlocking and locking my car.... thanks
__________________
http://server5.uploadit.org/files/REDchirp-REDchirp.jpg
Please dont' sugarcoat it, give me all the bad rep points you can possible give me ...pansies
REDchirp is offline
Old 06-06-2003   #5 (permalink)
Chrissy
Member
Chrissy's Avatar
1st diy without pics
things needed:
flashlight
some speaker wire
flat head screw driver
wire cutter/stripper
soldering iron
radioshack lil switch (any small one should do)
electric tape
1. turn you car on, turn steering wheel all the way over to the left
2. on the front right wheel, pop the little fastener out with you flat head screw driver.
3. while spreading the wheelwell and the bumper apart, reach your hand in and locate the right parking light and unplug it
4. 1st hardest part: with the parking light wire unplugged and in your hand, you will see an outer insulator wrapped around an insulated red and black wire. (REMEMBER RED IS POSITIVE, BLACK IS NEGATIVE!) unwrap the insulator and until the red and black wires are exposed, put a little cut in both with the wire cutter on both of them to expose the metal wire inside.
5. once you get the insulation off a little exposing the bare wire, you can solder like 2 feet of speaker wire to both of them. (dont forget which is negative and positive)
6. guide the speaker wire to the + and - to the transformer.
7. strip the end of the positive wire, connect it to one part of the switch and connect the other side of the switch to the transformer wire leading to the transformer
*the switch is to turn off the neons just in case you cant have them on while driving. it will be located under the hood.
8. strip the end of the negative wire, connect to the transformer directly.
9. test circuit out. if working , solder all joints and wrap with electric tape if not working, inspect the joints and/or make sure the positive and negative arent touching. (short)
10. whalla, now you have keyless entry activated neons. and when you turn on your headlights, they should turn on automatically.
Chrissy is offline
Old 06-06-2003   #6 (permalink)
guamcivic2k1
YoUnG N SuXsExFul
guamcivic2k1's Avatar
Send a message via AIM to guamcivic2k1 Send a message via MSN to guamcivic2k1
wow that sounds awesome! good job! just wnat to see pics or maybe even a video! maybe ill try it out when i get enough money for neons..
guamcivic2k1 is offline
Old 12-20-2003   #7 (permalink)
7thGenerasianCivic
7thGen Junkie
7thGenerasianCivic's Avatar
7thGenerasianCivic is just really nice 7thGenerasianCivic is just really nice 7thGenerasianCivic is just really nice 7thGenerasianCivic is just really nice
Where are the pix Chrissy? LOL
__________________
i ♥ my daily hooptie- staggered- coils- frame low
7thGenerasianCivic is offline
Old 12-20-2003   #8 (permalink)
NeonImpact
7thGen Junkie
NeonImpact's Avatar
NeonImpact should not be questioned NeonImpact should not be questioned NeonImpact should not be questioned NeonImpact should not be questioned NeonImpact should not be questioned NeonImpact should not be questioned NeonImpact should not be questioned NeonImpact should not be questioned NeonImpact should not be questioned NeonImpact should not be questioned NeonImpact should not be questioned
omg, so old, locked!
__________________
NeonImpact is offline
Closed Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Post your sedan pic!
Post Pics Of Clean Jdm 7th Gens
2004-2005 Post Your Ride
Gonzo.
PINOYS! Sound off and post your Civic Pics!
2001 - 2003 Post your ride....
Varnerr88 new jdm thread pictures and talk come on in..
7th Gen Members Rides Accident's and Crashes Thread
Lets see those BLACK Civics!!!!!
EM2Crew Reppin (56k keep dreamin)
Site Supporters
aluminum radiator
Honda car spoilers
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
