Honda Civic Member's RidesHonda Civic Member's Rides - Want to show off your Honda Civic mods? Need help deciding what Civic part, mod, or even what version Honda Civic to buy? Anything and everything about your very own Honda Civic member's ride goes here.
Welcome to civicforums.com!
Welcome to civicforums.com.
okay, first i was able to aim my lights to near perfect, the problem was the hotspots were merging together in the middle at 25+ft so i was able to fix that. now the beams point straight out and it looks like i have two mini flashlights for headlights ahaha
but WOW the turn signal drls with the polarg lens type bulbs in them are insanely bright. i have a feeling even in sunlight they will be visible. in the garage, the amber turn drl was brighter than my hi beams and when the park lights are on at night and i use the turn signal, the brightness is very very noticable. it hurts my eyes to look at. i also put a small led pnp bulb for the sidemarker that has four 5mm amber leds its also very bright from the side.
the retrofit made me feel bad, because i was blinding the crap out of people on a nightly basis.
um that ebay led, NO. you would need a heatsink the size of a brick. a 1w led is plenty, its roughly 35 lumens and puts out the same light as a normal 168 bulb (except its colored light). the one i got was 1w dorado from superbrightleds.com and the driver was the 1w 350ma from besthongkong.com and since the led is only 1w, a small heatsink is all you need. the driver makes sure it gets the right amount of power. the Vf is the forward voltage of the led. its the max amount of voltage you can give it for normal operation. so if you feed it 12v hooking it straight to the car, it will blow up in a second. as a general rule, 1w+ leds need constant current drivers. the standard resistors only work for 5mm leds and the square superflux style leds that run between 20ma-80ma each. still low enough that resistors (and a voltage regulator if you want) will be fine.
__________________
Restore Performance, Reduce Costs www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
Sponsored Links
haha i was just kidding with the 1000lm led though...
hahah but i WAS thinking of getting some 260LM cree(sp) led for my reverse and retroing them on.....because i cant really see at night when i reverse (stupid led reverse lights)
__________________ 7thGen.MT.C.
Quote:
Originally Posted by gearbox
alot of people just talk to say something. most of the time they have no idea wtf is going on lol
Quote:
Originally Posted by manahoonie
lol. well we got newbs to use the SEARCH button.... NOW the next step is to look at the date
door sills are from overseas, indonesia honda-access dealer i think. its oem honda part for sedan only. a friend from these forums brought em back for me a long time ago.
__________________
Member 1025782
bump bump. just painted my muffler back to its original non rusted appearance! using rustoleum 2000F hi temp flat black (looks more like grey, which is how the exhaust was when new). didnt bother with the piping for now. also sprayed around the sway bar area and rusted parts of the frame which covered up nicely
also just put on my JDM honda black emblem on the tezza grill. I got one more of the same size if anyone wants for $15 shipped. comes in original honda packaging. just cut off the pins in the back and it has double sided tape in the back. i think i like it, the grill doesnt look so bare now.
__________________
Member 1025782
ignition coil ground wires i copied the idea from similar products like the weapon-r ignition equalizer and sun auto systems. basically adding good grounds to the coil packs so that extra charge doesnt build up. idk if it does anything or not, but it couldnt hurt.
Quote:
Small current is charged on the iron core of direct coil, slight leakage also occurs. Consequently, the direct coils are not performing as it is originally designed. D-Spark eliminates charging of current and leakage at the iron core. It stabilizes the difference of potential among each coil and maximizes the original performance. As a result it brings stronger spark. Installation: Just tighten with the bolt of fixing the coil, then affix the wire at a grounding point such as engine head and connect the other end with the battery negative terminal.
__________________
Member 1025782
Beautiful car Gear. I can't wait till the weather here in Indiana gets nicer so that I can do more work on my ride. Work as in cleaning it up in the ways that you have w/ yours. I am a detailed person as well and if I see the slightest imperfection somewhere, I want it fixed so it doesn't catch my eye anymore.
