Go Back   Honda Civic Forum > GENERAL > Honda Civic Member's Rides
Honda Civic Member's Rides Honda Civic Member's Rides - Want to show off your Honda Civic mods? Need help deciding what Civic part, mod, or even what version Honda Civic to buy? Anything and everything about your very own Honda Civic member's ride goes here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 11-19-2008   #1 (permalink)
mrbanhbao
Senior Member
mrbanhbao's Avatar
mrbanhbao has a spectacular aura about mrbanhbao has a spectacular aura about
help QUICK!
guys im installing my basic as of right now. i got the fronts in but now im working on the rear. i loosen the bolt on the bottom and its almost out but then i realize it starts to turn in one place. its not coming out anymore, wat can i do? i try to pull it out its hard in place. To remove this ad, register today for free or log in if already registered!
mrbanhbao is offline   Reply With Quote
Sponsored Links
Old 11-19-2008   #2 (permalink)
BigVic4545
Member
BigVic4545 is an unknown quantity at this point
Re: help QUICK!
lol...u need to basically hammer it out....use a hex wrench or screwdriver and hit it with a hammer...it comes out easily....BTW when putting the bolt back in ur gonna have to remove the bolts from the control arm in order to put the bolt in easily.
BigVic4545 is offline   Reply With Quote
Old 11-19-2008   #3 (permalink)
baron340
Senior Member
baron340's Avatar
baron340 is just really nice baron340 is just really nice baron340 is just really nice baron340 is just really nice
Re: help QUICK!
ok i'm gonna be the first to say huh... i'm assuming you are installing suspension. that bolt on the bottom, you can either put a jack underneath it and take the stress off the bolt. or put a screw driver in the hole and whack it with a hammer.
baron340 is offline   Reply With Quote
Old 11-19-2008   #4 (permalink)
lordhelmet
Platinum Member
lordhelmet's Avatar
lordhelmet should not be questioned lordhelmet should not be questioned lordhelmet should not be questioned lordhelmet should not be questioned lordhelmet should not be questioned lordhelmet should not be questioned lordhelmet should not be questioned lordhelmet should not be questioned lordhelmet should not be questioned lordhelmet should not be questioned lordhelmet should not be questioned
Send a message via AIM to lordhelmet
Re: help QUICK!
Have someone jump up and down on the drum. That will make the holes line up so you can pull the bolt out.
lordhelmet is offline   Reply With Quote
Old 11-19-2008   #5 (permalink)
Palindrome
New Member
Palindrome's Avatar
Palindrome is an unknown quantity at this point
Re: help QUICK!
Quote:
Thats what i did with mine. I had my most healthy (fattest) friend stand on the drum while i put the bolt in.
__________________
civic | כiviכ
Palindrome is offline   Reply With Quote
Old 11-19-2008   #6 (permalink)
lordhelmet
Platinum Member
lordhelmet's Avatar
Re: help QUICK!
Quote:
I don't know if I would hammer it out. Push on the end of the bolt with a screw driver while unscrewing it. That way your not going to futz up the threads.
Old 11-19-2008   #7 (permalink)
mrbanhbao
Senior Member
mrbanhbao's Avatar
Re: help QUICK!
coolio i got it out. i jacked up the drums a lil bit to lessen the binding. then i used a screwdriver and pound on it lil. now im still not finished, i cant the rear driver side nut off. the one that is in the corner hella hard to reach. i got the other side off iono why i cant on this side. its on there reallly tight
Old 11-19-2008   #8 (permalink)
lordhelmet
Platinum Member
lordhelmet's Avatar
Re: help QUICK!
The nut on the bottom of the shock should be welded on the bracket. If its one of the nuts on the top of the shock inside the cabin then good luck. I have a sedan so I had a bit of room back there to fiddle around with.
Old 11-19-2008   #9 (permalink)
Albertross
Member
Albertross should not be questioned Albertross should not be questioned Albertross should not be questioned Albertross should not be questioned Albertross should not be questioned Albertross should not be questioned Albertross should not be questioned Albertross should not be questioned Albertross should not be questioned Albertross should not be questioned Albertross should not be questioned
Re: help QUICK!
Yeah, just make sure you're not twisting the nut welded on the control arm, because that would be foolish, lol. Use a breaker bar, or if you can afford it, rent out an air compressor, and buy an impact wrench. Then return it. It's the asian way.
Don't forget to put on anti-seize before you put those bolts back on!!!
Albertross is offline   Reply With Quote
Old 11-19-2008   #10 (permalink)
EnvyX
Member
EnvyX will become famous soon enough
Re: help QUICK!
I used an air wrench @ 130 psi and it didn't budge..
Somehow my dad managed to get it out though.
EnvyX is offline   Reply With Quote
Old 11-20-2008   #11 (permalink)
mrbanhbao
Senior Member
mrbanhbao's Avatar
Re: help QUICK!
im not talkin bout the nut on the bottom anymore. the 2 nuts in the trunk that holds the strut. 1 of them wont come off. waiting for a friend to stop by with a solution. i wanna finish my car before tomorrow
Old 11-21-2008   #12 (permalink)
ampong
Member
ampong's Avatar
ampong has a little shameless behaviour in the past
Re: help QUICK!
Is it already solved? What's the update to this?
ampong is offline   Reply With Quote
Old 11-21-2008   #13 (permalink)
mrbanhbao
Senior Member
mrbanhbao's Avatar
Re: help QUICK!
thank you everyone. i got this done this morning. i noticed the rear can go much lower then the front. i love them already. now to get camber kit for the rear
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Post your sedan pic!
Post Pics Of Clean Jdm 7th Gens
2004-2005 Post Your Ride
Page 210 = The New Project!! -The Speedfoos' 383 Stroker thread!!
PINOYS! Sound off and post your Civic Pics!
2001 - 2003 Post your ride....
Varnerr88 new jdm thread pictures and talk come on in..
Lets see those BLACK Civics!!!!!
7th Gen Members Rides Accident's and Crashes Thread
EM2Crew Reppin (56k keep dreamin)
Site Supporters
aluminum radiator
Honda car spoilers
