Go Back   Honda Civic Forum > GENERAL > Honda Civic Member's Rides
Reload this Page
Getting back at that NA build
Honda Civic Member's Rides Honda Civic Member's Rides - Want to show off your Honda Civic mods? Need help deciding what Civic part, mod, or even what version Honda Civic to buy? Anything and everything about your very own Honda Civic member's ride goes here.
LinkBack Thread Tools
Old 12-01-2008   #61 (permalink)
TRIZ
Hey! Look At Me!! I'm a Supporting Member!!Administrator
TRIZ's Avatar
TRIZ is a splendid one to beholdTRIZ is a splendid one to beholdTRIZ is a splendid one to beholdTRIZ is a splendid one to beholdTRIZ is a splendid one to beholdTRIZ is a splendid one to beholdTRIZ is a splendid one to beholdTRIZ is a splendid one to beholdTRIZ is a splendid one to beholdTRIZ is a splendid one to beholdTRIZ is a splendid one to behold
Re: Getting back at that NA build
Looking for crowers number...
TRIZ is offline   Reply With Quote
Old 12-01-2008   #62 (permalink)
TRIZ
TRIZ's Avatar
Okay, just got off with crower. Called 12/1/08 @ 2:22p-2:29p
He didnt have a set of maxi light rods on the shelf, but he did have the regular rods on hand. He weighed the reg crower rods at 570g and said the maxilight rods would be aprox 520g. That weight is for one rod, including the hardware.
He said it would be 6 weeks or so till a maxi light set came through that he could really weigh.
I also asked if these would work with stock pistons, and not just aftermarket. He said they would because they use the stock pins. (I thought everyone was saying if you have aftermarket rods then you need aftermarket pistons??)
He didnt know if these were interchangable between the d17a1 and the d17a2 though- I thought I'd ask because I couldnt remmeber off the top of my head.
Old 12-01-2008   #63 (permalink)
speedfoos
Boosted.......bitch.
speedfoos's Avatar
speedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questioned
A1 and A2 pistons are the same. Order them up!
speedfoos is offline   Reply With Quote
Old 12-01-2008   #64 (permalink)
TRIZ
TRIZ's Avatar
I need to figure out the weight of the stockers. Anyone know?
And havent people been saying that you need aftermarket pistons with aftermarket rods, as in the stock pistons wouldnt fit? I remember hearing this like it was common knowledge... anyone else remember that?
Old 12-01-2008   #65 (permalink)
wikkaco0
Member
wikkaco0's Avatar
wikkaco0 is an unknown quantity at this point
Yeah, I also remember talk about needing aftermarket rods for aftermarket pistons a couple years back. Think it was talk about the wrist pins.
Here's what I know and found.
The stock pistons in the D17 use 19mm wrist pins. This is the same as the D16.
Wiseco aftermarket pistons specifically for the D17 have 19mm wrist pins. (According to their catalogue)
http://www.wiseco.com/Catalogs/Sport...AcuraHonda.pdf
Seeing as most people use the Wiseco pistons with Crower rods for forced induction, I would have to assume the Crower rods also use 19mm wrist pins.
Compression height for the Wiseco and stock pistons are both 27mm. Wiseco pistons are desgned to be used with 137mm connecting rods. Again, same as stock.
To conclude, I bet you can use aftermarket pistons on stock rods.
wikkaco0 is offline   Reply With Quote
Old 12-02-2008   #66 (permalink)
bomerman19
Senior Member
bomerman19 is a name known to allbomerman19 is a name known to allbomerman19 is a name known to allbomerman19 is a name known to allbomerman19 is a name known to allbomerman19 is a name known to allbomerman19 is a name known to allbomerman19 is a name known to all
^ its under 500 grams I weighed them back in October and it was either 430 or 470 grams I can't remember I think 470 and I can't find where I wrote it down and my gram scale is at work, so I can't check till wednesday.
Also you can't use stock pistons on the crower rods It says so on there website. Go to http://www.crower.com/cat/import/honda/rods/rods.shtml look down the list at the D17 civic rods and look over to the right and you will see a little yellow diamond and if you scroll down a little bit and it will tell you what that diamond stands for (Indicates pin end width will not fit in OEM pistons. Must use aftermarket brand.)
I am pretty positive it is due to the fact that the stock rods have the pin pressed into them while the crower rods have a free floating pin that held in with circa-clips
bomerman19 is offline   Reply With Quote
Old 12-02-2008   #67 (permalink)
speedfoos
speedfoos's Avatar
Paul, PM me your address so I can ship that steering rack to you.
Old 12-02-2008   #68 (permalink)
TRIZ
TRIZ's Avatar
So gx pistons will work with d17a1/a2 rods... I need to find someone to weight of gx rods and whats good with them- they are D17 rods so they will fit.
Quote:
: D17A rods are 137mm. Compression height is lower than 1.6 pistons ~3mm, deck height is similar from D16 to D17, and bore is equal. The D17A gets it's displacement from stroke.
: 1.7L rods are the same from DX to EX (PLM). They are the same 137mm length as the D16 rods, share the same 19mm wrist pin diameter, have the same 45mm rod journal diameter, but have a 19.8mm wide big end, unlike the D16 BE width of 22.6mm. The GX rod has a different number (PMS) but I believe it to be the same length as the PLM.
That being said... should D16 rods fit in a D17? I'm not famil exactly with the term "big end" To google....
Ahh I cant find a digargram where they the measurments are taken, I need to run to class
Old 12-02-2008   #69 (permalink)
D17alltheway
Member
D17alltheway's Avatar
D17alltheway will become famous soon enough
can you use a d16 crank? and get the block notched? or would the d17 crank be better?
D17alltheway is offline   Reply With Quote
Old 12-02-2008   #70 (permalink)
bomerman19
Senior Member
Quote:
well I believe a long time ago gerry tried to stick a d16 bottom end in a D17 or something.The crank snout probably has to be machined and I think that there is an issue with using the crank gear on a d16 cause there is one less notch on it than the d17 and you just can't get the crank and cam triggers to run right or something.
essentially the d16 and d17 are similar but if you break it down into lamens terms the d17 is in essence a stroked d16 crank.
good luck finding some one that has a gx that is ripped apart and I don't think the guys in the warehouse in detroit are going to go searching the whole warehouse for the set of gx rods to weigh them. they might if you bring them cake... but the cake is a lie lol
I think the big end is different on the d16.
you have two ends on a rod the small end or PE(pin end) where the wrist pin and piston go and then you have the Big end wich is the end that goes around the crank shaft.
I was talking to Jeff Evans today about crower forced induction rods and we got onto using stock rod on aftermarket piston. It can Be done. BUT you have to machine the piston and the rod and grind off some metal and it is alot of work and it really isn't worth it. Its kinda ghetto kinda like cutting off every 3rd tooth on the syncro rings of your transmission so it shifts easier on the drag strip when your putting out alot of power. the reason why crower says you can't do it is cause the aftermarkets use a different style of pin than the stock honda
Old 12-02-2008   #71 (permalink)
TRIZ
TRIZ's Avatar
The guy at the Honda parts desk knows me pretty well, I'm hoping the next time I'm in town I can stop by and have him ask someone to weigh one, or if thats impossible, he'll probably order one for me even know he knows I'll be returning it if weighs more then the crower rods. Hes seen me ask for some non-traditional parts for my vic over the years.
Old 12-02-2008   #72 (permalink)
TRIZ
TRIZ's Avatar
So I looked up the GX pistons on majestics website (orig looking for the price on how much it might cost to order one connecting rod) and I found this...
Quote:
P/Num....Part name.....................................msrp..... majprice
394823 PISTON SET (STD)..........................63.62.....44.53
394976 PISTON SET (OVER SIZE) (0.25)........44.52.....31.16
395261 PISTON SET (OVER SIZE) (0.50)........63.62.....44.53
So there are three different size GX pistons??? What is this about- does this mean, that there is a 75mm, 75.25mm, and 75.50mm piston available? I've never seen three different stock piston sizes before. Anyone know what the deal is?
Old 12-02-2008   #73 (permalink)
bomerman19
Senior Member
there over sized pistons honda does it with almost every motor there is standard 1/4mm oversized and 1/2 mm oversized.
It cause when you change pistons in a block you need to rehone the block and that takes away material eventually you loose too much material and you have to bump up to a large piston andy had to go .50 overbore on his last set of pistons after the last motor blew. But a word of warning if you go .50 overbore and something happens and you need to put in new rings or something if you really really lucky you might be able to get a very light hone on the cylinder but it is very easy to loose too much and once you go past .50 the block is shot unless of course you want to cut the stock sleeves and re-sleeve the block but that will usualy cost you a $1000.
Also they don't really like to separate up a set of rods cause they are usually pretty closely matched on the weight but supposedly there is only One set of GX rods in the country and they are in a warehouse in Detroit (I have very very good sources lol) If you do get one, take a picture of it for me cause I want to know if it is bigger then stock or shot peened.
Old 12-02-2008   #74 (permalink)
7thgenMugen
Member
7thgenMugen is an unknown quantity at this point
Hey Bomerman, Foos said you were getting your NA vic dynoed today. How'd that go? Most of us are are real interested in some hard numbers on a good NA built engine.
7thgenMugen is offline   Reply With Quote
Old 12-03-2008   #75 (permalink)
bomerman19
Senior Member
Not as good as I wanted let me first say the exhaust breathes great and so does the intake mani there is no restriction there what so ever but before I went I knew that there was a wall in there some where and I found it.
120hp and 118tq
The cam is too big for it. there is not enough static compression to make use of the cam. Essentially it need more pressure in the cylinder ie. boost or high comp pistons. the torque band is kinda nice though, it starts at 90 at 2000 rpm is up to 115 @ 2300 rpm and then fluctuates between 100 and 118 all the way to 6500 rpm. And it is soooo smooth the car feels like it came that way from the factory.
I have the stage 2 downstairs in the box so that might go back in last time I had that in I got 144 with the most messed up map ever shitty exhaust and stock intake mani so I should still be able to break 150 easy. But jeff is not going to be scheduling anybody for a tune till mid jan early feb.
I will post my graph up once I get it scanned in so probly tomorrow night.
wasn't a total loss I finally got reliable dyno charts that tell me pretty much everything I need to know about the motor to get the most power out of it in the future. and the car really does run butter smooth it amazing how smooth it is.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Post your sedan pic!
Post Pics Of Clean Jdm 7th Gens
2004-2005 Post Your Ride
Page 200 = New Video! - Page 200 - The Speedfoos' Turbo Thread!!
PINOYS! Sound off and post your Civic Pics!
Varnerr88 new jdm thread pictures and talk come on in..
7th Gen Members Rides Accident's and Crashes Thread
EM2Crew Reppin (56k keep dreamin)
Lets see those BLACK Civics!!!!!
The Silver Coupes thread!!
Site Supporters
aluminum radiator
Honda car spoilers
Powered by vBulletin® Version 3.6.8
