Go Back   Honda Civic Forum > GENERAL > Honda Civic Member's Rides
Honda Civic Member's Rides Honda Civic Member's Rides - Want to show off your Honda Civic mods? Need help deciding what Civic part, mod, or even what version Honda Civic to buy? Anything and everything about your very own Honda Civic member's ride goes here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 12-04-2008   #91 (permalink)
mule69
New Member
mule69 is an unknown quantity at this point
Re: Getting back at that NA build
Would doing a NA build have any effect on the reliability of the engine over the long term? To remove this ad, register today for free or log in if already registered!
mule69 is offline   Reply With Quote
Sponsored Links
Old 12-04-2008   #92 (permalink)
TRIZ
Hey! Look At Me!! I'm a Supporting Member!!Administrator
TRIZ's Avatar
TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of
Send a message via AIM to TRIZ
Quote:
Its anyones guess. But if you do it correctly and safely and dont be stupid about it like deciding to see what happens with say 15:1 compression, then it will last just as long as any other stock motor. If you cut corners and decide not to replace things that should be replaced when having the motor apart, if your dealing with internals that is, then you can screw up your ride. This all depends on how far you want to go with the build of course. The easiest NA build I can think of would be dropping in a stage 1 cam from crower and calling it good. Will it affect the life of your engine? Not really... there is the posability that you can mess shit up on the install and ruin your motor, but take your time and be sure you know what your doing, and if you dont- take it to someone who does, and you should be good and have your motor run just as long, if not longer, than any stock motor.
....basically this is a long winded reply that breaks down into this: Do it right and your motor will be fine, try and do an NA build when you dont know what your doing or doing it half assed and you'll screw it up.
This is the same for anything on a car. Its just like a brake job- its not very difficult to chang pads, but you do run the risk of crashing if you do it wrong- ex accidently cutting the brake hose line.
TRIZ is offline   Reply With Quote
Old 12-16-2008   #93 (permalink)
D17alltheway
Member
D17alltheway's Avatar
D17alltheway will become famous soon enough
well just to throw another pickle in your ongoing dilemma.... are you going to use the A1 tranny and its longer gear ratios?
D17alltheway is offline   Reply With Quote
Old 12-16-2008   #94 (permalink)
lordhelmet
Platinum Member
lordhelmet's Avatar
lordhelmet should not be questioned lordhelmet should not be questioned lordhelmet should not be questioned lordhelmet should not be questioned lordhelmet should not be questioned lordhelmet should not be questioned lordhelmet should not be questioned lordhelmet should not be questioned lordhelmet should not be questioned lordhelmet should not be questioned lordhelmet should not be questioned
Send a message via AIM to lordhelmet
Long gear ratios would be bad for NA because engine should stay in the power band. I don't think the stock gear ratios between an A1 and A2 would make too much of a difference though. I think Trix is running an A1 trans.
lordhelmet is offline   Reply With Quote
Old 12-16-2008   #95 (permalink)
wikkaco0
Member
wikkaco0's Avatar
wikkaco0 is an unknown quantity at this point
Quote:
I have an A1 transmission. The taller gears don't make that much of a difference. It's more of a gear spacing issue between first and second gear. It just bogs into second if you don't have enough revvs. Not an issue in day to day driving of course. Increased rev limit helps quite alot though. Overall however, ratios are a relatively short in both cases and if you're making enough power and have a big enough rev band, I think the final drive from the A1 will be more advantageous.
D17A2 5M Gear Ratio
First 3.143
Second 1.870
Third 1.241
Fourth 0.970
Fifth 0.757
Reverse 3.231
Final Drive Axle Ratio 4.412
D17A1 5M Gear Ratio
First 3.462
Second 1.870
Third 1.241
Fourth 0.970
Fifth 0.711
Reverse 3.231
Final Drive Axle Ratio 4.111
__________________
"I'd race you, but my Civic is stored." - Sitting in his BMW...
wikkaco0 is offline   Reply With Quote
Old 12-17-2008   #96 (permalink)
bomerman19
Super Member
bomerman19's Avatar
bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned
The different trans gear ratio do make a difference I had to run andy old trans which was from a dx and the gears were just to long for the power I now finally have my old ex gear set back in the trans and my acceleration is a lot better in I have also ran the HX gear set which is also too long. the only one that I have not run is the LX.
bomerman19 is offline   Reply With Quote
Old 12-19-2008   #97 (permalink)
TRIZ
TRIZ's Avatar
DX and LX gear ratios are the same, arent they??
I'm dumb with trannys... can someone break down what the gear ratios really mean... 4.3333.... hows that any different from 1.333? I have NO idea.
Old 01-07-2009   #98 (permalink)
01_EM2
Member
01_EM2's Avatar
01_EM2 can only hope to improve
Quote:
Originally Posted by bomerman19 View Post
wow this thread has gotten rolling nice
K series are fine but like I said before they don't just cost $150 like a d17 and motors do just blow up thats why at any time of day there is always some one broken down on I-495 capital beltway I have seen motors blown from being driven hard I have seen the blow from bad wrenching, seen them go from just an accidental mistake, and I have seen them go for no reason at all. it happens. But you see if mine goes i am left with the self satisfaction that "I don't care! I get another one tomorrow for $150" not shit that was my k-series i have to start searching so maybe I can find one for under 3 grand in a week.
Also Alot of people don't know this including many k owners but there is one fatal flaw in the desing of the K-series.
The timing chain tensioner. it is operated by oil pressure wich is nice unless you stick it on the track and you get into a hard turn and the revs are already spinning high. the oil sloshes away from the pick up(and it that baffle can only do so much) loose pressure tensioner eases off the chain hopps there goes your motor. so 6000 rpm good suspension hard turn and bam! I have only found one company that has actually addressed this issue and that is TODA. not too hard to blow a K.
I'm not bashing on k's just the ease and cheapness of the d17 has it's advantages. also I have seen a k in a 7thgen before now I know I have never tried to pull one before but to me from the looks of it unless you had a lift and could drop it from the bottom it looks like it could take some time to pull. Mine takes 90 mins to get out from the time the hood pops and the jack slides under untill the the engine is on the ground next to the car.
and it didn't take much to beat a k
150 for crower stage 2 cam
150 for crower valve springs and retainers
900 for k-pro
beat an ep3 and run nose to nose with a type s. tempest racing claimed 144 with matching torque to the wheels that was after I blew out my exhaust gaskets on the way to the tuner and they did a shitty job. I have alot more done to the car now should be above 160 hoping for 170. I think the torque is going to be high but not the hp cause I'll be honest I hit a wall at like 100 miles an hour but I will accelerate like a bat out of hell all the way up to there.
There are k's out there that will beat me and I have driven k series cars and swaped k-series cars but still IMO I have not found a K-series car that is any where near as fun to drive as my car. My car is so much fucking fun drive, that I get sad if I don't drive it everyday. It's awesome!!!
id like to find some cams and springs for that price ne idea where i can??
01_EM2 is offline   Reply With Quote
Old 01-08-2009   #99 (permalink)
speedfoos
Boosted.......bitch.
speedfoos's Avatar
speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned
Used. Although Paul's estimates are a little low. I picked up a new Crower cam for $250 and had sold my extra set of springs and retainers for $200.
__________________
Quote:
Originally Posted by LogicWavelength
This thread (T.E.A.R.S.) was inspired by speedfoos. We all know about his very public and very obscene battle against his car's engine.
There's a good chance that I'm not going to answer your PM.
The Foos' 383 Stroker (and everything else) Thread....(clickme)
T.E.A.R.S. Crew Member #2
My terbow shopping list and tips thread
www.7thgenhonda.com
speedfoos is offline   Reply With Quote
Old 01-08-2009   #100 (permalink)
bomerman19
Super Member
bomerman19's Avatar
It took a lot of time and searching but that is what I paid for everything you just have to keep your eye out. And when a deal like that comes around especially for the k-pro you have to grab it. It might mean your eating rammen noodles for the next couple of months but its worth it.
If you are looking for new parts at least for the cam the cheapest I have been able to find is directly from crower.
Old 01-08-2009   #101 (permalink)
speedfoos
speedfoos's Avatar
I'm brownbagging it for the next few weeks after buying Andy's kpro!
__________________
www.7thgenhonda.com
Old 01-08-2009   #102 (permalink)
bomerman19
Super Member
bomerman19's Avatar
Quote:
LOL! So worth it though!
Oh any update on said firewall?
Old 01-09-2009   #103 (permalink)
01_EM2
Member
01_EM2's Avatar
oh isee well thats a real tuner right there. i guess ima do both builds. i have a d17a1 and a d17a2 block and bottom end. i think ima build the a1 all motor and add the vtec head and cam and springs to see how far i can get. and since i got a friend whos gonna build a d16y8 for boost ill be building my a2 for boost aswell. but very slowly
Old 01-09-2009   #104 (permalink)
speedfoos
speedfoos's Avatar
I emailed Levi again. We'll see what he comes back with.
__________________
www.7thgenhonda.com
Old 01-09-2009   #105 (permalink)
EM2 RYDER
New Member
EM2 RYDER's Avatar
EM2 RYDER is an unknown quantity at this point
i already have and i/h/e and clutch and lightend flywheel and i was thinking about the crower stage 2 but unfortunatley i cant afford everything that you have to buy with it ie. valve springs and retainers, kpro. so say i get the crower stage 1 i know you dont need to upgrade the valves springs but would you still need something to tune it with and if so whats the best other than kpro for the stage 1?
EM2 RYDER is offline   Reply With Quote
Tags
build , crank , d16 , d17a1 , gx , na , pistons , size , snout , stutters , vtec
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Post your sedan pic!
Post Pics Of Clean Jdm 7th Gens
2004-2005 Post Your Ride
Page 210 = The New Project!! -The Speedfoos' 383 Stroker thread!!
PINOYS! Sound off and post your Civic Pics!
2001 - 2003 Post your ride....
Varnerr88 new jdm thread pictures and talk come on in..
Lets see those BLACK Civics!!!!!
7th Gen Members Rides Accident's and Crashes Thread
EM2Crew Reppin (56k keep dreamin)
Site Supporters
aluminum radiator
Honda car spoilers
