Go Back   Honda Civic Forum > GENERAL > Honda Civic Member's Rides
Reload this Page
EM204 turbo build
Honda Civic Member's Rides Honda Civic Member's Rides - Want to show off your Honda Civic mods? Need help deciding what Civic part, mod, or even what version Honda Civic to buy? Anything and everything about your very own Honda Civic member's ride goes here.
LinkBack Thread Tools
Old 07-24-2008   #16 (permalink)
Tragedy
skate or die
Tragedy's Avatar
Tragedy is a name known to allTragedy is a name known to allTragedy is a name known to allTragedy is a name known to allTragedy is a name known to allTragedy is a name known to allTragedy is a name known to all
Re: EM204 turbo build
Nice build, valve cover paint is awesome.
Tragedy is offline   Reply With Quote
Old 07-24-2008   #17 (permalink)
DaRk_MauL
Super Member
DaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of light
Quote:
Originally Posted by filipinop1405 View Post
maul, you might as well get bigger ones if you are planning for power over... i think 250 is what some people say.. or is it more...well my point is do it right the first time and don't waste your money on anything that you plan on changing in the future, unless its the turbo...
yes you have a point there.but stock srt-4 injector are 520cc right?
I am gonna run the setup first on my stock block to see how everything runs
in the mean whyle i can build the 2de engine...
DaRk_MauL is offline   Reply With Quote
Old 07-24-2008   #18 (permalink)
filipinop1405
Diamond Member
filipinop1405's Avatar
filipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of light
well i'm not sure what the cc's are for the srt-4 injectors but what are you're power goals?
filipinop1405 is offline   Reply With Quote
Old 07-24-2008   #19 (permalink)
DaRk_MauL
Super Member
Ill be happy with a steady 300hp
Old 07-24-2008   #20 (permalink)
speedfoos
Boosted.......bitch.
speedfoos's Avatar
speedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questioned
SRT-4 injectors are 577cc Ching.
Check this page out. It's a good way to calculate injector size. If you're shooting for 300whp, the 577cc injectors will run at about 85% duty cycle which is just fine.
http://injector-rehab.com/issg/
speedfoos is online now   Reply With Quote
Old 07-24-2008   #21 (permalink)
DaRk_MauL
Super Member
thx clint good nfo check it out and yes the srt 4 ones wil be at 85% so they will
be fine for my project...
Old 07-24-2008   #22 (permalink)
DaRk_MauL
Super Member
KwV2 Coils
put my kw V2 suspension on this weekend. What a difference in driving behavior.Still have some adjusting to do because its to hard in the front right
no and going bumpy on the road, cornering is great tough!
Old 07-24-2008   #23 (permalink)
filipinop1405
Diamond Member
thanks for clearing that up for me clint.
nice coilovers ching
Old 07-25-2008   #24 (permalink)
exturbo6
Post Master General
exturbo6's Avatar
looks good man. good luck with the build!
exturbo6 is offline   Reply With Quote
Old 07-25-2008   #25 (permalink)
emjay
Super Member
emjay is a jewel in the roughemjay is a jewel in the roughemjay is a jewel in the roughemjay is a jewel in the rough
ok .. about the srt-4 injectors ... 85% with a return setup or without ???
mine are at ~50% duty and im only at 196whp ... returnless. You guys sure it will be enough??
Aren't there two srt-4 injectors as well ... ummm 540 sumting cc and 577cc ??
I am going to go for 300 whp as well .. and i was going to upgrade my injectors to 750cc RC engineering and it costs 400 bucks !! FUCK and i would love to not get this .. but last thing i want is short on fuel come tuning
emjay is offline   Reply With Quote
Old 07-25-2008   #26 (permalink)
DaRk_MauL
Super Member
hey wel if i use the site that clint posted
and i take your values at 50% duty it get
that you need 643cc injectors. So i found this sheat that also is refering to feul press.
I think its returnless but not sure about that.
http://www.srtforums.com/forums/f187...12/index3.html
Found also that there are 3 stage of srt
injectors.
Stage 0 = 527cc's
Stage 1 = 577cc’s
Stage 2 = 682cc’s
Old 07-25-2008   #27 (permalink)
filipinop1405
Diamond Member
jay i would go with a return line...it may be cheaper than just going bigger injectors if not that... i'm sure it'll be safer to go with the return lines! just something to look at and think about.
Old 07-25-2008   #28 (permalink)
DaRk_MauL
Super Member
yes that true
Old 07-25-2008   #29 (permalink)
speedfoos
speedfoos's Avatar
The return line is good so that you have positive control of the fuel pressure using an aftermarket fuel pressure regulator with a 1:1 boost reference port. In otherwords, for every extra 1 psi of boost it sees, it raises the fuel pressure by 1 psi. That's the only (although very important) benefit to going to a return system. If the stock fuel pressure regulator was adjustable then there would not be a need to change it.
Old 07-25-2008   #30 (permalink)
filipinop1405
Diamond Member
oh shut up clint...my shyt sounded better! damn always gotta put down the enlisted guys... just fucking with you... wonder if bob still has his stock one with boost reference...hmmm i'll check, thanks for setting me on the right track.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Post your sedan pic!
Post Pics Of Clean Jdm 7th Gens
2004-2005 Post Your Ride
D-E-F-A-B-R-I-C-A-T-E, defabricate - Page 193 - The Speedfoos' Turbo Thread!!
PINOYS! Sound off and post your Civic Pics!
Varnerr88 new jdm thread pictures and talk come on in..
7th Gen Members Rides Accident's and Crashes Thread
EM2Crew Reppin (56k keep dreamin)
Lets see those BLACK Civics!!!!!
The Silver Coupes thread!!
Site Supporters
aluminum radiator
Honda car spoilers
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
