there is some glare off the chrome housing, but it shoots way up into the air where nobody will see unless youre sitting on top of a big rig. i think there is also a lil bit which is what lights up the road signs. not as bright as halogen glare, but still there and bright enough to read the sign.
heres what it would cost if you dont mess up lol.
bosch e46 single projectors $100
ebay clear headlamps $100
china 50w ballasts $120
philips DL50 bulbs $110
wire harness with relay $15
supplies and extra things $50
so figure right around $500 for a retro that will be one of the brightest on the road.
it rained and the connectors did not seem to be wet at all. also so far there is zero fog in the lights. i think the ebay design is great. when i had my oem lights sealed up completely, they would fog in the corners a little. well the ebay design has a single vent in that spot, so it prevents the fog from forming. yay. also i need to get a ziptie for that ballast so it doesnt fall on the alternator belt.
thanks for all the comments. i actually just got done installing catz zeta kit to the halogen foglights! hehe. i mounted the ballasts underneath the headlamps and ran all the wiring with the bumper off. so yeah, get ready for even more light, about as bright as h3c hid kit with 2000+ lumens. im prolly gonna switch back to clear bulbs once the piaas burn out for even more light. pics coming tonight, but heres a sneak preview
heres where i mounted it, kinda hoping it doesnt fall, there is not much shelf holding it up. but i wrapped the wires around stuff so it wont actually fall to the ground.
stock (12.5v) vs boosted (15.4v) can you tell the difference??
and a quick pic of the hid relay mounted for easy access. all i have to do is unplug the green trigger wire when i take it to shops lol. that red stuff is just terminal protector spray.
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
