Go Back   Honda Civic Forum > GENERAL > Honda Civic Member's Rides
Reload this Page
Page 200 = New Video! - Page 200 - The Speedfoos' Turbo Thread!!
Honda Civic Member's Rides Honda Civic Member's Rides - Want to show off your Honda Civic mods? Need help deciding what Civic part, mod, or even what version Honda Civic to buy? Anything and everything about your very own Honda Civic member's ride goes here.
LinkBack Thread Tools
Old 09-17-2007   #826 (permalink)
ryox82
Super Member
ryox82's Avatar
ryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to all
Re: The Speedfoos' Turbo Install and Everything Else Thread!!
Quote:
Originally Posted by speedfoos View Post
Bah I officially suck at MIG welding. Even on mild steel. I'll finish the exhaust tomorrow. There's your update.
Damn man....don't give up!!!
ryox82 is offline   Reply With Quote
Old 09-17-2007   #827 (permalink)
Mr_Plenty
Super Member
Mr_Plenty's Avatar
Mr_Plenty has a spectacular aura aboutMr_Plenty has a spectacular aura aboutMr_Plenty has a spectacular aura about
keep them coming
Mr_Plenty is offline   Reply With Quote
Old 09-17-2007   #828 (permalink)
speedfoos
Boosted.......bitch.
speedfoos's Avatar
speedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questioned
Oh I haven't given up. Just for tonight.
I spent about 3 hours in the garage cutting, grinding and welding. When I blow my nose it looks like I've been snorting lines of road tar. I have two more full tube welds to make tomorrow and a couple holes to plug from tonight and the exhaust will be done. I'm just running out of daylight now that's it's getting closer to winter.
speedfoos is offline   Reply With Quote
Old 09-17-2007   #829 (permalink)
FoSho
Super Member
FoSho's Avatar
FoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of light
Mwuahahha, I'm back. Lost my internet for a couple days! I know ya'll missed me!
Well I've done the impossible. I have found an intake for the dezod kit without battery relocation!! Oriellys $20 custom build your own intake kit
Check the picture!
So to give ya an update....My pushing coolant problem is getting much worse...head gasket here I come, you're not alone foos!
I did however change my plugs & mess with the gap. It has completely taken away my misfire codes & rough idle on cold starts.
Now my problem is slow boost response or turbo spool.
The boost still builds to 7 psi but takes alot longer to reach 7 psi. Power is noticably different. Car ran fine after new plugs & intake. I noticed while driving in 2nd I usually build 1-2 psi @ 2200 rpm. Now I don't see shit unit about 3500 rpm. I check all my charge pipe connections, vac lines, I dunno whats going on. The downpipe is leaking slighty do to bolts backing out. That did bring down my turbo spool but not this bad. It is noticable different! The car does not drivel like a misfire is present. I figure if I have a boost leak it's gonna leak all pressure.
The odd thing is sometimes you get on it and boost is there and you're going. Then most of time it's like I don't even have a turbo. You can hear the turbo belting away but you're not really moving fast, by that time boost just kicked in and you're outta rpm. Anyone got any ideas? I hope turbo is ok!!!! All my oil lines are good.
I'm stupidfied once again
Aren't turbos fun!
FoSho is offline   Reply With Quote
Old 09-18-2007   #830 (permalink)
speedfoos
speedfoos's Avatar
Sounds like a boost leak somewhere in the IC piping. Ditch those worm clamps and get some proper t-bolt clamps, and then hairspray the ends of your charge pipes when you put the couplers back on. Also check to make you're not leaking where you plumbed your IAT sensor into the pipe.
Won the auction for my electric PS pump!!! It's from a Peugot 307. She needs a little lovin' (rezzy is cracked) but I got for next to nothing. The equivalent of $50 shipped. That should be here Wednesday or Thursday.
Oooops! Gonna be late for work!!
Old 09-18-2007   #831 (permalink)
Alpha 5
Ultimate Member
Alpha 5's Avatar
Alpha 5 should not be questionedAlpha 5 should not be questionedAlpha 5 should not be questionedAlpha 5 should not be questionedAlpha 5 should not be questionedAlpha 5 should not be questionedAlpha 5 should not be questionedAlpha 5 should not be questionedAlpha 5 should not be questionedAlpha 5 should not be questionedAlpha 5 should not be questioned
Nice find, I am really interested in this. I can't wait to see how it pans out....
Alpha 5 is offline   Reply With Quote
Old 09-18-2007   #832 (permalink)
FoSho
Super Member
FoSho's Avatar
Thats the funny part. Before my IAT sensor was loose in the silicone you could push it back & forth. Now I sealed it with alot of FIPG Silicone.
I'm gonna rip it apart this weekend & see.
Watcha gonna do with that P/S pump....I wanna see you rig this.
Old 09-18-2007   #833 (permalink)
MarchMadnessisM
Member
MarchMadnessisM's Avatar
MarchMadnessisM has a spectacular aura aboutMarchMadnessisM has a spectacular aura aboutMarchMadnessisM has a spectacular aura about
ahhh yes here comes another 20 pages of foos rigging this thing n trying to get it fixed, im tellin u this is gonna be like the biggest thread by the time he actually gets to 9psi and running correctly
MarchMadnessisM is offline   Reply With Quote
Old 09-18-2007   #834 (permalink)
Alpha 5
Ultimate Member
Alpha 5's Avatar
Yee of little faith,
want a cookie?
Name that movie.
Old 09-18-2007   #835 (permalink)
DsevenEm2
This is Myspace
DsevenEm2's Avatar
I...Am....Back.
My Turn:
Ok so im in Orlando now..yay? This place is ok... could be alot better but what the hell. The town is iffy.. lots of rice in the apartment complex. The people are whatever. Im sure ill get used to it. I woke up this morning and my car is covered in like..salt? or sand.. or some shit.. i have no idea. My roommates are cool.. and school starts next week.. oh boy. Just read all this stuff and damn i didnt see any of these problems coming in but oh well...ill be waiting for the updates as usual. anyway im here again.. and my internet is bullshit... it sucks, it keeps kicking me off and pissing me off...and sometimes the pages dont load.. any ideas anybody?
good luck foos, cheer up it could be worse..
DsevenEm2 is offline   Reply With Quote
Old 09-18-2007   #836 (permalink)
MarchMadnessisM
Member
i think hes pretty happy all his parts are comin in, hes got the turbo working, and he was almost late for work lol
Old 09-18-2007   #837 (permalink)
speedfoos
speedfoos's Avatar
My name is now MIG Master. I was able to run both beads with only two little holes to patch up at the end! Woohooo!!! Exhaust is back on the car and I can drive it to work again!!! Thank God I've been hittin' the gym as not having PS until this weekend is a work out.
Although I am a little offended FoSho. I have never 'rigged' anything in my life. All of my installs and mechanical bits and bobs are always flawlessly installed with the utmost degree of professionalism. No don't look under my car. That's not a piece of braided lock wire being used as an exhaust hanger....
As for what I'm gonna do with it, I'm gonna 'rig' it to replace my belt driven PS pump that I fubar'd.
Welcome to Orlando Jose. That crap you see on your car is a mixture of sand and salt. Be sure an wash your car often as that crap plays hell on paint and aluminum parts!
HGs arrived today as well as a new pair of safety glasses. Hooray! Now I'm just waiting on the head studs.
Old 09-18-2007   #838 (permalink)
FoSho
Super Member
FoSho's Avatar
haha, all apologies Foos. However, I do recall several threads back someone talking about representin kansas with a......piece of t-shirt? to...uh make a drive belt! See, how I being from Kansas know all too well the art of 'rigging' or 'ghetto rigging" if you will
I just hope it works out good so I can copy you!!!
I wish I was in the cool club
Old 09-19-2007   #839 (permalink)
speedfoos
speedfoos's Avatar
The cool club? All you gotta do is get in the thread and claim your member number man! You've had more than enough problems to be a T.E.A.R.S. member!
That was a sock and it was just an optical illusion...... Never happened.......
Old 09-19-2007   #840 (permalink)
LogicWavelength
7th Gen Photographer
LogicWavelength's Avatar
LogicWavelength is a glorious beacon of lightLogicWavelength is a glorious beacon of lightLogicWavelength is a glorious beacon of lightLogicWavelength is a glorious beacon of lightLogicWavelength is a glorious beacon of lightLogicWavelength is a glorious beacon of light
LOL... I love how on this forum, in order to be "cool" you need to have totally destroyed your perfect-working-order engine and spent thousands of dollars. I feel so special.......
.....and I should because I started it!
LogicWavelength is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Post your sedan pic!
Post Pics Of Clean Jdm 7th Gens
2004-2005 Post Your Ride
PINOYS! Sound off and post your Civic Pics!
Varnerr88 new jdm thread pictures and talk come on in..
7th Gen Members Rides Accident's and Crashes Thread
EM2Crew Reppin (56k keep dreamin)
Lets see those BLACK Civics!!!!!
The Silver Coupes thread!!
Site Supporters
aluminum radiator
Honda car spoilers
