Go Back   Honda Civic Forum > GENERAL > Honda Civic Member's Rides
Reload this Page
Page 200 = New Video! - Page 200 - The Speedfoos' Turbo Thread!!
Honda Civic Member's Rides Honda Civic Member's Rides - Want to show off your Honda Civic mods? Need help deciding what Civic part, mod, or even what version Honda Civic to buy? Anything and everything about your very own Honda Civic member's ride goes here.
LinkBack Thread Tools
Old 08-22-2008   #2731 (permalink)
speedfoos
Boosted.......bitch.
speedfoos's Avatar
speedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questioned
Re: Wasn't the IM, Valves are Fuxored (Page 178)! - The Speedfoos' Turbo Thread!!
OK, head is all pulled apart. A couple damaged bits.
Here's the exhaust stud that I mentioned.
Cam gear was cracked as well on three spokes
No big deal though. Pulled the rest of the studs out just to make it easier to handle on my little workbench.
Rocker assembly looked pretty good, if a little crappified on the end caps. Then again it's off a Hawaii car with like 60K on it, so no big deal
Lots of corrosion and gunk on the combustion chambers though. Intake valves had siezed a little as well, took the back of my screwdriver to pop them loose. My guess is the head has been sitting for a while given the amount of crap in there.
Nothing a little gasoline and elbow grease can't fix!
Everything is out and ready to be swapped though. Not bad for 2 hours of work!
speedfoos is offline   Reply With Quote
Old 08-22-2008   #2732 (permalink)
bomerman19
Senior Member
bomerman19 is a name known to allbomerman19 is a name known to allbomerman19 is a name known to allbomerman19 is a name known to allbomerman19 is a name known to allbomerman19 is a name known to allbomerman19 is a name known to allbomerman19 is a name known to all
is it just me or does one of those valves look bent 2nd row 2nd in from the left
bomerman19 is offline   Reply With Quote
Old 08-22-2008   #2733 (permalink)
speedfoos
speedfoos's Avatar
It's just you Paul, they're all straight as an arrow. It's just sitting cattywhompus in the egg carton.
Old 08-23-2008   #2734 (permalink)
DsevenEm2
This is Myspace
DsevenEm2's Avatar
Not bad at all for two hours.. looks like the Suzuki 90hp heads I got to pull off this past week at school.
Cars still give me the creeps though.... these heads and blocks and everything you're taking apart is about 90% the same as whats on these outboard motors.. ecspecially when I went into my Honda course a few months ago.. but im still tempted to take everything on my engine apart.. my luck with my car just stinks..
Oh yea.. Yamaha 5-star Certification awarded today FTWMFW!!11!
DsevenEm2 is offline   Reply With Quote
Old 08-23-2008   #2735 (permalink)
speedfoos
speedfoos's Avatar
Not much difference between a Suzuki 90hp head and a Honda 127hp head I'll bet!
Motors are motors man, as long as they are OHC, piston/rod-based, instead of pushrod or wankels, they are pretty easy to work on. Congrats on the cert!
Old 08-23-2008   #2736 (permalink)
speedfoos
speedfoos's Avatar
Houston, we are ready for re-assembly!
Old 08-23-2008   #2737 (permalink)
bomerman19
Senior Member
^sweet! soon you can blast off!lol
Old 08-23-2008   #2738 (permalink)
speedfoos
speedfoos's Avatar
Well, I thought so, but it's always something. Have a read. Not so bad, just a 48-hour delay.
Anyways, on to today's work.
Just a note, when you re-assemble a head, always put RTV (or Hondabond) underneath the endcaps otherwise it will leak. Just a little bit like so.
Here's Scott (wolfgang5884 on here) being put to work! I actually had someone to help me today, thanks Scott!!! Here he is pulling the motor mount off in preps to put the head back on.
And fast-forward to four hours later when she was ready to go. Had everything ready to go, started topping off the fluid, and look what I found.
Yes that's a tiny pinsize hole in my nice Koyo race radiator. Grr.... Oh well. Such is life. Nothing a little JB Weld can't fix.
This will sit until Monday now to give the JB Weld time to cure properly. I used the Kwik version, but I'm not going to take any chances. I've used JB Weld on my stock radiator for about 6 months and never had any problems with it leaking. This just needs to hold for a couple weeks until I get back to the states.
But she started right and ran with only minimal issue - gotta cut the lower timing cover due to some clearance issues with the longer bolt I used on the tensioner. So here she sits until Monday!
Old 08-23-2008   #2739 (permalink)
lordhelmet
Diamond Member
lordhelmet's Avatar
lordhelmet should not be questionedlordhelmet should not be questionedlordhelmet should not be questionedlordhelmet should not be questionedlordhelmet should not be questionedlordhelmet should not be questionedlordhelmet should not be questionedlordhelmet should not be questionedlordhelmet should not be questionedlordhelmet should not be questionedlordhelmet should not be questioned
Looking good as always Foos. Do you still have to get it inspected or can it be thrown on the boat and shipped back?
I get to go deal with changing out my fucking alternator. Weeeee!
lordhelmet is offline   Reply With Quote
Old 08-23-2008   #2740 (permalink)
exturbo6
Post Master General
exturbo6's Avatar
nice clint!!
exturbo6 is offline   Reply With Quote
Old 08-23-2008   #2741 (permalink)
speedfoos
speedfoos's Avatar
Thanks Steve! You should probably change your sig on here though.....
It got inspected, failed, and then while it was torn apart in my driveway, it magically passed. Gotta love hookups! Trying to get in order to go the track one last time before she ships. I would love to change an alternator and be running again.
Old 08-23-2008   #2742 (permalink)
emjay
Super Member
emjay is a jewel in the roughemjay is a jewel in the roughemjay is a jewel in the roughemjay is a jewel in the rough
clint for a guy who started from scratch, ur work is fuckin clean as hell good for u, everything is done so ... properly
emjay is online now   Reply With Quote
Old 08-23-2008   #2743 (permalink)
sicma99ot
just a man with a civic
sicma99ot's Avatar
sicma99ot is just really nicesicma99ot is just really nicesicma99ot is just really nicesicma99ot is just really nice
man its really commin together. i hope your close to being done, i wanna see those numbers.
foos FTW
sicma99ot is offline   Reply With Quote
Old 08-24-2008   #2744 (permalink)
speedfoos
speedfoos's Avatar
Quote:
Thanks! For me, half the build is in the looks. There's no point in putting a huge power mod on the car if it looks half-assed and dirty when you pop the hood. I'm a bit of a perfectionist when it comes to stuff like that I guess.
Quote:
foos FTW
LOL - she's not going on the dyno again until I get k-pro. The only numbers I should be seeing is when she goes to the strip next weekend!
Old 08-24-2008   #2745 (permalink)
emjay
Super Member
how u gona tune ur built engine then for the tracks? :S
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Post your sedan pic!
Post Pics Of Clean Jdm 7th Gens
2004-2005 Post Your Ride
PINOYS! Sound off and post your Civic Pics!
Varnerr88 new jdm thread pictures and talk come on in..
7th Gen Members Rides Accident's and Crashes Thread
EM2Crew Reppin (56k keep dreamin)
Lets see those BLACK Civics!!!!!
The Silver Coupes thread!!
Site Supporters
