Go Back   Honda Civic Forum > GENERAL > Honda Civic Member's Rides
Reload this Page
Page 200 = New Video! - Page 200 - The Speedfoos' Turbo Thread!!
Honda Civic Member's Rides Honda Civic Member's Rides - Want to show off your Honda Civic mods? Need help deciding what Civic part, mod, or even what version Honda Civic to buy? Anything and everything about your very own Honda Civic member's ride goes here.
LinkBack Thread Tools
Old 07-25-2008   #2551 (permalink)
speedfoos
Boosted.......bitch.
speedfoos's Avatar
speedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questioned
Re: Rebuild Time - First Startup Vid on Page 167!!! - The Speedfoos' Turbo Thread!!
50-mile update. Leaks.
But not too bad. Looked like the oil pump was leaking, the rear main, and possibly the passenger axle seal as well. So I tore it down last night, pulled the crank pulley back off and discovered I didn't put enough Gagunga juice on the oil pan when I put it back on. Easy fix, although I hate taking my downpipe on and off.
She goes for inspection today, so fingers crossed!
speedfoos is offline   Reply With Quote
Old 07-25-2008   #2552 (permalink)
emjay
Super Member
emjay is a jewel in the roughemjay is a jewel in the roughemjay is a jewel in the roughemjay is a jewel in the rough
i hope u passs
emjay is offline   Reply With Quote
Old 07-25-2008   #2553 (permalink)
dopes6070
dopes6070 should not be questioneddopes6070 should not be questioneddopes6070 should not be questioneddopes6070 should not be questioneddopes6070 should not be questioneddopes6070 should not be questioneddopes6070 should not be questioneddopes6070 should not be questioneddopes6070 should not be questioneddopes6070 should not be questioneddopes6070 should not be questioned
Thank God your not in California haha...
dopes6070 is offline   Reply With Quote
Old 07-25-2008   #2554 (permalink)
filipinop1405
Diamond Member
filipinop1405's Avatar
filipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of light
GL with the inspection bro!
filipinop1405 is offline   Reply With Quote
Old 07-25-2008   #2555 (permalink)
exturbo6
Post Master General
exturbo6's Avatar
poor clint....everyone pray for the man and his car...
exturbo6 is offline   Reply With Quote
Old 07-25-2008   #2556 (permalink)
filipinop1405
Diamond Member
Old 07-25-2008   #2557 (permalink)
exturbo6
Post Master General
exturbo6's Avatar
something happened to his car when he was leaving for inspection. so he has been in the mix of fixing it. shoudl be almost done..im sure hell be on to fill everyone in.
Old 07-25-2008   #2558 (permalink)
emjay
Super Member
wooo passing inspection with a BUILT BIG TURBO hahaha we're so funny guys
Old 07-25-2008   #2559 (permalink)
speedfoos
speedfoos's Avatar
Well as Steve mentioned, something very bad and almost terminal happened on the way to the inspection today. I was just going through the village to get to the highway, puttering along at about 25mph when all of sudden the engine started making a really odd, awful sounding noise. I didn't like it so I pulled over immediately and cut the engine. Then called Mindy for a tow back home (only 1.5 miles away).
Got home and tried to start it. Nothing. Sounded really bad too.
My first thought was I dropped a valve. Pulled the VC off and everything looked OK.
Next thought was I spun a bearing. But my oil pressure was good the whole time. So I dropped the oil pan (with the oil still in it), pulled the baffle out and pawed through the oil. Nothing there but some fine shavings from the rings as they seat themselves. I looked at the rotating assembly and everything looked fine.
***The whole time I'm up in AIM with Steve giving him updates and bouncing ideas back and forth - this really helped and can't say thanks enough. But I had to degrease my laptop!***
Anyway, so I go back up to and rotate the crank a little. Sounds weird, raspy popping. I look at the cam while I rotate the crank. Yeah. It's not moving. WTF over?
I pull the crank pulley off, thinking maybe a lost coil pack nut got wedged in the timing assembly, gumming things up. Nope not there, but what I did see was the my timing belt tensioner is like hanging off. WTF would have caused that? I have no idea. I remember tightening it down, but I might not have. I don't remember exactly, I've been wrenching a lot lately.
Had two options at this point.
1. Pour gas on the car, light it on fire, and walk away.
2. See what can be done.
I was close to TDC anyway, so I set things back on TDC, smeared some JB Weld on the tensioner bolt and ran it back into the block. I set the timing and then went and checked all the valve lash. It was all fine and within spec still and the crank moved without any problems.
Hmm......I might be OK. Then I put enough stuff back on to allow the car to run. I figured if I bent some valves, I can't really hurt it anymore than it already is. Pulling the head off and taking it to a machine shop is not economically feasible in this country. I would be better just buying someone's used head and shipping it over here.
Anyway, started her up and ran fine considering there were no O2 sensors hooked up at all and was just running the downpipe for exhaust.
Holy sheepshit Batman. That was a close call today!!
Old 07-25-2008   #2560 (permalink)
emjay
Super Member
damn foos, u musta thought at that point when driivng ur car and heard the noise like ----- fukkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkk kkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkk kkkkkkkkkkkkkkkkkkkk
worst feeling man, spend so much money and think sumting catastrophic happened
Old 07-25-2008   #2561 (permalink)
speedfoos
speedfoos's Avatar
Yeah, tell me about it. I was so excited today too. I made a little holder for my boost controller out a an extra radiator bracket and then all that happened. I think she's OK now and here's the boost controller bracket!
Old 07-25-2008   #2562 (permalink)
DaRk_MauL
Super Member
DaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of light
HEHE dont mention carinspection. Lucky
for you your not in Belgium yhe car will be
gone forever.... unless is back stock at
inspection!!!
Clint you know that not good for your valve he..was the timing of alot?
DaRk_MauL is offline   Reply With Quote
Old 07-25-2008   #2563 (permalink)
filipinop1405
Diamond Member
DAMMMMMMMMMMMMMMMMM bro can't believe that shyt happened bro. glad to hear that its ok tho
Old 07-25-2008   #2564 (permalink)
speedfoos
speedfoos's Avatar
Timing was spot on. She just needs to pass emissions and run (roughly) until I get back to the states and then she gets a new stock VTEC head - without giant 38mm hogged out exhaust ports - stuffed with my cam and springs.
Old 07-25-2008   #2565 (permalink)
Mr_Plenty
Super Member
Mr_Plenty's Avatar
Mr_Plenty has a spectacular aura aboutMr_Plenty has a spectacular aura aboutMr_Plenty has a spectacular aura about
close call
Mr_Plenty is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Post your sedan pic!
Post Pics Of Clean Jdm 7th Gens
2004-2005 Post Your Ride
PINOYS! Sound off and post your Civic Pics!
Varnerr88 new jdm thread pictures and talk come on in..
7th Gen Members Rides Accident's and Crashes Thread
EM2Crew Reppin (56k keep dreamin)
Lets see those BLACK Civics!!!!!
The Silver Coupes thread!!
Site Supporters
aluminum radiator
Honda car spoilers
Powered by vBulletin® Version 3.6.8
